  1. May 12, 2025 at 8:49 PM
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    Took her to the beach.
  2. May 12, 2025 at 9:41 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Link for the pump/flush kit?
    Corndog123 and BR73[QUOTED] like this.
  3. May 13, 2025 at 2:10 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Oooooo.....I looked it up!! Dual reservoir shocks? Wow!!
    bulldog93 and reywcms[QUOTED] like this.
  4. May 13, 2025 at 3:04 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    L/S Grab Handle GCS AT Cooler Kit 295/70 18's TOYO Open Country AT III Bilstein 6112 / 5100 Coachbuilder Shackles 12Volt systems remote start Dasaita Android 13 CF trim / chrome delete Redline shifter boot Stillen CAI
  5. May 13, 2025 at 3:07 AM
    Corndog123
    Sam
    Tennessee
    How did it go?
    BR73 likes this.
  6. May 13, 2025 at 3:17 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Not too bad and used almost 2qts. I had plenty of shop towels to catch spillage.Tools needed:
    Vacuum pump/ bleeder with attachments
    Rags
    Pliers for the stinking clamp
    2qts of Toyota Transmission and Power Steering fluid (not WS)
    Air supply for the vacuum pump
    I also have a Stillen CAI so I had to remove the tube for the front air dam to access the lid for the power steering so flat head screwdriver for clamps
  7. May 13, 2025 at 3:20 AM
    Corndog123
    Sam
    Tennessee
    I gotchya. If I do mine I might go the manual pump route. Thank you for posting this!!
    BR73[QUOTED] likes this.
  8. May 13, 2025 at 3:22 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    Try to find an attachment that fits the power steering line fairly snug or it will suck air and take a little longer :)
    Corndog123[QUOTED] likes this.
  9. May 13, 2025 at 3:25 AM
    BR73
    BR73 Tundra LIFE
    Rick
    Talladega,Al
    My Four Uncles vacuum was actually a brake bleed kit but hell a vacuum pump is a vacuum pump but all the attachments are for a brake bleed which is next
  10. May 13, 2025 at 3:30 AM
    Corndog123
    Sam
    Tennessee
    Good advice!! Thanks again!
  11. May 13, 2025 at 5:43 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Here’s the current setup which is still a dual resi shock setup. But the new kit has some bigger benefits. Stronger, longer shocks/larger shocks, more travel etc
  12. May 13, 2025 at 10:15 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    That is my next tire, I believe.
  13. May 13, 2025 at 10:35 AM
    Cthulhu
    bulldog93 likes this.
  14. May 13, 2025 at 11:07 AM
    Ebrperk
    Ebrperk Old member
    South Central Kansas
    2018 1794 MGM
    Tinted windows, go rhino D6 side steps and shorty antenna, Bilstein 5100's rears, 6112's fonts set to 2.5" Rocktrix RT111 18x9 -12offset NItto Terra Grapplers G3's 275/70 R18's. Amp from James @ Tech12volts FRAC Harness
    Thanks, found this on Facebook marketplace, I spend way too much time on there
    Armstrs[QUOTED] likes this.
  15. May 13, 2025 at 11:18 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Much appreciated... :thumbsup:
  16. May 13, 2025 at 11:56 AM
    Corndog123
    Sam
    Tennessee
    That's so freaking COOL man!! Thank you for the pic and description!!
  17. May 13, 2025 at 3:25 PM
    Red-Barn
    Red-Barn New Member
    Saturday
    2016 SR5 DC TRD Off-Road
    What are the running boards on your truck? Link?
  18. May 13, 2025 at 3:50 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Perfect...
  19. May 13, 2025 at 4:02 PM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
  20. May 13, 2025 at 4:08 PM
    Red-Barn
    Red-Barn New Member
    Saturday
  21. May 13, 2025 at 5:54 PM
    shawn474
    MoCo, Maryland
    These have been great for me; I put skateboard grip tape over the steps and have to replace it every year or two. Takes 5 minutes. But these are sturdy, the powder coat has held up exceptionally well and couldn’t be happier (especially for what I paid). YMMV
  22. May 13, 2025 at 8:39 PM
    Stone Chingon'
    Stone Chingon' New Member
    BC
    East County SD
    2021 Crewmax 4x4 Limited
    I picked up both pairs of shocks for $2500. The coilovers are tuned by Accutune and have the 500lb Eibach springs installed (stock 700lb Fox springs came with/included in the deal). Rear shocks are stock Fox valving etc..
    Dude threw a pair of TC upper arms in for $500 everything had less than 2000 miles on it. Not sure if I am going to install them yet or not.. The truck really isn't lifted all that much maaaybe 2". This truck is my daily driver and I am so happy with the way it rides and drives.
    I will say that when mounting up the new wheels it seemed like the new lug nuts only grabbed like 3-4 threads of my wheel studs before thet were ready to be torqued them down? Seemed a bit scary.. Anyone else out there experience this??
  23. May 14, 2025 at 4:11 AM
    atc250r
    atc250r New Member
    Orange County, New Yorkistan
    2020 Tundra Double Cab 6ft Bed SR5 TRD OR
    Nothing yet except for some LED interior & exterior bulbs.
    Not sure where you're located but I'm going to be pulling the Toyota nerf bar style steps off my 2020 double cab if the rain stops for a few daysPXL_20250328_154603021~2.jpg . I like the Tyger steps Shawn has but it looks like they're only available for Crewmax trucks. If you're in the northeast and are interested in the ones I've got.
  24. May 14, 2025 at 4:58 AM
    shawn474
    MoCo, Maryland
    here you go:
    https://www.vividracing.com/tyger-a...MIus-ii_SijQMVP2dHAR0JUxVNEAQYAyABEgIG8fD_BwE
    atc250r[QUOTED] likes this.
  25. May 14, 2025 at 5:00 AM
    atc250r
    atc250r New Member
  26. May 14, 2025 at 5:12 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    @Stone Chingon' Sweet set up! Not sure which brand of wheel? Method, Racine, SSW? I would reach out to the manufacturer and ask about lugs. I hit up Method about torque and my MR701's are 85-91 foot pounds with a minimum of 7.5 turns. Make sure you have the right type of lugs as well.
    I recently had UCA's installed and it made a night & day difference on handling- I recommend getting those on.
  27. May 14, 2025 at 5:47 AM
    I'm going to say Kansas.
