2018 5.7 Toyota Tundra. Mileage
Discussion in 'Performance and Tuning' started by Itsmeto you, May 7, 2025.
  1. May 7, 2025 at 2:04 PM
    Itsmeto you
    Itsmeto you [OP] New Member
    Toybeast
    Hi, does anyone know why I’m only getting 7-8 mpg with city driving, not towing. My last Tundra was an ‘08 with tow package and i was getting 15mpg in the city and highway. Both have the 5.7 motor, the ‘08 had 4.10 ring gear the ‘18 supposedly has a 4.30 on Toyota’ VIN info.
    I can obviously tell that the ‘18 Tundra has a more highway gear ratio so not believing the 4.30 ring gear setup, I’m thinking more like a 3.90.
    The local dealers are saying that it may be a catalytic converter issue.
    Any thoughts would be extremely appreciated!
    Go Tundra Nation!!!
  2. May 7, 2025 at 2:06 PM
    How long have you had it and how many miles are on it?
  3. May 7, 2025 at 2:10 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    2021 DC SR5 4x4 (guess the color)
    Need more info. Mileage, service history and fuel trim data (via scan tool) would help. Is this a Flex fuel vehicle?
    Tundra234 likes this.
  4. May 7, 2025 at 2:12 PM
    Itsmeto you
    Toybeast
    I’ve only had it for 4 wks, it has the same motor and approximate ring gear as my ‘08 which i owned for 17 yrs.
    My ‘08 had 235,000 miles and got 15mpg city and hwy, the ‘18 has 112,000 and is only getting 7-8mpg both have the 5.7
  5. May 7, 2025 at 2:15 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    Of all the possible things contributing to poor fuel economy like you describe, the axle gear ratio is very low on the list.
    caboj likes this.
  6. May 7, 2025 at 2:20 PM
    Itsmeto you
    Toybeast
    Mileage is at 112,000, the truck was a one owner vehicle with regular maintenance, I don’t know about the fuel trim data (scan tool) is this something that a certified Toyota shop can do? Not a dealer. A local dealer had mentioned that it could be a catalytic converter issue although i would think that the engine light would be on.
  7. May 7, 2025 at 2:26 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    Hold up on the scan tool. Is this a Flex fuel vehicle? You’ll know if the fuel cap says E85 is okay and under the hood the engine code sticker will say “3UR-FBE” and your VIN will have a “W” in it.
  8. May 7, 2025 at 2:29 PM
    Itsmeto you
    Toybeast
    Thanks for your help, no not a flex fuel vehicle.
    WhiteSR5 likes this.
  9. May 7, 2025 at 2:31 PM
    Tundrav82019
    Tundrav82019 New Member
    Leo
    2019 Tundra Limited TRD Off Road
    Probably check tires, alignment and wheels.
  10. May 7, 2025 at 2:38 PM
    caboj
    caboj New Member
    CA
    2018 CM TRD OR
    Is this based on the dash read out or actual MPG calculated when filling up?
  11. May 7, 2025 at 2:42 PM
    Itsmeto you
    Toybeast
    Tires and alignment are good, tire pressures are correct, Nitrogen filled. The truck does have upgraded 20” rims/ tires, Michelin street tires, vs the OEM 18” rims.
  12. May 7, 2025 at 2:44 PM
    Itsmeto you
    Toybeast
    Yes, i had wondered this also, and checked with actual gallons per odometer readings. Thanks
  13. May 7, 2025 at 2:49 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    Thank you for clarifying. 7-8 MPG is not normal. Could be a lot of things; final drive ratio will not cause fuel economy that poor.
    You can get a scan tool that is able to read live data at Harbor Freight, Walmart, Auto parts stores, Amazon, etc. It will help pinpoint the problem. If I were in your position, I would verify that maintenance is up-to-date, particularly Air filter and spark plugs..."regular maintenance" to many owners means the oil was changed every 10,000 miles. If you can't verify from Toyota that the plugs have been changed, that's the first place I would start with a new air filter and fluids all around. Also, run a couple doses of Techron or other PEA-based fuel system cleaner to help clean up any dirty injectors.
