Kidd74's camping/adventure build
Discussion in '2.5 Gen Builds (2014-2021)' started by Kidd74, Dec 11, 2024.
  1. Apr 17, 2025 at 10:46 AM
    Kidd74
    Kidd74 [OP] New Member
    Nat
    Durango, CO
    2017 TRD PRO
    37's 5.29's...
    The rear locker doesn't really help with the 4lo limiter issue but the gears do. It's all about maintaining rpms through/over obstacles. Once you're up against something that wants to stop the truck (specifically the rear wheels) and you're at idle, the throttle just becomes unresponsive, locker on or not.
    I usually experience the issue going up a step or ledge. Normally I would crawl up, bump my front wheels up and over and slowly crawl up when the rear wheels make contact. Tundra won't let me do that so I need to approach those types of obstacles differently—never letting the rpm's drop too much and maintaining momentum which seems like a good way to break shit.
    I guess Toyota engineers were thinking they needed to protect the drivetrain from the big 5.7. My 3rd and 5th gen 4runners never did anything like this and yes, they had small motors and less power but they also had smaller diffs and a weaker drivetrain. I have a buddy with a 200 series Land Cruiser which has the same motor and smaller rear diff and his rig does not have any 4lo limiter issues.
    Curious if any of the new Tundras have this issue.
    I'm always down to get out. hit me up if you're in the area.
  2. May 11, 2025 at 8:08 AM
    Kidd74
    Nat
    Durango, CO
    2017 TRD PRO
    37's 5.29's...
    Took a quick solo trip to Moab via Lockhart Basin... rougher than I remember it from about a decade ago. Camped up on Porcupine Rim the second night.
    First off road workout w/37's and there was a lot of inappropriate touching of the fender liners.
    At the end of the trail, the truck didn't want to come out of 4 low so I just there in neutral for a while with both 4lo, 4wd lights blinking. I shifted to D and it made some bad noises. After turning the truck off and back on a couple times it shifted to 4 high. I'll change the TC fluid and see if that helps, hopefully it was just acting temperamental from not being in low range all winter.
