General Supercharger Thread
  1. May 9, 2025 at 12:22 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @Downytide the 880's are supposed to be very responsive even with a low duty cycle at cruising rpm.
  2. May 9, 2025 at 12:25 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    That sucks that it may have been an introduced issue. At least your SC will be serviced and in excellent working order.
  3. May 9, 2025 at 12:27 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    I usually introduce my issues, one way or another...fml. What's strange is I installed the spacers in November, and this started last month. I agree, at least the SC will be freshened up.
  4. May 9, 2025 at 12:31 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    It's odd that it shifted at all. You'd notice it rubbing during install no doubt.
    e30cabrio, HulkSmurf14 and Mdl like this.
  5. May 9, 2025 at 12:33 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I’d say you found it my dude! This condition is known as “soft foot” on rigidly mounted rotating equipment. Just worked on aligning a shitty old pump with soft foot today actually.
  6. May 9, 2025 at 12:34 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Yeah, I didn't notice anything when I installed the spacers. The SC seemed to sit flush and I was able to torque the nuts/bolts to spec with no issues, and no vacuum leaks when I smoke tested.
  7. May 9, 2025 at 12:45 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Always frustrated me on the ships aligning pumps...no fancy tools back then.
    e30cabrio and Silver17[QUOTED] like this.
  8. May 9, 2025 at 12:52 PM
    Silver17
    Eastern PA
    The electronic alignment tools make it so much easier for sure. I’ve done it plenty with the dial indicators as well. Not enjoyable.
  9. May 9, 2025 at 12:59 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Maybe it's the staring. :rofl:
  10. May 9, 2025 at 1:12 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    The new laser machines make it stupid simple. Just put a requisition in for an Easy Laser XT770 at work, to supplement the two 660's we have.
    Silver17[QUOTED], HulkSmurf14 and Mdl like this.
  11. May 9, 2025 at 1:37 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Thanks to Sniv, the tree has another 2 years.
  12. May 9, 2025 at 2:00 PM
    centex
    centex New Member
  13. May 9, 2025 at 2:05 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Finished porting my GM snout, need to clean it up by hand since the cartridge rolls aren't getting in far enough. Also removed the vacuum barbs and drilled the holes out to tap for 1/4npt, going to install 6an-1/4npt fittings in place of the barbs.
  14. May 9, 2025 at 2:08 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Looking good! Nice to eliminate any un metered air intrusion
    HulkSmurf14 likes this.
  15. May 9, 2025 at 2:12 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It does move well! I let off on a run when I saw it hit 11.7 afr at 6000rpm. I'm still working on my mindset for going pig rich...baby steps as I've got it to low 11's to high 10's at higher rpm.
    Wynnded, HulkSmurf14 and reywcms like this.
  16. May 9, 2025 at 2:22 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    You still running water/meth as well?
  17. May 9, 2025 at 2:38 PM
    VWTim
    Corvallis, OR
    Who's got a go-to online source for silicone PCV/etc hoses? Trying to stay off Amazon if possible.
    Need 1/2 and 3/8 as the hose Radium provided is getting hard and I'd like to replace before it cracks.
  18. May 9, 2025 at 2:39 PM
    centex
    centex New Member
    I was thinking about it and I’m wondering if it’s a touch lean because it’s scaled for 7psi and if it’s only setting 6psi it might not be adding enough fuel. I could also just be out of fuel but i don’t think so since when it was 15* colder outside and boost was at 6.8-7psi I was dead on 11.4afr.
    Mdl[QUOTED] and HulkSmurf14 like this.
  19. May 9, 2025 at 2:40 PM
    centex
    centex New Member
    https://www.siliconehose.com/
    I’ve used them before with good success.
    VWTim[QUOTED] and HulkSmurf14 like this.
  20. May 9, 2025 at 2:45 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Don't use silicone for the catch can, it's permeable and the oil will seep through and make a mess. Use rubber hoses, like low pressure fuel hose. You should be able to get from a local auto parts store, or summit racing.
    Mdl, e30cabrio, Wynnded and 2 others like this.
  21. May 9, 2025 at 2:46 PM
    VWTim
    Corvallis, OR
    Interesting, my experience with silicone is multilayer in industrial settings. Good to know.
  22. May 9, 2025 at 2:47 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    True statement! Nothing like the ol famous 034 hose seep!
    blenton, Mdl and armyoffoo[QUOTED] like this.
  23. May 9, 2025 at 2:48 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I replaced my catch can hoses with silicone and they were covered in sludge on the outside, nice HPS hoses, wasted money.
    Mdl and HulkSmurf14 like this.
  24. May 9, 2025 at 2:50 PM
    j_supra
    Manitoba, Canada
    2008 Tundra Limited
    20" Vision brawl, 33.5" Toyo at3s, Bilstein 5100s, LTH, custom exhaust, AEM filter, TRD intake pipe, Joying HU, hertz components and sub, Rokblokz XL, AVS visors
    Does this apply to using silicone hoses for coolant as well?
    Mdl likes this.
  25. May 9, 2025 at 2:51 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Coolant is fine, it's the oil vapor and contaminants that seep through.
    j_supra[QUOTED], blenton, Mdl and 3 others like this.
  26. May 9, 2025 at 2:52 PM
    HulkSmurf14
    2014 Tundra Limited
    Just oil.
    j_supra[QUOTED] and armyoffoo like this.
  27. May 9, 2025 at 3:40 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Yes, 70/30(w/m) and spraying at 9psi on up. Getting it dialed in takes a little bit. I was running 10.4afr's and leaned them up to 11 and 10.8ish 5600rpm on up.
  28. May 9, 2025 at 3:44 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    When you run out of fuel you'll know it. The temps play with it a few points but the PE can jump around a little bit.
  29. May 9, 2025 at 4:10 PM
    bflooks
    bflooks New Member
    Metrowest MA
    I'm using Improved Racing and have used Setrab hoses.
    HulkSmurf14 and armyoffoo like this.
  30. May 9, 2025 at 4:13 PM
    Winks4x4Toy
    Winks4x4Toy New Member
    Maryland
    2015 1794 Super White Tundra
    Bak Flip cover, LED interior lights, American Flag tail gate letter inlays, 20in wheels, full audio system, 12in Android center screen.