    If you service yourself, unplug the battery while you work on it to reset the fuel trims. Check fuel consumption MANUALLY (miles driven / fuel consumed). If still poor fuel economy, we can start pinpointing using live data.
    Possible (more likely) causes beyond routine maintenance:
    -Faulty Mass-airflow sensor
    -Slow/faulty upstream O2 sensors
    -Faulty/Dirty fuel injector(s)
    -Faulty fuel pressure regulator
    -Coolant temp sensor
    -etc...etc.
    Most of these are common repairs that come up after 100k miles.
    A bad catalytic converter would throw a check engine light unless the downstream O2 sensors are bypassed or have spacers added to fool them.
  14. May 7, 2025 at 2:53 PM
    Itsmeto you
    Toybeast
    one of the odd issues is the Toyota build sheet on the truck through Toyota’s VIN # check is that it is supposed to have a 4.30 gear ratio. My previous ‘08 Tundra with a 5.7 and the tow package, at 4.10 ratio had a lot more off the line response. I suspect that the build sheet is incorrect as the off the line response seams to be more inline with a 3.90 ratio. I have gotten ahold of the dealer that sold the truck but they are unable to see if the original buyer elected for a highway gear vs the towing gear ratio.
  15. May 7, 2025 at 2:59 PM
    WhiteSR5
    WhiteSR5 New Member
    SC
    Are you more concerned about the final drive ratio or poor fuel economy? I can't help with the former; but the poor response and poor economy are very likely related.
  16. May 7, 2025 at 3:03 PM
    Itsmeto you
    Toybeast
    Thanks WhiteSR5, I will look into this, obviously something is off on the vehicle. As mentioned my previous’08 was a total Bear on pulling and off the line response. If i selected the towing mode without a load, off the line this truck was crazy quick! The ‘18 Tundra with the supposed 4.30 gear’s are not close to being comparable and the 50% mpg loss is a total mystery.
  17. May 7, 2025 at 3:25 PM
    Tundrav82019
    Leo
    Also maybe check if the butterfly valve for your air intake and oxygen sensor could be cleaned
  18. May 7, 2025 at 3:27 PM
    Red&03Taco
    Red&03Taco YUT
    Jerad
    2018 Platinum Tundra, 2016 Platinum Sequoia, 2003 Tacoma SR5 V6 5Spd
    The lack of quickness off the line is a separate thing. They changed the throttle input mapping because people complained about the earlier trucks being too jerky when you depressed the throttle.
  19. May 7, 2025 at 4:26 PM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Just bought mine. Here's my computer mpg. One way to work, 8 miles city stop and go.
  20. May 7, 2025 at 6:05 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    8 in town is low. Most of my driving is highway and I see about 13.5 overall. Highway only is closer to 15. Towing my 25’ travel trailer gets me in the 8 range.
    From my understanding, 4.30 was the only ratio available in 2018 4x4 models.
    For comparison, my truck is also a 2018. CrewMax Platinum. She’s a fat pig, weighing 7,200# with me in it every day because of the canopy, heavy tires, and all the other shit that adds up. 285/75-18 LRE tires and 5.29 gearing.
    Has your truck had its 100,000 mile service stuff done? Spark plugs, every fluid in the whole thing, clean air filter, belt, etc. if you’re not sure, now would be a great time to do it so you have a solid baseline.
  21. May 7, 2025 at 6:26 PM
    Pig Rig
    Pig Rig Get to Work
    Long Bed
    Towel for a Seat Cover
    A bad plug is possible, not sure if that throws a warning on whatever year OP has.
    Used to get real shit mileage per gallon on a 5 cylinder Ranger until it was 6y cyl again.
    EmergencyMaximum likes this.
  22. May 8, 2025 at 3:47 PM
    Rexr
    Rexr New Member
    Sam
    Bay Area, CA
    2018 MGM SR5 CrewMax
    Build Page https://www.tundras.com/threads/stage-1-of-my-build-complete-37s-are-on.157611/#post-3916395
    That fuel economy is ungodly low. I have a 2018 5.7 and im on 37inch ATs and 4.30 axle ratio and I get around 10 in the city and 15 on the freeway. You should not be getting that low of gas milage stock.
