Official Tundra Wheel and Tire Setups - Pics and Info
Discussion in 'Wheels & Tires' started by csuviper, Jan 10, 2014.
  1. Mar 28, 2025 at 3:36 PM
    #3271
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I wish, but rays center caps are for 114mm center bore and will not work with these wheels. I made my own knockoff rays caps by modifying some caps for black rhino wheels and getting some rays raised resin decals.
  2. Apr 8, 2025 at 5:14 PM
    #3272
    TRD OR in bronze on a LX570. Look pretty good
    nowayout, Badknees, BlackNBlu and 5 others like this.
  3. Apr 10, 2025 at 5:28 AM
    #3273
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    Did you have cab mount rub?
    Badknees[QUOTED] likes this.
  4. Apr 10, 2025 at 11:03 AM
    #3274
    therealjonwick
    JR
    2019 OR
    Any body mount rub?
    Tundra Texan likes this.
  5. Apr 10, 2025 at 5:30 PM
    #3275
    therealjonwick
    JR
    2019 OR
    Really debating going to 295/70 18. Have 6112/5160. Top setting with 2cb shims driver 1 passenger. 3”+ front lift. Cb +3 with 1” spacer rear. Going to get +25 rims. Really don’t want a BMC.
  6. Apr 11, 2025 at 2:10 AM
    #3276
    therealjonwick
    JR
    2019 OR
    Any BMC needed?
  7. Apr 11, 2025 at 4:27 AM
    #3277
    DontTazeMeBro
    DontTazeMeBro New Member
    2022 Platinum MGM
  8. Apr 11, 2025 at 5:03 AM
    #3278
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Wow, what a great thread!!! Currently running 305/55R20s. No rubbing issues. Suspension is a Rough Country Vertex system. Rims are XD somethingorothers and I have no idea what the offset is.
  9. Apr 11, 2025 at 9:51 AM
    #3279
    textundra12
    textundra12 New Member
    I’m running a 1.9 bilstein with a 1.25 rear on 295/70 rt trail and I have only had slight rubbing in reverse at full lock when going over bumps.
    Corndog123 likes this.
  10. Apr 15, 2025 at 7:34 AM
    #3280
    GIJones77
    GIJones77 Turn, burn, bank, and roll!
    Indiana
    22 Tundra SR5
    Cosmetic only so far
    Ok guys, new poster here. I currently own a 2022 Tundra. I just lifted the suspension with 4" Rough Country set up. My problem is wheels and tires which brought me here. There is a ton of information, but I still can't find exactly what I need to pull the trigger on wheels and tires. So here goes..
    Stock 265/60R20 (33") on 20x8 rims with a +60 offset.
    I'd like to move up to a 20x9 rim with either +12 or 0 offset, 295/65R20 (35").
    I have aftermarket wheel wells that protrude approx 2" so I'm ok with the rubber sticking out a bit, but my concern is full turn what I can get away without rubbing or having to cut much out.
    Should I play it safe and go for the +12? Or should I go higher like 18 or even 30?
  11. Apr 18, 2025 at 4:02 AM
    #3281
    ChalkyDC
    ChalkyDC New Member
    2004 white tundra double cab
    Hey all, been trough here trying to nail down exactly what I want to do and can do with a wheel and tire set up. Not sure this is the right spot, but I didn't want to start another wheel and tire questions thread. Right now on my 04 double cab 4wd with a spacer lift, came on the truck and stuck with it for a while unfortunately, I have what I think are xd addicts (also came with the truck) that are 16x8 or 9, can't fully remember, that have a +5 offset with 285/75/16. I thought I was having contact issues with the tires on the upper control arms. Turns out suspension was a mix of worn and used, truck was repaired. Also found out the frame is/was bent. Uca's aren't touching the tires now, but I also need tires. Been looking at a few options and trying to get advice for the best way to go. Leaning towards pro comp 69series 17x9 with -6 offset and 4.76 backspacing, but I've also looked at trd pro 4Runner wheels and going back with the stock 17x7.5 wheels. I don't really want to keep the 285 size tire and I'm think more of 275/70 just to have a tad bit more clearance with the suspension. I really don't want to run spacers and if I go aftermarket I'll also buy hubcentric rings. With the options listed, is there going to be any other clearance issues to look out for? And what would be the best size tire to go with? I'm sorry if this is repetitive and a lot of information. After all I've had to do to this truck my budget shrank quickly.
  12. Apr 22, 2025 at 8:41 AM
    #3282
    Badknees
    Badknees New Member
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    Sorry for the late reply.
    No cab mount rub but just a little on the sway bar...not enough to worry about.
  13. Apr 22, 2025 at 4:28 PM
    #3283
    therealjonwick
    JR
    2019 OR
    No worries. Thanks! Think I’ll take the risk with 295’s.
  14. Apr 25, 2025 at 12:02 PM
    #3284
    Magnet18
    Magnet18 New Member
    Rob
    Oregon
    2008 Double Cab SR5 TRD
    Installed longer M14 wheel studs (ordered from Japan) and 1.5" spacers from Titan.
    I think it looks a lot better.
    Before & after
    [​IMG][​IMG]
    after
    COTundra23, Corndog123 and ATV25 like this.
  15. Apr 25, 2025 at 1:34 PM
    #3285
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    Before:
    BillyB, Seto87, COTundra23 and 3 others like this.
