Best way to route fuse tap into fuse box?
Discussion in '3rd Gen Tundras (2022+)' started by DrinksOnMe, May 6, 2025.
  1. May 6, 2025 at 9:22 PM
    DrinksOnMe
    DrinksOnMe [OP] New Member
    2024 Silver Tundra Limited 4x4
    Okay, you have an accessory that requires you to tap into the fuse box. You know which direction to install the fuse tap for continuity but you are afraid to cut the fuse housing to run your wire because you don’t want to void your warranty if moisture or dust gets in. What’s the best course of action here?
    I have searched the forum and Google and couldn’t find anything that made me comfortable. Wish there was an aftermarket fuse cover that was waterproofish. But I assume they would be under some legal challenges if it were to fail. What are your suggestions?
  2. May 6, 2025 at 9:59 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Are you needing it to jump off a specific fuse?
  3. May 7, 2025 at 3:01 AM
    60centenergy
    60centenergy I'm not superstitious, but I am a little stitious
    Zack
    GVL
    2024 Lunar Rock SR5 Tundra TRD Sport
    I found some empties that I added a fuse to. I did this to each of the boxes under the hood. I know the interior one is tight but haven’t needed to do anything add-a-fuse wise on interior yet.
    I just fished a wire up the bottom opening where the other main loom came in on each. I have some pics showing this on my under hood lighting write-up and bed lighting write-up if you wanna check it out.
  4. May 7, 2025 at 3:34 AM
    GREENPUS
    GREENPUS New Member
    Scott
    2024 Black Tundra Limited TRD Off-Road
    I’ve seen a few people install these smaller fuse adaptors and they are small enough to allow the fuse box lid to be stilll used
  5. May 7, 2025 at 6:48 AM
    DrinksOnMe
    My main concern is running the wire into the fuse box through the plastic housing. How do you maintain a seal if I cut into the fuse box to run a wire? I get I can just drill a whole but would rather like something a bit more water/dust proof.
  6. May 7, 2025 at 7:17 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I notched a lip on the fuse box itself and sat the wire there....the lid just sits on top and pushes the wire down just a bit to form a quasi-seal.
    NewImprovedRon and astrength22 like this.
  7. May 7, 2025 at 7:29 AM
    ESalt206
    ESalt206 25 Limited
    CO
    25 Limited Lunar Rock
    UnderCover Flex, mud flaps, Beat Sonic amp, Predator side steps. To come... heritage grille and 20in light bar
    This is exactly what I did on mine to avoid pinching the wire.
  8. May 7, 2025 at 7:31 AM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    You can also feed the wire thru the bottom of the fuse box, via where the rest of the wires enter the fuse box. It’s a tight fit but doable.
  9. May 7, 2025 at 10:17 AM
    NewImprovedRon
    NewImprovedRon New Old Guy
    Ron
    NW Arkansas
    2015 Radiant Red Tundra
    ^^This. You can also drill a hole in the cover and get a rubber plug that fits the hole and has a hole premade in the center of the plug. Run the wire through the plug and then insert the rubber plug into the hole. Seals nicely.
  10. May 11, 2025 at 9:57 PM
    DrinksOnMe
    Thanks for the info everyone. Just cut through the cap. Figured it cheaper to replace the cap rather than the fuse housing.
  11. May 12, 2025 at 4:11 AM
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield
    I made a 3D print tall fuse box cover that accommodates fuse taps. This link also supplies a file to print a fuse diagram label to glue onto it. This is for the fusebox inside the cab underneath the glove compartment. Keep the OEM one in case you need it later.
    https://www.thingiverse.com/thing:5859195
    GREENPUS, eddiefromcali and ChuckL like this.
  12. May 12, 2025 at 9:03 AM
    Noelandry
    Noelandry New Member
    Adrian
    2025 Limited
    I simply drilled a hole in the side, then used some silicone to seal it. Simple and effective.
  13. May 12, 2025 at 12:07 PM
    Rockpig
    Rockpig You did what?
    08 Limited
    I have 3 fuse boxes in my hybrid, which one are you talking about? Underhood or under passenger side dash?
