  1. May 10, 2025 at 7:10 PM
    Stock63
    Stock63 New Member
    2005 Tundra DC 4WD
    I’ll have to give it another try I guess. Should I clear the codes after?
    Sirfive[QUOTED] likes this.
  2. May 10, 2025 at 7:59 PM
    IMG_7996.jpgNew camping light per @APalmTree recco
    It’s super bright!!!
  3. May 10, 2025 at 8:03 PM
    Check for garbage buildup in the tone ring also, on the wheel it’s bitching about buildup in. Also, take sure the tone ring is visible near-centered or at least taking up a good portion of the sensor hole. Yes clear codes. I can’t remember if you need to clear them in the ABS ECU or if you can just clear normally. I’m more than a bit surprised to see you have multiple sensors bitching also. Almost like someone repressed bearings wrong, but probably not because it’s voltage/circuit codes?
  4. May 10, 2025 at 8:07 PM
    Oh and I just looked up c1241 b/c it wasn’t ringing a bell. Basically that code suggests your ABS module isn’t able to get enough voltage to function properly. Which may also suggest THAT is the problem, and the other codes are phantoms caused by the module-voltage-too-low issue, eh?
    I’ve not seen that code on here recently so if I were you I’d consult the FSM for that code string ASAP and start debugging.
  5. May 10, 2025 at 8:08 PM
    I always knew you was bright
  6. May 10, 2025 at 8:16 PM
    Azblue
    The Dirty T ( ^_^)_且
    Link?
  7. May 10, 2025 at 8:18 PM
    Stock63
    Stock63 New Member
    2005 Tundra DC 4WD
    I was looking though the facebook groups and someone had the same thing and replaced the module, but my abs light has been on for almost a year now.
  8. May 10, 2025 at 8:20 PM
    It very well may be the module/ABS ECU, but if I don’t have handy cheap access to a spare to test, I would just go by the FSM’s testing to confirm it’s the module. The process is in there IIRC.
    Stock63[QUOTED] likes this.
  9. May 10, 2025 at 8:22 PM
    Stock63
    Stock63 New Member
    2005 Tundra DC 4WD
    Forgive me for my ignorance but what is the FSM and IIRC? its probably a stupid question lol
  10. May 10, 2025 at 8:24 PM
    Factory Service Manual. You know, the thing linked in the mega thread near the top you should have downloaded by now? :rofl:
    IIRC = if I recall correctly. And a lot of times I don’t. But in this case I think I am.
  11. May 10, 2025 at 8:27 PM
    Stock63
    Stock63 New Member
    2005 Tundra DC 4WD
    I figure it was something like that but I just wanted to confirm haha
  12. May 10, 2025 at 8:30 PM
    RUSTYNUTS
    Rusty
    sOCal
    to be continued...
    Ew. Losing a front wheel would be inconvenient.
  13. May 10, 2025 at 8:32 PM
    Yeah it’s amazing. Open the FSM click on FIND in your PDF reader, and plug in your code. You may have to jump thru ‘next’ a few times, but eventually it takes you right to the diagnostic tree and all the info you need to diagnose the problem. Straight from Toyota. Exact same type of manual the shop tech is going to consult if they’re not familiar with the issue enough to directly solve it. Fucking magic. :rofl:
    BroHon and Stock63[QUOTED] like this.
  14. May 10, 2025 at 8:40 PM
    bmf4069, JakeJake and Azblue[QUOTED] like this.
  15. May 10, 2025 at 9:09 PM
    Stock63
    Stock63 New Member
    2005 Tundra DC 4WD
    codes aren't showing up in FSM weird maybe I'm doing it wrong?
  16. May 11, 2025 at 4:49 AM
    Don't start buying parts until you know for sure what the issue is. I've tried three different wheel speed sensors and still couldn't fix mine but I was having different symptoms than you. I was getting random ABS activation below 5mph but my light wasn't on.
    I eventually gave up and pulled both ABS fuses which triggered the light to come on. So now I live without ABS but my ABS light has been on for 6 years.
    You don't have that option in your 2005. They changed the fuses at some point and yours can't be pulled like mine.
