General Supercharger Thread
  1. May 9, 2025 at 4:13 PM
    Winks4x4Toy
    Winks4x4Toy New Member
    Maryland
    2015 1794 Super White Tundra
    Bak Flip cover, LED interior lights, American Flag tail gate letter inlays, 20in wheels, full audio system, 12in Android center screen.
  2. May 9, 2025 at 4:16 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    HulkSmurf14 likes this.
  3. May 9, 2025 at 4:28 PM
    centex
    centex New Member
    Where do I buy this shirt?
  4. May 9, 2025 at 5:10 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Scored this on marketplace this afternoon. $350 with a gasket and filter kit. New in box.
    Now to find time to install my 2 post lift and install the shift kit and this.
  5. May 9, 2025 at 6:43 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  6. May 9, 2025 at 6:53 PM
    Winks4x4Toy
    Maryland
    That's my custom shirt!
  7. May 9, 2025 at 6:54 PM
    Winks4x4Toy
    Maryland
    Which shift kit did you get?
  8. May 9, 2025 at 6:58 PM
    VWTim
    Corvallis, OR
    Sonax zip kit with the transgo pressure "valve?" Or whichever they call it.
  9. May 9, 2025 at 7:22 PM
    DbQC
    DbQC New Member
    2009 tundra sr5
    Found a new in-box Trd supercharger and fit kit IMG_3892 2025-05-10 02_20_38.HEIC.jpg IMG_3880 2025-05-10 02_21_08.HEIC.jpg
  10. May 9, 2025 at 7:22 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Boost pressure valve=maintains line pressure
    Good stuff!
    HulkSmurf14 and VWTim[QUOTED] like this.
  11. May 9, 2025 at 7:23 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The fit kit is the bonus find!
    M3Tundra-JK and HulkSmurf14 like this.
  12. May 9, 2025 at 7:25 PM
    VWTim
    Corvallis, OR
    There ya go, it's been on a shelf for like 6 months :)
    Mdl[QUOTED] and HulkSmurf14 like this.
  13. May 9, 2025 at 7:34 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Softball and a heatgun is the best way to do it. That’s how I did mine and took about half an hour but works well and looks stock. Same hardware works too.
  14. May 9, 2025 at 7:48 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Whew, some miles on those boxes though. Nice find.
    AZTundra, Mdl and HulkSmurf14 like this.
  15. May 9, 2025 at 9:52 PM
    AZTundra
    Paul
    Phoenix, AZ
    Thanks for the tip.
    Mdl and Ponderosa_Pine[QUOTED] like this.
  16. May 10, 2025 at 10:50 AM
    mustang67408
    Victor
    Hot dry place in Nevada
    I either use a large prybar and a hammer and tap them off and if they are really stuck,
    I cut them off carefully
  17. May 10, 2025 at 11:04 AM
    mustang67408
    Victor
    Tripleconpanna and Wynnded like this.
  18. May 10, 2025 at 11:16 AM
    centex
    centex New Member
    Been there tried that. Unless you’ve got deep pockets and they are trying to void your window switch warranty because of a supercharger, you are in for a long and expensive fight.
    Wynnded and mustang67408[QUOTED] like this.
  19. May 10, 2025 at 11:45 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    My Toyota dealer did replace my transmission for free several years after they installed the Magnuson 1900, which I thought was pretty cool. Didn’t give me alot of grief over it. Definitely dealership dependent and also if it was installed there likely counts significantly.
  20. May 10, 2025 at 1:16 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Got started on the interchiller installation, cut up the hardline from the condenser to the cabin evap and brazed on the hose fittings. I also replaced my condenser (cracked), and need to replace my compressor (clutch noise).
    HulkSmurf14, Ryuu, Wynnded and 4 others like this.
  21. May 10, 2025 at 7:11 PM
    HTXtundra4x4
    HTXtundra4x4 Texas
    Katy, TX
    2018 SR5 CM MGM
    Not supercharged here, but I follow this thread because I want my tundra to be SC/ed and I enjoy reading about it. Anyways, I do have ARH long tube headers w/ DD exhaust and have been dealing with the idle surge and have been annoyed with it for two years now. I've seen a few posts about how to possibly tune it out, so I've been trying to replicate. So after a few hours, it seems that raising the P/N idle to 875 from 700 seems to have helped quite a bit. Also changed LTFT min idle to 899 to see if it would help but didn't seem to do anything that I'm aware of.
