  1. May 13, 2025 at 7:48 PM
    ToyotaDude
    ToyotaDude Member
    2003 Tundra AC V8 4x4
  2. May 13, 2025 at 7:55 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    Hauled 700 pounds of trash and grass clippings (most of the weight was from "Crackhead Corner") to the landfill today.
    Got compliments from one of the landfill workers. "Hey---you got a new ride?" Me: "New-to-me. 201K on her though." Him: "It's OK, it's a Toyota!" :muscleflexing:
    That was a nice compliment. :)
    Filled up three of my vintage gas cans with non-ethanol gasoline and hauled that back, just beating a rain shower.
    Hutcheson, MooreKen, bmf4069 and 8 others like this.
  3. May 14, 2025 at 4:14 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
  4. May 14, 2025 at 7:22 AM
    NUDRAT
    NUDRAT 6 lug life
    SW CT
    Between 'Ridgelines'
    check your breather on the rear diff - make sure it's not junked up as they do. Built up pressure is a sure way to fail your repair.
  5. May 14, 2025 at 7:30 AM
    Kalannar97
    Kalannar97 New Member
    Michael
    Hillsboro, TN
    2003 Red Tundra SR5 2wd AC V-8 LSD ABS
    New Frame (Recall in 2019), added 17" 4-Runner Snowflake Rims
    Already replaced the breather when I had the pinion seal replaced when it blew out. Unfortunately, I topped off the axle last night and it started leaking again at the edge of the JB Weld are on the bottom. It's not that bad and I should be able to use it for helping with our move this weekend. But a replacement axle will be in the future after we get moved in.
    NUDRAT[QUOTED] likes this.
  6. May 14, 2025 at 8:19 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Might be worth a trip to TX.
  7. May 14, 2025 at 8:37 AM
    Kalannar97
    Michael
    Hillsboro, TN
    That would be nice, but that is a long haul from Middle Tennessee. I've found a couple useable ones here that are in the $300-600 range for a complete axle. Just have to get the time to go get one. Been a busy couple of months and it isn't slowing down until end of June it looks like.
    On that note, how worried should I be about a 300k mile axle? There is an 2wd ABS V-6 axle with the 4.08 ratio in it. At the same place they have a 2wd like mine just no LSD as well with only 200k on it. Trying to decide which would be better to get for the least trouble. There are also a couple of ABS axle housings a little further away that have lower miles on them as well.
  8. May 14, 2025 at 9:41 AM
    mcharfauros
    mcharfauros Hafa Adai
    MO
    06 AC SR5 4X4
    Dumb Truck Thangs
    14May24
    Still slow going on the Truck. Got some new tires finally, was also able to find a matching wheel for a spare as well. I’ve had good luck with Falken Tires, so decided to try out these AT4s in 265/75/16.
    [​IMG][​IMG]
    While I was going hard at buying tires, I got a spare for our 100 series as well in 285/70/17 Falken Rubitrek. Still need to get some hardware for the Rock Warrior Ring.
  9. May 14, 2025 at 9:45 AM
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    it’s been sitting like that for a year?
  10. May 14, 2025 at 9:56 AM
    I just had something odd happen. Put my truck in reverse and let of the brake. It doesn't move. Drop it down to neutral and then back into reverse. Same thing. I then give it a little gas and it slams into reverse at that point. Not good. Got to my destination and it goes into reverse fine.
    Hopefully a freak thing?
  11. May 14, 2025 at 10:21 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Trans fluid level?
    455h0le_dachshund likes this.
  12. May 14, 2025 at 10:24 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Is there a what will I be doing to my 1st gen tundra soon thread?
    Found this big ass hole the other day. Thankfully I have a new OEM in a box waiting instead of rebooting again. Guess it's time to order the ECGS bushing too. I don't have severe axle angles but is there a way to slightly stretch the OEM boots without destroying the clamps? Seems they.aleays rub a little on at least 1 rib though I don't think that is the cause.
    Voss likes this.
  13. May 14, 2025 at 10:53 AM
    Good tip. Looks like fluid levels are good.
    Voss likes this.
  14. May 14, 2025 at 11:08 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    Is that overfilled? Fluid looks a little burnt. Could just be background. I can't remember cuz I don't have a dipstick anymore, but bottom notches cold and top notches are hot?
    Voss, G_unit3000 and Sirfive like this.
  15. May 14, 2025 at 11:12 AM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Top notches: off, bottom notches:running? Im not a tranny guy, but its bound to drain if the pump isnt running, right?
  16. May 14, 2025 at 12:19 PM
    NickB_01TRD
    KY
    Top notches hot bottom notches cold. Always check while running.
  17. May 14, 2025 at 12:23 PM
    Sirfive
    ‘02 Limited AC TRD
    Bassani cat-back
    Why is there more fluid in the pan while hot? Expansion? An inch or so of difference is alot.
  18. May 14, 2025 at 12:36 PM
    Dakillacore
    Georgia
  19. May 14, 2025 at 1:35 PM
    Fluid is definitely not burnt. Nice and pink against the napkin when I checked. As for the level, I agree it looks slightly high but this is where it's been for almost 5 years. I did my last transmission service in 2020. 20-25k miles since then. PHM once explained that a dip stick isn't an exact measurement, especially with ATF.
    So I think the level is ok..? If the issue happens again I'll report back.
  20. May 14, 2025 at 2:16 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Okay. Ya I figured it might have been the background making it look dark. It's certainly not high enough to where it should be causing an issue. Just my initial thought. Hopefully it's a fluke.
    Side note: It's funny how you gather an understanding of someone over the internet. My first thought was, "there's no way he'd have dirty shit pumping through his truck."
  21. May 14, 2025 at 2:36 PM
    grzzlr
    grzzlr New Member
    2002 AC V8 TRD 2x
    Still riding that high from the differential fluid fixing the shudder (it feels like new it was so bad!) today I figured out what the front end rattle was. The driver said anti-rattle spring was broken! Local parts shop had a new set for $3, rattle is gone. Took the passenger side off and cleaned/greased it hoping it'd get rid of a slight squeal but it's still there damn.
  22. May 14, 2025 at 3:28 PM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Threw on some rainforest shop visors. Got tired of water going in the cab lol.
  23. May 14, 2025 at 5:47 PM
    Check to see if the dust shields on both front wheels is touching the rotor.
  24. May 14, 2025 at 6:14 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    If the dip stick isn’t an exact measurement, what’s the best way to know we filled enough oil? Recently did drain and fill and based my last fill based on Dip stick…
  25. May 14, 2025 at 6:35 PM
    tb1982
    tb1982 New Member
    NW Oregon
    06 Phantom gray Tundra DC TRD 4x4 SR5
    New wheels and tires! Got a smoking deal on these off a 22 4Runner. Would personally rather have white letters out but next set I guess!
  26. May 14, 2025 at 6:35 PM
    Azblue
    The Dirty T ( ^_^)_且
  27. May 14, 2025 at 6:40 PM
    Voss
    2003 AC TRD 4x4
  28. May 14, 2025 at 7:00 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    https://www.tacomaworld.com/threads/boot-slide-mod-no-more-blowing-cv-boots.146070/
    I remember this was popular on first gen tacos, back when I had my prerunners. I've never done it myself though.
    Kimosabe likes this.
  29. May 14, 2025 at 7:01 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    No CEL or pending codes?
    Fluid doesn't look terrible, but definitely could stand a drain n fill soonish.
  30. May 14, 2025 at 7:04 PM
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    And in neutral with parking brake set
    Voss likes this.