    This thread may or may not help.
    https://www.tundras.com/threads/slow-speed-abs-activation-fixed.131442/
  17. May 11, 2025 at 6:42 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Does it dominate the darkness? :p
  18. May 11, 2025 at 7:24 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    How in the hell do you think you can run...
    when the helicopter light is as bright as the sun??
  19. May 11, 2025 at 7:58 AM
    Strange, I guess ABS codes aren't in the '05-06. They're in the '03 manual. Grab a copy of that year and run diagnostics from there. Section DI-469. They're saying that specific code is either battery/alternator or ??. Fastest thing you can do to rule out one of the three is to go to the local auto parts store and get your battery tested. If your alternator is more than 150k miles old, maybe a refresh is in order., but you can test it. And of course, check for cable corrosion and terminal corrosion, and terminal tightness.
    Anyway, yes, I think that code specifically is potentially triggering the other codes.
  20. May 11, 2025 at 8:44 AM
    Friendly heads-up:
    REI is having an anniversary sale starting 5/16 - 26th. 20% off one item per order/customer, code is ANNIV2025
    Sneak peek site and maybe a look at some of the stuff that may have add'l markdowns or something: https://www.rei.com/promotions/anniversary-sale
    If you were needing any camping or outdoor activity stuff and you're an REI person also, it's the time to buy. Just got the flyer in the mail.
    tpope, ToyotaDude, RUSTYNUTS and 3 others like this.
  21. May 11, 2025 at 8:57 AM
    Voss
    Voss Dust in the wind
    Valod
    2003 AC TRD 4x4
    Great way to ruin a campsite
  22. May 11, 2025 at 10:18 AM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    But get a load of those sweet purple cacti!
    FrenchToasty and Voss[QUOTED] like this.
  23. May 11, 2025 at 11:01 AM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    The FSM for 2005-6 shows the wiring for a double cab starting on page 454 of the electrical section. Looking on page 457 the grounding points for this system are behind the kick panels. Been raining some around here. Might be a good spot to check. Page 92 shows locations for IN and IO these grounding points.
    shifty` likes this.
  24. May 11, 2025 at 12:22 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Mother's day was a success. My wife didn't have to lift a finger today :hearteyes:
  25. May 11, 2025 at 1:48 PM
    Awesome. We’re just getting started over here. I’m tossing on some venison beer brats and pretty sure smoked cheddar links, Yukon gold mash, and who knows what the hell else will happen. Salad, zucchini casserole?
  26. May 11, 2025 at 2:00 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    @shifty` man get you a vacuum sealer. Protect them beautiful sausages from the freezer burn. We are having chili from last year that was vacuum sealed and adding some smoked brisket. Probably gonna vac seal the leftover brisket for the freezer.
    It's easier to control the portion sizes when the kids are home.. Us empty nesters have to take special measures at times..
    shifty` and KNABORES like this.
  27. May 11, 2025 at 2:09 PM
    They were processed at the end of January, and vacuum sealed before they went in chest the freezer. Just transferred from freezer to fridge on Thursday, and here they are thawed.
    Where you seeing burn?
    KNABORES likes this.
  28. May 11, 2025 at 2:30 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    No burn at all. Just seeing wax paper and assuming that they were in the freezer enclosed in that.
    Those look like very tasty, well seasoned and well stuffed sausages. I would hate to see someone go to that trouble and get freezer burn.
    I bought a chamber sealer a couple of years ago because I wanted to go faster at sealing.. Wow the difference. We put up 3 deer, 4 bluefin tuna and several catches of crappie and trout alongside of crawfish and such...
    Sorry, not trying to throw dirt. Sounds like I'm preaching to the choir about sealers..
    shifty`[QUOTED] likes this.
  29. May 11, 2025 at 2:33 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    I would trade a quart of crawfish stock for a pack of sausage like that..
    shifty` and FrenchToasty like this.
  30. May 11, 2025 at 2:45 PM
    tpope
    tpope New Member
    NW GA
    2006 Crew
    Have you ever seen canned sausage? We used to eat Penrose brand sausage…
