Bed partition
Discussion in '3rd Gen Tundras (2022+)' started by WhiteDevil1978, May 13, 2025.
  1. May 13, 2025 at 2:02 PM
    WhiteDevil1978
    WhiteDevil1978 [OP] Ye Olde White Devil
    Dustin
    North Carolina, 'Murica
    2023 Tundra SR5 TRD Off-Road
    6 inch lift, 37 inch tires, Badlands Apex 12,000 lb winch, Fab Fours concealed winch mount with 30 inch LED, Prinsu roof rack with RC 40 inch LED and 10 inch RC LED's on sides, Auxbeam 12 switch controller, Heretic ditch lights, RetraxPro XR bed cover, Elevate bed crossbars with additional bar that connects them, Pedal Commander throttle control, overlanding solar array (2) LiTime 230ah batteries, Renogy 40 amp DC to DC charger, LiTime 60 amp MPPT, LiTime 40 amp LiFePO4 AC to DC charger, Renogy 400 watt suitcase panels
    I wanted a better looking bed partitioning board and did not want to pay out the rear end for a metal one, so I decided to create my own. For the last two years I used just an ordinary 2x8, but the board was always an eye sore compared to the rest of the truck. So.... out came the saw, stain, wax free shellac as a bonding coat and Extreme Protection polyurethane. I have actually created two of these boards, but one is coated in spar urethane and the other will be coated in water based polyurethane. Interesting little tidbit I learned..... some water based polyurethane are actually harder than oil based! They resist denting and scratches better. At least that is the claim of several people and the manufacturer. I'm giving it a go and see what I get! The lettering is created using a wood burner/pyrography kit20250513_164252.jpg 20250513_164301.jpg
  2. May 13, 2025 at 2:11 PM
    SavageAsFlux
    SavageAsFlux New Member
    2006 Tundra SR5 DC Auto Blue Metallic
    I like it, cool idea with the wood burning the logo into it, Might want to do that at some point with my 2x8 in my bed.
    So would you recommend the water based poly then?
    cartage1 likes this.
  3. May 13, 2025 at 3:35 PM
    WhiteDevil1978
    Dustin
    I'll include all the links to the products. I did massive homework on this to make sure I got the absolute most durable outcome possible. I used Minwax Special Walnut stain. That needs to cure for 48 hours or more, then two coats of Zinsser Sealcoat matte/flat as a bonding agent (according to instructions on the can, DO NOT thin it with denatured alcohol or any other thinner for the purpose of a bonding coat). Then 4 to 5 coats of Crystalac Extreme Protection Water Based Polyurethane. Mountains of information in the form of reviews and other places suggests this is the hardest option to resist dents and scratches alike.
    https://www.amazon.com/dp/B001003F9M
    https://www.acehardware.com/departm...0rBx6lK-zde9AIEZ4WvqFsUxtpFkOXQxoCwPUQAvD_BwE
    https://a.co/d/3wPkoOo
    I checked over and over the compatibility of all these specific items and to the best of my knowledge this setup will give you the absolute hardest finish. It should be noted that I do have a weatherproof bed cover, so the polyurethane should be sheltered enough to prevent any problems, but that Crystalac water based polyurethane does have UV protestants in it, which is rather rare for polyurethane to have. It also has special additives to increase hardness. I assume those two things are what causes the abnormally high price of the polyurethane.
    Just read the instructions on each product and apply as directed. It should give you a great finish product! I even included the file that I used to make the stencil. I just made it as big as it could be while fitting on a piece of paper to run through the printer. Good luck!
  4. May 13, 2025 at 3:53 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    Excellent job! Makes mine look like its from Sanford & Son.20250317_161320.jpg 20250317_161243.jpg
  5. May 13, 2025 at 3:58 PM
    WhiteDevil1978
    Dustin
    I'm kind of pissed at myself for not thinking of this before now, but you could buy this poster, cut it out with an exact knife like I did a regular piece of paper, and make an identical board as the one I have made... except your logo would be noticeably bigger. I hate to say it, but I'm probably going to go through the process again just to have a board with a bigger logo. The extra small poster would fit perfectly onto a 2x8.
    https://www.redbubble.com/i/poster/...bePPqj7IfwcXpz_FMVlaqqWC1aMDPzoLqgG_uj0&gQT=2
  6. May 13, 2025 at 7:40 PM
    WhiteDevil1978
    Dustin
    I do like those guards you have. I have thought of using self adhesive rubber padding, but they screws look good and I'm sure will last longer! What kind of material did you use? That is a rather quick addition that I am sure will guard from the ends getting beat up!
    cartage1 and Raven67[QUOTED] like this.