    First step is see if thats your actual milage. Drive to the gas station and fill up your truck. Then track every mile you drive (use gps to do this not your odometer in case its inaccurate). Once you are near empty fill up again and divide the distance you drove by how much you just filled up. This will be your ACTUAL MPG.
    If this is still low then the issue wasnt your dash reading. I would start off by checking/replacing the engine air filter, do an oil change maybe using the correct viscosity oil, run an injector cleaner through your fuel system (like techron or seafoam, just make sure it has PEA), clean your mass airflow sensor, clean your throttle body, and check your spark plugs. Your plugs should not need replacing at 66k miles. They are iridium tips so they should last around 100k-120k. But check them still incase they are fowled with carbon. If they are fowled replace them and DEFINATELY run the injector cleaner once or even twice.
    If the issues still persist then id replace the O2 sensors. I wouldn't worry about your axle ratio. 3.90 and 4.30 should not make a differnt in MPG of more than 1mpg unless you are towing, have oversized tires, live in mountainous areas, or have a lot of weight in the bed/cab.
    Hopefully your cats are not the issue because that would be EXPENSIVE and these fuckers have 4 of them.
  23. May 8, 2025 at 4:23 PM
    EmergencyMaximum
    Stock weight is 5680! What you have is like fully loaded truck! I doubt mods add that much. You don't have any payload capacity left. How much do you weigh, sir?!
  24. May 8, 2025 at 9:33 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    I’m 245#, but still sexy.
    (5) 35” heavy tires
    Heavier suspension parts with Deavers.
    Alcon brakes are big and heavy
    canopy
    Bedslide
    50L Dometic full of cold ones
    Dual batteries
    ARB dual motor air compressor
    Stereo gear with a heavy sub box
    200W Solar on canopy roof
    A mid-size Action Packer tote with a few tools and minor safety stuff
    Bunch of lights
    It all adds up…. I’ve weighed it several times and it’s pretty much always in the 7,100 to 7,200 range. As mentioned, she’s a fat pig. And, you’re correct. I technically have no payload left. But, I’d argue that the heavier tires and wheels (4 of them), the big brakes, and half of the additional suspension weight ought not count against payload since they are unsprung weight that the truck is not carrying. This thread is not about that though, so let’s not discuss that theory here.
    Back on topic, I just ran 340 miles on a hilly interstate in Western Oregon today. 75 mph with cruise, and rolled 13.9 mpg.
  25. May 8, 2025 at 10:00 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    Another thing to consider, and I didn’t look back to see.
    Is your speedometer accurate? When I went to bigger tires, I put in a Rough Country Speedo calibrator. It’s really close to perfect.
    If you have larger tires without Speedo calibration, you’re not going to show as many miles per tank as you actually covered. Not by enough to show 8mpg on its own, but it all adds up.
  26. May 9, 2025 at 10:50 AM
    Uncle_Charlie
    Uncle_Charlie New Member
    2018 Tundra- Work truck package
    Have you checked the brakes? I suppose a brake part could be dragging making the drivetrain worker to overcome that resistance.
  27. May 14, 2025 at 11:28 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    For grins, and because I’m due for a shock rebuild and want good data, I weighed each corner last night.
    Full tank of fuel, minus 3.2 miles worth of gas to the weigh station.
    Golf clubs in the bed and a backpack with laptop and other associated work stuff in the back seat.
    Front Left: 2,000#
    Front Right: 1,750#
    Rear Left: 1,950#
    Rear Right: 1,750#
    Total weight: 7,450#
    I weighed the entire truck at the end to narrow down any variances. I also forgot to list the full skid plate package and power steps when listing my adders.
    I say that the 5,680# claim is with an empty tank and no passengers. A full tank of gas and me adds nearly 500# right off the bat. Still means I’ve added nearly 1,300# of stir to my truck…. None of my stuff is big ticket items. It just adds up.