  16. Apr 28, 2025 at 3:20 AM
    #3286
    Corndog123
    Sam
    Tennessee
    Welcome from TN!!
  17. Apr 28, 2025 at 5:53 AM
    #3287
    Nightshade1970
    Nightshade1970 New Member
    2021 Tundra Nightshade Edition
    Carven Exhaust, Nitto Ridge, Bora 2" spacers, TRD Rear Sway, AFE Air Filter, LED bulbs, Truxedo Pro cover, Eibach 2.0 Coilovers, Smoked taillights, Lamin-X fogs, more mods coming
    SSW 17X9 0-offset. Yokohama Geolander 35/12.5 R17. Eibach front about 2" lift with coachbuilder shims for a lift about 2.5". Shimmed bumper, removed flaps. No BMC, rubs front liner very little so will heat and reform.
    jalam321, BillyB, Seto87 and 4 others like this.
  18. Apr 28, 2025 at 6:03 AM
    #3288
    Corndog123
    Sam
    Tennessee
    Nice!!!
  19. Apr 28, 2025 at 6:20 AM
    #3289
    Nightshade1970
    Thank you.
    Corndog123[QUOTED] likes this.
  20. May 5, 2025 at 3:53 PM
    #3290
    atc250r
    atc250r New Member
    Orange County, New Yorkistan
    2020 Tundra Double Cab 6ft Bed SR5 TRD OR
    Nothing yet except for some LED interior & exterior bulbs.
    Got a set of Raceline Gauge 950's wrapped in Wildpeaks this morning and I wasn't going to let the rain stop me from putting them on when I got home from work. 18x9 with +18mm offset clears 285/65R18's on a stock rig after removing the front mudflaps and the flaps in front of the front tires.
    ATV25 and Thumper_6119 like this.
  21. May 7, 2025 at 7:40 AM
    #3291
    nowayout
    nowayout New Member
    NY
    15 Dbl
    Do you have any better pictures? Or is that not your truck?
  22. May 7, 2025 at 10:36 AM
    #3292
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Fuel Assassins.
    Closest pic I have of them.
    Cant remember the Tire name off the top of my head,must be having one of those senior moments...
    You'll have to zoom in on em to see more details.
    Thought the chrome bolts on the flares went well with them.
    ATV25 likes this.
  23. May 7, 2025 at 1:11 PM
    #3293
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Yeah...That brings back memories of my Tacoma days.
    Did a lot of body mount chops and welding a cap on them to help keep em rigid.
  24. May 8, 2025 at 5:55 PM
    #3294
    RabidAxolotl
    RabidAxolotl New Member
    25 Lunar Rock Limited
    Method 316 Gloss Titanium 18x9 +18 offset
    Wildpeak AT4W 275/70r18
    OEM TRD Off-Road Bilsteins
    Slight rub at full lock with OEM mudflaps. Seemed to be when turning on sloped surfaces.
    You can see how slight the rub was. Took off the OEM Mudflaps and putting on RokBlokz this weekend
    Seto87 and ATV25 like this.
  25. May 8, 2025 at 6:00 PM
    #3295
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    I'm currently looking for tires for my 2018 with plans to run stock 18" wheels and BORA 1.25" spacers. My search has been for 285/70/18 but I have a good lead on 295\70\18 for a really good price.
    Going to be installing the Eibach Pro 2R front/rear kit with Dirt King UCA's & BORA 1.25" wheel spacers. I do have the TRD front sway bar.
    I don't mind removing or reshaping plastic but based off the quoted posts above, it looks like I should be okay as far as UCA and sway bar clearance, right?
    @Knoxh458 No wheel spacers on your rig, right?
    @bucketlintels02 Did you end up installing spacers?
  26. May 10, 2025 at 2:58 PM
    #3296
    therealjonwick
    JR
    2019 OR
    Currently running 6112/5160. 3rd setting with two driver shims, one passenger. +3 CB shackles and 1”block. Have bora 1.25”. Stock TRD 18 OR rims. CB bumper shims. 285/70 18 Toyo AT III. No rubbing. Plan to jump to 295 soon.
    ATV25 and TacomaTRD4x402[QUOTED] like this.
  27. May 10, 2025 at 3:06 PM
    #3297
    TacomaTRD4x402
    Southern California
    Thank you Mr Wick! Exactly what I was hoping to hear. That's just about the same plans I have for my truck. BORA spacers and I have the bumper shims too. I was able to get a full set of Toyo 285/70/18 AT III(same as yours).
    That's a nice truck you got there :drool:
  28. May 10, 2025 at 3:25 PM
    #3298
    therealjonwick
    JR
    2019 OR
    Thanks. Post up pics when you got it all done! I could have probably used only one of the shims. Maybe even forgone all together. Also have JBA UCA’s.
  29. May 12, 2025 at 3:59 PM
    #3299
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Had the same problem years back with some rims I got a good deal on.
    Chucked em up in the lathe and removed a bit of material and they fit fine.
    You could call a machine shop and have them do it.
    Cant imagine they'd charge you much.
    And from the looks of it you wouldnt have to remove much.
  30. May 14, 2025 at 9:08 PM
    #3300
    solidpoop
    solidpoop New Member
    Kevin
    24 Tundra
    RRW 17x8.5 +25, 315/70/17 Falken AT4W
    Bought these brand new, they look great, but one wheel arrived with blemishes. Contacted RRW support and they said it’s within normal manufacturing specs. Am I crazy for letting this bother me?
    ATV25 likes this.
