2020 TRD Pro Suspension Rebuild Advice
Discussion in 'Suspension' started by thecaptain115, May 7, 2025.
  1. May 7, 2025 at 10:11 AM
    thecaptain115
    thecaptain115 [OP] New Member
    2020 Toyota Tundra TRD Pro Double Cab P275/65R18 Tires 72k miles
    I need to get the Fox struts and shocks rebuilt, and have not been successful in finding someone local to do it, so I am going to have to send them off. I am trying to figure out what a good aftermarket option would be that is a direct swap out that maintains the factory TRD Pro ride height and without having to readjust the rest of the suspension components. I looked at buying factory replacements, and its looking to be $4k+. Ideally, these would be rebuildable as well so I can just swap them when needed.
    I don't do any off-roading, so an external reservoir isn't necessary. Are the Fox 2.5 Factory Series Coilovers going to work for what I am trying to accomplish? What about the 2.0 Performance Series Coilovers?
    edit:
    https://www.shocksurplus.com/produc...ir-2007-2018-toyota-tundra-2wd-4wd-883-02-021
    https://www.shocksurplus.com/produc...rs-front-pair-2007-2018-toyota-tundra-2wd-4wd
    What about the rears? I'm open to other brands, I'm just looking for the easiest option to swap out between rebuilds that maintains ride height and doesnt require making a bunch of adjustments.
  2. May 7, 2025 at 12:09 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    I would rent a car while they are being rebuilt. Far cheaper.
    SC SR5 likes this.
  3. May 7, 2025 at 1:02 PM
    thecaptain115
  4. May 8, 2025 at 5:11 PM
    Diesel5610
    Diesel5610 New Member
    Pine City, NY
    2021 Black TRD Pro
    What about Blistein 6112/5160? I thought I have read guys went with that combo and it was a direct swap. I am about ready to do the same with my 2021.
  5. May 14, 2025 at 4:08 AM
    SC SR5
    SC SR5 New Member
    2014 SR5 CM, 2025 Lifted Platinum
    RC coilovers/level shocks , 2014 Factory lift on the 2025 Platinum
    I actually like someone’s idea about renting a car while rebuilding, I think everything you’ve mentioned is a downgrade
    BillyB likes this.
  6. May 14, 2025 at 4:10 AM
    SC SR5
    SC SR5 New Member
    But actually RC 2” coilovers would do well if you need something to install while the foxes are getting done
  7. Jul 27, 2025 at 5:11 PM
    steezy
    steezy New Member
    2021 Tundra TRD Pro
    Anyone done the Fox rebuild? I’m about 15k miles away from needing mine rebuilt and am curious how long people were without their trucks…
  8. Jul 27, 2025 at 5:36 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    On my 2016 I have Eibach adjustable coilovers set at +2" which is TRD PRO height. I like them enough that I have a shop installing Eibachs on my 2025 Tundra tomorrow.
  9. Jul 27, 2025 at 6:27 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    Yes. But I rebuilt them prior to install. If you can find a shop to rebuild them locally, you probably won't be down too long.
    bulldog93 likes this.
