General Supercharger Thread
  1. May 8, 2025 at 2:05 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    At a minimum some will install an afr gauge to keep track of their fuel ratio to ensure they are not running lean. It's not required but a safety net to keep an eye on what is happening.
  2. May 8, 2025 at 2:40 PM
    mustang67408
    Victor
    Hot dry place in Nevada
    ^^^^^THIS!!!!
  3. May 8, 2025 at 3:15 PM
    AZTundra
    Paul
    Phoenix, AZ
    Question for those of you with the RCF throttle body and the Magnuson airbox. Will I be able to stretch the intake tube over the RCF throttle body or is there an adapter or tube that I should order in preparation for the install?
    armyoffoo and HulkSmurf14 like this.
  4. May 8, 2025 at 3:17 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It's tight but will fit with a bit of stretching. Just rembering from past post on it.
  5. May 8, 2025 at 3:21 PM
    AZTundra
    Paul
    Phoenix, AZ
    Thanks @Mdl.
  6. May 8, 2025 at 3:26 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That's what I'm running. Maybe a little heat and silicone spray to aid things, or just hawk tuah it.
  7. May 8, 2025 at 4:57 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Yes, I got mine on.
    Wynnded, Mdl and AZTundra[QUOTED] like this.
  8. May 8, 2025 at 5:02 PM
    blenton
    blenton New Member
    That’s pretty much how I got mine on. Might have been a few choice words in the process as well..
  9. May 8, 2025 at 5:12 PM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Interesting...
    Pretty sure their site tells you to only use their certified installers.
  10. May 8, 2025 at 5:51 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Just saw this post, and thought it was worth sharing given the predominant topic as of late. Boost and warranty are on different spectrums. 500 miles on it! Clearly it had a defect out of the box, and no dice on warranty repair.
    mustang67408, Ryuu, armyoffoo and 2 others like this.
  11. May 8, 2025 at 5:58 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    When I spoke with them he was pretty adamant on stating any alterations, pullies, shooting water methanol would void the warranty.
  12. May 8, 2025 at 6:03 PM
    Silver17
    Eastern PA
  13. May 8, 2025 at 6:08 PM
    bflooks
    bflooks New Member
    Metrowest MA
    I'm not really caught up on the support side of the SC community, but in 500 mile no warranty situation above, is that another 8-10k? Or is it a discounted replacement cost since the additional peripherals are already done?
  14. May 8, 2025 at 6:14 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    It depends, it's the very firm 1-2 shift that can make things uncomfortable in stop and go, lock it in 1st gear helps but doing 10mph while doing 3000rpm also sucks....
    alright fellas, I need to swap injectors, I'm 100% these 750cc injectors are causing me all my headache, bought DW 650cc, question is, is this diy-able? I have a fear of injectors swap since many years ago when I was young, a mishap almost burnt my car down.
    HulkSmurf14 likes this.
  15. May 8, 2025 at 6:15 PM
    centex
    centex New Member
    Hate to be that guy but if you modify something you run the risk of voiding the warranty. Not saying it should have failed, just that you pay to play.
  16. May 8, 2025 at 6:17 PM
    centex
    centex New Member
    Very DIY-able and very easy. The blower may make it more of a challenge depending on how much in encroaches on the fuel rail but otherwise its really simple. I was nervous also but it took maybe an hour to swap all 8. Easier than spark plugs.
    HulkSmurf14 and armyoffoo like this.
  17. May 8, 2025 at 6:19 PM
    Silver17
    Eastern PA
    They can be pricks if they want to be, that’s their right and they put it in writing. My point is I wouldn’t expect much out of them as far as warranty coverage. Easy fix, buy a Harrop or Whipple.
  18. May 8, 2025 at 6:20 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Are they five-o 750's? Easy swap just relieve all the pressure. Pull fuel pump fuse and start up to run out and careful when separating fuel line. Ensure o-rings and spacers are seated.
    HulkSmurf14, armyoffoo and Wynnded like this.
  19. May 8, 2025 at 6:21 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I've been leaning towards Harrop if I go bigger. And I only go to 6400rpm.
  20. May 8, 2025 at 6:22 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Not to keep this going but on their website...
  21. May 8, 2025 at 6:23 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I went from the TVS1900 to the TVS 2650, it was ~$5-6k. Some items are reused, some of those modified, and some are new. For example, the top radiator hose is retained, some of the intercooler hoses are reused, but some are unique and were supplied in the upgrade kit.
  22. May 8, 2025 at 6:28 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    DIY for sure, blow out the area with compressed air before removing as there is always dirt/debris in there, and get your tune adjusted.
    Wynnded, HulkSmurf14 and Mdl like this.
  23. May 8, 2025 at 6:33 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    That's some gnarly damage, hopefully the damage was limited to the supercharger.
    Wynnded, Mdl and Silver17[QUOTED] like this.
  24. May 8, 2025 at 6:38 PM
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    Dang, that's crazy. Wonder if the failure was purely because of his mods or if the unit was defective from the get go and his mods just made it fail way, way earlier. Maybe without the mods it would have lasted longer but eventually still failed within the warranty period.
    Wynnded likes this.
  25. May 8, 2025 at 6:45 PM
    centex
    centex New Member
    Or a turbo. They’ll even sell you the parts to up the boost from the cab!
    Selfish jab I know but I couldn’t resist.
    Silver17[QUOTED] and HulkSmurf14 like this.
  26. May 8, 2025 at 6:46 PM
    Silver17
    Eastern PA
    My understanding of TVS superchargers are the bearings are made to last indefinitely at 18,000 RPM (literally never fail) and sure there are cases where they still do. People run them at 24,000 RPM all the time with no issues. He surely wasn’t spinning it that fast on what he describes as a “moderate pulley combo”. The snout bearing retainer appears to have failed, which would cause catastrophic failure at any RPM. Looks to me like a faulty unit that they conveniently decided not to help him out with.
  27. May 8, 2025 at 6:52 PM
    Silver17
    Eastern PA
    You can wait 2-4 weeks for warranty supercharger repair, or 2-4 weeks for your turbo boost to come on. You decide!
    Just joshin.:p At least Jesse would help you out, warranty or not it seems.
  28. May 8, 2025 at 7:10 PM
    blenton
    blenton New Member
    So, water methanol voiding the warranty I can understand.
    Swapping pulleys that keep the blower speed below that 18k rpm threshold - I don’t really understand that voiding the warranty. I would think that as long as the unit design limits aren’t breached, there should be zero issues with it.
    When I reached out to Harrop, they basically told me swapping pulleys was fine for the blower, but might not be good for the motor…
    For those of us that live at altitude other than sea level, a smaller pulley is a necessity just to get stock blower power levels.
  29. May 8, 2025 at 7:15 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Savage.
  30. May 8, 2025 at 7:23 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    This is a good time to point out that the older TRD TVS1900 has a drive design that has much better shaft support. With two bearings giving the drive shaft a ride inside and totally supported by the cast snout prior to the coupler, it’s straight beef. The new larger TVS 2650 has a single bearing out at the pulley, and replies on the rotor pack bearing to support the shaft after the coupler. The TVS 1900 for the 3.5 2GRFKS in the Tacoma has the same less durable design.
    With that said, the newer single bearing design with exposed driveshaft certainly will flow better. It’s also spinning significantly slower to achieve the same or greater flow numbers… but then the rotor pack bearing has a larger heavier rotor, it would be interesting to take a deeper dive and try to factor everything in.
