White smoke from the exhaust like steam train
Discussion in '3rd Gen Tundras (2022+)' started by 1794 LE number 716, May 5, 2025.
  1. May 5, 2025 at 7:57 PM
    1794 LE number 716
    1794 LE number 716 [OP] New Member
    jonathan
    1794 LE number 716
    none
    ok so here is the question? I just hit the 1 year mark on my LE and I have just short of 30K. I went in to have the 30K oil change and I also bought new rubber cause the falken suck...
    as I was driving home 60 miles the truck was fish biting and felt like it was snagging up hills and losing power. I had to drive another 250 round trip and as soon as my wife got into the truck and I started it she said what's wrong with the truck. at a stop light the truck would shake till the hybrid kicked in. again up hills losing power and fish biting. called the dealership and he said bring it back down in the morning. they looked over it and saw that everything was plugged in. he drove it and could feel the fish biting and snagging. so I dropped it off on the Monday morning of the 28th of April funny enough the day I bought it in 24. when I pulled into the garage I cut it off and then started it back to roll up the window and that's when the white smoke started to poor out like a 20s steam engine, I have been in a rental ever since. still no word. anyone have this problem or know what it might be. I'm still waiting
  2. May 5, 2025 at 8:08 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Scary, cracked block or maybe head gasket leak?
  3. May 5, 2025 at 8:10 PM
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    Hadn’t heard the term fish biting before - that’s a new one to me but makes sense after a google search. Sorry to hear about your truck! I love to be my service advisor’s worst nightmare and call almost everyday after 4-5 business days or every day after the promised delivery date (I’ve had horrible luck with parts being on back order). I’d call for an update first thing tomorrow. The smoke thing kinda sounds like a head gasket but that’d be the first time I’ve personally seen anything about head gaskets going bad on a third gen. If they also did a rear diff fluid change, could be a bad diff, which has been a somewhat common problem. Best of luck!
    raylo and 1794 LE number 716[OP] like this.
  4. May 5, 2025 at 8:18 PM
    1794 LE number 716
    jonathan
    1794 LE number 716
    none
    ya my service manager didn't look very happy I'm in the rental till the 14th we will see
  5. May 5, 2025 at 8:18 PM
    1794 LE number 716
    jonathan
    1794 LE number 716
    none
    ya I didn't know what it was till he told me what it was time will tell I'm in the rental till the 14th
    chrisgibbs707[QUOTED] likes this.
  6. May 6, 2025 at 5:50 AM
    Gonefishingdave
    Gonefishingdave New Member
    Dave
    Central New York
    2024 MGM Tundra TRD OR Limited
    Bakflip cover, AVS vent visors
    I saw this title and thought: “they picked the new Pope already?”
    Edit: OP originally posted with title: “White Smoke”
    Hbjeff, hinkle, JLS in WA and 10 others like this.
  7. May 6, 2025 at 6:05 AM
    :rofl::rofl::rofl:
    That was a pretty good one. :thumbsup:
    JLS in WA, kirkb, Pine_Cone67 and 2 others like this.
  8. May 6, 2025 at 6:18 AM
    TundraDan723
    TundraDan723 Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    This is exactly what I thought too! :rofl:
  9. May 8, 2025 at 1:47 PM
    1794 LE number 716
    jonathan
    1794 LE number 716
    none
    so has anyone heard of this one yet coming from the 24 or other years? truck has been in the shop for over a week and this is the poss out come I just got. now I don't know too much about engines and all but this doesn't sound very good. this problem happened right after a oil change at the 30K mark
  10. May 8, 2025 at 1:54 PM
    1794 LE number 716
    jonathan
    1794 LE number 716
    none
    got word its a poss failed valve guide what ever that is
  11. May 8, 2025 at 2:14 PM
    chrisgibbs707
    Socal
    2022 Tundra SR5 4x4
    Ooof. Hopefully won’t have to be too invasive. I’d guess they’d just replace the valve guide and seal, maybe the whole head on that side (or both sides). Curious if the smoke was coming from coolant burning from overheating or oil making it past the valve guide seal, into the combustion chamber and thru ur exhaust.