  7. May 14, 2025 at 5:08 AM
    Raven67
    Kentucky
    I had leftover rubber from trimming my tailgate mat, worked perfectly. Just a thick piece of rubber, keeps it from flopping around in the slot.
  8. May 14, 2025 at 5:54 AM
    Looks really good!
  9. May 14, 2025 at 5:57 AM
    Looks pretty good to me. Those look a hell of a lot better than mine.
  10. May 14, 2025 at 10:08 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    Yep. Both of them look miles better than my unfinished, flopping around 2X8.
    cartage1, Gonefishingdave and Raven67 like this.
  11. May 14, 2025 at 10:14 AM
    Sean492
    Sean492 New Member
    Winston Salem, NC
    2018 MGM Tundra Sport
    I'm three years in with my unfinished 2" x 8". I'm hoping this motivates me to make it look better!
  12. May 14, 2025 at 6:56 PM
    WhiteDevil1978
    Dustin
    I found a plastic plate that was left over in building that solar battery bank in the photo. I'm going to use a planer to take out 1/16 of an inch so that the plastic is flush with the rest of the board. Got some black phosphate modified truss head screws to fasten the plastic to the board. I cut the plastic pieces today and the screws should arrive tomorrow, but it will be a few days before I do the planing. I actually have to go back to work tomorrow. Dang work gets in the way of far more interesting and fun projects! I'll post photos when the finished product is in my hands.
    Raven67[QUOTED] likes this.
  13. May 16, 2025 at 6:47 PM
    Yugo
    Yugo New Member
    Aleks
    North Carolina
    ‘24 Platinum MGM
    Could someone post exact dimensions and angles you are cutting these to? Appreciates you Tundra fam!
  14. May 16, 2025 at 7:14 PM
    DRP
    DRP Old Member
    Dave
    They have the specs in the manual. :thumbsup:
    It's on page 429 in my manual. Search "deck divider" if you're using the pdf manual
    Yugo[QUOTED] likes this.
  15. May 16, 2025 at 9:17 PM
    WhiteDevil1978
    Dustin
    If you still need the angles/lengths, I'll check tomorrow and post back.
  16. May 16, 2025 at 9:23 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  17. May 16, 2025 at 10:06 PM
    WhiteDevil1978
    Dustin
    Good detailed stuff! To get the angle PERFECT, now I will have to spend another week sanding, staining, shellacing and finally another 7 coats of polyurethane! I build decks for a living, and have every conceivable tool needed to do it perfectly, but the TIME involved!
  18. May 17, 2025 at 4:01 AM
    Raven67
    Kentucky
    LOL! I spent a few days on mine while watching NCAA basketball tournament! I didn't get too fancy with it since it sits in the bed of the truck to hold things in. I've already had bricks up against it. I agree you want it to look nice, but its not furniture. :cheers:
  19. May 17, 2025 at 5:18 AM
    hudrock
    hudrock New Members only jacket
    So Cal
    25 MGM Limited
    This is a cool feature. I get how the vertical dividers are handy but how would you use the horizontial dividers? Separating different material, like rebar on the bottom and lumber on the top?
  20. May 17, 2025 at 6:22 AM
    ESalt206
    ESalt206 25 Limited
    CO
    25 Limited Lunar Rock
    UnderCover Flex, mud flaps, Beat Sonic amp, Predator side steps. To come... heritage grille and 20in light bar
    I’ve used the horizontal boards to create a platform bed to sleep on in previous trucks. Works pretty well.
    Tundrastruck91 and 1lowlife like this.
  21. May 17, 2025 at 8:38 AM
    Yugo
    Yugo New Member
    Aleks
    North Carolina
    ‘24 Platinum MGM
    Thank you! I really appreciate you posting this.
  22. May 17, 2025 at 8:54 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    You are welcome.
    I didn't even know it was there until @DRP posted it.
    I don't think it is in my 2014 manual.
    I'd like to make a board to go towards the rear of my bed.
    90% of putting anything back there needs to stay near the tailgate to unload.:thumbsup:
  23. May 17, 2025 at 9:48 PM
    WhiteDevil1978
    Dustin
    7 coats of Crystalac water based polyurethane (supposedly the hardest, most scratch resistant) and used a planer to recess the hard plastic pieces where it'll meet the truck bed. I probably have too much time on my hands.
  24. May 17, 2025 at 10:32 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Hey that looks great! Love the logo