    Disclaimer: I'm no tuner and just trying to figure this shit out myself! With you guy's help of course.
    Will update if anyone is interested.
    snivilous[OP] and koditten like this.
  22. May 10, 2025 at 7:24 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Hell yeah, yes I have the same ARH/DD setup and the idle surge was very annoying/made it seem like the truck was gonna die at idle to other people.
    I did a similar idle rpm increase and been testing that the last few months and agree it seems to help alot. I only see the rpms move a little after warmup (no more huge rpm swings) and isn’t really noticeable audibly. My afr gauge still oscillates alot. If you find any other methods let me know!
  23. May 10, 2025 at 7:32 PM
    HTXtundra4x4
    HTXtundra4x4 Texas
    Katy, TX
    2018 SR5 CM MGM
    I do believe it was one of your posts that I saw about raising the idle rpm so thank you! I just went and cranked it up again and it went back to the same ol' surging shit. Although not as low as almost dying like it was! I don't have an AFR gauge.
  24. May 10, 2025 at 8:22 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    What size collector do you have? @HTXtundra4x4 ? 1 7/8
    Are the primary O2's sitting proud inside the primary tube. Sometimes if they are set too far back it can cause surging as its not reading properly.
    Wynnded likes this.
  25. May 10, 2025 at 8:38 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    Yes 1-7/8” primaries. This is how the collector O2 is setup where it’s angled towards the engine. Does that look right?
    Tripleconpanna likes this.
  26. May 10, 2025 at 9:14 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I believe if the bung height is less than 1/2 inch enough sensor is in the stream. I have my primary O2's in primary 7 and 8 12 inches from the head. It's old school but prevents getting clean air from back pulses in collector. Even though its one cylinder from the primary its supposed to be a true sample. But Keith did the O2 bungs for me back in 2012.
    Wynnded and armyoffoo like this.
  27. May 11, 2025 at 7:03 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Raised my idle awhile back but not for surging. Mine was kicking a code off when coming off the throttle and it would go below the rpm threshold. Sniv upped the idle and no issues. This was probably more so related to dialing in the big TB. Video shows my idle with the ARH headers and Spd catback.
    https://youtube.com/shorts/ydLmMkb8rZI?si=gG-SjBuhSF9jGGEA
  28. May 11, 2025 at 9:22 AM
    HTXtundra4x4
    HTXtundra4x4 Texas
    Katy, TX
    2018 SR5 CM MGM
    Mine are 1-3/4" tubes and the upstream o2's are in the bungs on the primary tubes. The bung on the collectors is plugged for now. I think that is the reason, ARH didn't put them in the right spot on the primary. I've thought about taking it somewhere to have new bungs welded in, but I don't really know who to trust to do that, so thought i would try and tune it out.
    Also, if I hold the RPM at 1500 or so for 15-30 seconds, it will idle normal after that until I shut it off and restart. This is with A/C off. A/C on, seems to idle normal while the compressor is turning.
  29. May 11, 2025 at 9:34 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Thats pretty much where mine are located. Well there goes that theory for the surging idle. You both have them in different spots and different sized collectors.
    I have my idle in P/D raised to 750 rpm for when the e-fan kicks on.
  30. May 11, 2025 at 4:32 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I got the liquid line completed for the Interchiller, now I just need to reconnect everything, tee into the suction line, mount the dryer and interchiller, then connect the lines and draw a vacuum on the system. I also have a pusher fan to mount in front of the condenser that will get activated by the same switch that triggers the solenoid. I will probably get it wrapped up tomorrow. Second picture is a M5 nutsert below the battery tray where the solenoid mounts.
    From the condenser I cut the line about 1.5" after the first bend (would cut it shorter for a more gradual bend in the soft line, first soft line is 4 7/16" to the tee fitting, second soft line is 3 1/16" to the 90 degree into the solenoid, third soft line is 5 5/8" from the 90 degree out of the solenoid into the hard line. I cut the hard line going to the cab about 4 3/4" after the bend.
