General Supercharger Thread
  1. May 13, 2025 at 12:21 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Is this from the valve body check valve? I was taking off the coolant puck and it was in the outlet...
  2. May 13, 2025 at 12:24 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Wow, yes it is. The Anti-drain back check valve.
  3. May 13, 2025 at 12:35 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Awesome...guess I'm removing my valve body again...been running without the spring since 07/2021...I am my own worst enemy
  4. May 13, 2025 at 1:01 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    awesome info as always!
  5. May 13, 2025 at 1:01 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Holy crap
  6. May 13, 2025 at 1:17 PM
    centex
    centex New Member
    4 years without it? I wouldn't be going back in there just for that.
  7. May 13, 2025 at 1:27 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Yeah, I'm tempted to leave it, but curious if it changes anything, like the mule kick shifts if I'm heavy on throttle. I was already planning to do a drain and fill since I'm replacing the stock cooler with an aftermarket unit.
  8. May 13, 2025 at 1:33 PM
    centex
    centex New Member
    Drain back valve should be the valve that doesn't let the converter drain down after sitting for long periods of time. But if there's one thing I've learned about Toyota's, they are different than anything I've worked on to date.
  9. May 13, 2025 at 1:34 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Is it the original transmission. Extra spring? :rolleyes:Weird how it would migrate to the puck.
    HulkSmurf14 likes this.
  10. May 13, 2025 at 1:36 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Original trans, only worked on by me. It was folded and stuck inside the outlet port on the transmission. I took off the puck and thermostat and there it was, sitting there like "is this a good time to discuss your truck's extended warranty?"
  11. May 13, 2025 at 1:49 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I'm gonna leave it as-is, hoping to upgrade the trans in a few months anyways.
  12. May 13, 2025 at 3:34 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    You just went to level 11 in my book! I like your style!
    Mdl and armyoffoo like this.
  13. May 13, 2025 at 4:27 PM
    blenton
    blenton New Member
    Manufacturers leave extra parts in new cars all the time! I mean, why else would I have a bucket of left over parts every time I work on my truck? :anonymous:
  14. May 13, 2025 at 4:28 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I finished up the interchiller installation and got my AC system back together...but I'm not happy with that sharp 90 in the soft line, so I ordered a hard 90 fitting and another braze-on connection so there won't be any restriction.
  15. May 13, 2025 at 4:31 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I'm still trying to figure out how that happened, unless the check ball body fell out and is floating around in the pan as well...the spring is supposed to be on top of the body. Tomorrow I'm going to drain and fill, I'll drop the pan when I do so I can verify.
  16. May 13, 2025 at 4:40 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Im jealous, looking forward to hearing about your chilly IATs. So badass!
    In other news my leaky exhaust sound I had was not a bad manifold or gasket against the block. Just a failed gasket on the manifold to the midpipe. Glad that was an easy fix. No more ticking or having to spend big bucks on new headers. Phew!
  17. May 13, 2025 at 5:33 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The only other spring would be from the tcc relay valve lockup. But you'd be having some major issues if it were out of the valve body. And it's not that long.
  18. May 13, 2025 at 6:41 PM
    HulkSmurf14
    2014 Tundra Limited
    If anyone wants a deal for a Harrop...I'm local and can check it out or what have you...
  19. May 13, 2025 at 6:44 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Nice. What I'm looking for but not a kit and just a little over budget at the moment...
    Thanks for posting it up!
    HulkSmurf14[QUOTED] likes this.
  20. May 13, 2025 at 6:46 PM
    HulkSmurf14
    2014 Tundra Limited
    I guarantee you could negotiate...these are the times folks give things away...this response is to anyone, not just you, Mike ;)
    reywcms, Tripleconpanna and Mdl like this.
  21. May 13, 2025 at 7:30 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    I can do $500 cash tonight
    e30cabrio, reywcms, Mdl and 3 others like this.
  22. May 13, 2025 at 7:44 PM
    blenton
    blenton New Member
    $501 - plus a $20 Home Depot gift card... :p
    e30cabrio, Mdl and HulkSmurf14 like this.
  23. May 13, 2025 at 7:46 PM
    HulkSmurf14
    2014 Tundra Limited
    Lol I'll ask :bananadance:
    Mdl likes this.
  24. May 13, 2025 at 7:46 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I'll do $850 and couple of stickers!!!!
    e30cabrio, blenton, Mdl and 1 other person like this.
  25. May 13, 2025 at 7:48 PM
    Tripleconpanna
    or.... If MDL is running an old TRD unit, he can have the Harrop, and I'll give him $750 and more stickers for his!!!
  26. May 13, 2025 at 7:48 PM
    blenton
    blenton New Member
    Stickers?!? Darn it man, you HAD to throw in some stickers! :bananadead:
    Let me see what I can squeeze out of the couch cushions - the kids may have left some interesting prizes in there. I'm sure there's some "vintage" popcorn I can throw in..
  27. May 13, 2025 at 7:50 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    She may be little, old and tired but she still puts out. :rofl:
  28. May 13, 2025 at 7:50 PM
    Tripleconpanna
    :laugh:
    e30cabrio and HulkSmurf14 like this.
  29. May 13, 2025 at 7:51 PM
    HulkSmurf14
    2014 Tundra Limited
    Like a pig snout, they don't wear out
    BigAl, Mdl and Tripleconpanna like this.
  30. May 13, 2025 at 7:51 PM
    Tripleconpanna
    and at her age, she'll just be happy to still be 'gettin' it'... I won't have to buy her fancy dinners, flowers, or larger injectors!!!
    Wynnded, HulkSmurf14 and Mdl[QUOTED] like this.