  12. May 8, 2025 at 2:48 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Not a car guy, are ya?
    Rcflyersd and chrisgibbs707 like this.
  13. May 8, 2025 at 5:13 PM
    DontTazeMeBro
    DontTazeMeBro New Member
    2022 Platinum MGM
    Dammit, came here to make a “did you elect a pope” joke!!
  14. May 8, 2025 at 6:27 PM
    Observer
    Observer New Member
  15. May 9, 2025 at 1:34 PM
    JH8473
    JH8473 New Member
    2025 Tundra SR5
    None
    Probably a bad turbo.
  16. May 9, 2025 at 8:28 PM
    1794 LE number 716
    jonathan
    1794 LE number 716
    none
    ok so here is the good news. after all the test and talking with toyota it all came down to the fact the teck put 2 exter quarts of oil in the truck. the exter oil went into the cylinder and thats what caused the engine fish bite and smoke. all is well and the truck is running great . i got lucky
    Tundrastruck91 likes this.
  17. May 10, 2025 at 3:39 AM
    TundraDan723
    Which is why I change my own oil...
  18. May 11, 2025 at 7:09 AM
    Rcflyersd
    Rcflyersd Wingnut
    Mark
    Dakota
    01 Tundra SR5, 02 Sequoia SR5, 23 Tundra Limited double cab
    So is the offending dealer going to cover the damaged catalytic converters that were compromised by excessive oil mist passing through that will probably set check engine light issues with catalyst deterioration fault codes down the road? As in fault codes P0420 and/or P0430.
  19. May 11, 2025 at 5:44 PM
    Mossy Creek
    Mossy Creek New Member
    East Tennessee
    2024 WCP 1794
    When the dealer did my last free oil change at 20K miles, they put just under 9 quarts in. That was a tad over 1 quart too much.
  20. May 11, 2025 at 6:03 PM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    I still want to know what “fish biting” is.
    chrisgibbs707 and kirkb like this.
  21. May 11, 2025 at 7:19 PM
    Cthulhu
    Man this thing called search is really cool! :rofl:
  22. May 11, 2025 at 10:06 PM
    Rakkasan
    Rakkasan New Member
    NorCal
    2020 Tundra- cement-crew max 4x4
    Spray in Bed liner, 2-10”subs/400w.amp, tailgate shock, Tinted windows, seat covers, dash cover, CatShield, Fuel D538 20”wheels, Husky custom floor mats, TSC tool chest, leather seat covers. Genuine Cooling systems transmission cooler, scan gauge OBD2
    You should have the place replace your spark plugs, I’d bet they’re fouled a bit after burning two quarts of oil.
  23. May 12, 2025 at 10:46 AM
    1794 LE number 716
    jonathan
    1794 LE number 716
    none
    thats a great question that i will bring up to my service guy. thank you
  24. May 12, 2025 at 10:47 AM
    1794 LE number 716
    jonathan
    1794 LE number 716
    none
    that two is a great question that I will bring up to my service man. thank you
  25. May 12, 2025 at 10:55 AM
    yakeng
    yakeng 3URFE Apologist
    You are way more generous than me, I'd be raising hell. Significant long term damage can occur with overfilling oil.
    Rakkasan likes this.
  26. May 12, 2025 at 12:30 PM
    1794 LE number 716
    jonathan
    1794 LE number 716
    none
    I have it in writing that there will be no long term damage to the truck or engine. my service manager stands by his word and he will fix anything that comes down the pipe. I'm hoping that there is no damage at all. time will tell. I would have been a ass but me and my service manager are tight. he got Toyota to pay for a 2500 bed cover so he is on my side. well for now
    Tundrastruck91 and kirkb like this.
  27. May 12, 2025 at 2:05 PM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    Sounds good. You do know your service manager is taking the senior service manager position at the local Ford dealer next week. His word in good today.
    yakeng likes this.
  28. May 12, 2025 at 3:09 PM
    Coronerrpm
    Coronerrpm New Member
    Bob
    22 tundra red sport
    Non yet
    New Pope?
  29. May 12, 2025 at 7:10 PM
    1794 LE number 716
    jonathan
    1794 LE number 716
    none
    what do you mean he is leaving lololol
