First Gen Trans Temp Mode?
Discussion in '1st Gen Tundras (2000-2006)' started by Dracko, May 13, 2025.
  1. May 13, 2025 at 1:30 PM
    Dracko
    Dracko [OP] New Member
    2005 Tundra SR5
    Well i'm looking to do a fluid change on my 2005 Tundra and both OBDII readers I planned to use don't read trans temp.
    Wondering if the method of jumping the OBD outlet with a piece of wire and then shifting back and forth between N and D works for these trucks?
    I would prefer to use a scanner so looking into Techstream
  2. May 13, 2025 at 1:50 PM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    I know there are a ton of posts about using scanguage to do it, but that's all I remember. Maybe you can try the jumper wire mod (at your own expense) and report back, for science.
  3. May 13, 2025 at 2:02 PM
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    Right out of the FSM
  4. May 13, 2025 at 2:52 PM
    Dracko
    2005 Tundra SR5
    That’s exactly what I needed, thanks!
    Fragman[QUOTED] likes this.
  5. May 14, 2025 at 10:01 AM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    Installed a Scangauge II on my 01 AC several weeks ago and set one of the customizable ports to read the trans temp. Works perfect.
  6. May 14, 2025 at 10:43 AM
    Dracko
    2005 Tundra SR5
    That’d be nice. The Autel scanner we have doesn’t seem to read any trans temps let alone the FGT’s.
  7. May 14, 2025 at 11:35 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Curious which model Autel ?
  8. May 14, 2025 at 12:41 PM
    Dracko
    2005 Tundra SR5
    MD801
    BubbaW[QUOTED] likes this.
  9. May 14, 2025 at 1:00 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    My OBDII reader and app also pull trans temp from the ECU. I just use that instead of the FSM jumper method.
    OBDLink CX
  10. May 14, 2025 at 1:33 PM
    CC80guy
    CC80guy New Member
    Larry
    Lehighton, PA
    Seems to me that unless you can see a live gauge while actually towing down the road, or especially up a hill, a normal OBDII reader isn't of much use. You need a gauge in front of you that you can keep an eye on in real time under all conditions.
  11. May 14, 2025 at 1:37 PM
    PNW15
    PNW15 New Member
    WA
    2006 DC V8 4WD
    OBD Link gives live data via your phone screen, and can also record.
  12. May 14, 2025 at 1:46 PM
    Dracko
    2005 Tundra SR5
    Thanks again Fragman, that method worked as it should. Turned out I had some extra in there cuz I put back what I pumped out and was sorta shocked at how much came out of the drain tube
    Fragman and PNW15 like this.
