Replacement bed question
Discussion in '1st Gen Tundras (2000-2006)' started by Seepick1, Apr 30, 2025.
  1. Apr 30, 2025 at 11:51 AM
    Seepick1
    Seepick1 [OP] New Member
    VA
    2006 SR5 Double Cab 4.7L
    Just discovered when I removed the plastic bedliner to spray on a liner, that i have some serious rust issues toward the front bulkhead of the bed. Frame is in good shape for now, but now I need to either replace the bed, or attempt to fix this with the limited time I have. Without an infant and a toddler, this would be a fun welding project, but I just don't see how it's possible.
    My question: Found a replacement double cab bed (I have the one without fender flares), but it is listed as a 2WD version. Is there a difference between 2WD and 4WD beds? Both are for a double cab. Thanks in advance
  2. Apr 30, 2025 at 12:44 PM
    rouxster70
    rouxster70 New Member
    04ac2wdv65spd
    My understanding is that dbl cab body same 2wd & 4wd. Check fuel filler door location and mounts to verify those line up. How’s the color difference?
  3. Apr 30, 2025 at 12:45 PM
    Seepick1
    VA
    Oh it is totally different. Silver vs my blue steel metallic. But since I have the model without flares, I'll have to take what I can find
  4. Apr 30, 2025 at 2:09 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    It's too bad you're so far away. I literally just swapped my bed for a new one and am trying to sell my old one, which is blue steel metallic. But there shouldn't be any difference between 2WD and 4WD beds. 4WD stuff is all up front.
    G_unit3000 and Seepick1[OP] like this.
  5. Apr 30, 2025 at 2:17 PM
    Make sure you understand which cab type you have. The Access cab has the 4 doors that the rear doors open clam shell or suicide style only after the front doors are open. The Double cab has the 4 full doors that open independent of each other like normal doors. The beds are not interchangeable between AC and DC trucks. Doesn't matter what drive train you have, all the AC beds are the same and all the DC beds are the same. You can swap your fenders over to the new one.
    G_unit3000 and shifty` like this.
  6. Apr 30, 2025 at 4:49 PM
    Seepick1
    VA
    Yes, I'm fully aware of the differences between the bed for access, double, etc. Here are some photos. The tail lights should be indication enough that it is double cab. My only concern is if there is some weird thing that makes a 2WD bed different. I have the vin number of the bed I'll have to run it through my dealership to double check.
    Also, looks super clean underneath and only surface rust on top
    G_unit3000 likes this.
  7. Apr 30, 2025 at 4:59 PM
    I only mentioned it because you listed yours as a “dual cab”.
    Seepick1[QUOTED][OP] likes this.
  8. Apr 30, 2025 at 5:04 PM
    Seepick1
    VA
    Never noticed that was on my profile. Appreciate the heads up.
    KNABORES[QUOTED] likes this.
  9. Apr 30, 2025 at 5:05 PM
    2wd and 4wd beds are
  10. Apr 30, 2025 at 6:36 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    This one isn’t in quite as good of condition but it’s the same color… just located in Idaho.
  11. Apr 30, 2025 at 6:58 PM
    Seepick1
    VA
    Only issue is that it has the fender flares, which most double cab have. Mine does not, which makes matching the body much more tedious. If it were the same body style, I'd probably inquire about freight shipping. Thanks anyway
  12. Apr 30, 2025 at 7:04 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Too bad. But that’s a good looking truck.
  13. Apr 30, 2025 at 7:08 PM
    Seepick1
    VA
    Thanks! Broke my heart to find the rust under the plastic bed liner. Underneath, it really didn't look bad.
  14. May 1, 2025 at 8:27 PM
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    I presume that you looked into repairing your bed. I've seen a post or two on here showing repairs that looked solid , especially if it is going to be covered up again under a bed liner
  15. May 2, 2025 at 4:24 AM
    Seepick1
    VA
    Yes, that would absolutely be my preferred choice. I have the welding experience to do it as well. What I do not have, however, is the time. The infant and toddler have all of that.
    My plan, however, is to swap beds, and repair my current bed over time.
    Stay tuned for a repaired replacement bed, up for sale.
    But it will probably take me a year at this point lol.
    G_unit3000[QUOTED] likes this.
  16. May 2, 2025 at 9:49 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    So you're also part of the club that wrenches from about 8pm - midnight? And also can't pull out the impact during those hours because it's too loud.
  17. May 2, 2025 at 1:58 PM
    Seepick1
    VA
    It's an exclusive club. Fortunately, I've found that somehow, miraculously, I can run just about any tool (impact, grinder, table saw, circular saw) and no one can hear anything. But yea, after 8pm, if my honey-do list isn't too long
    Kimosabe[QUOTED] and G_unit3000 like this.
  18. May 4, 2025 at 6:45 AM
    Hi06silver
    Hi06silver Fat. Thumbs.
    2006 DC 4x4 Waltrip
    Did you find these at a local pick and pull or car-part.com or something? I can't find shit close to me and have the same issue with having no flares...
  19. May 4, 2025 at 7:56 AM
    Seepick1
    VA
    Found it at an online salvage yard. Had them send me a bunch of pics. Almost decided to wait, but it was a good del and figured i might not ever find another without flares. Good luck. I initially found it on ebay
  20. May 4, 2025 at 8:07 AM
    Same issue @jpink had, IIRC. He eventually found a bed w/o though. It's tough to find, I was keeping eyes out in my area when @FirstGenVol mentioned he needed one, ideally in black. I setup SearchTempest to look and hit www.car-part.com once or twice a week for 3 weeks with no luck.
  21. May 4, 2025 at 8:21 AM
    06dctundy
    06dctundy New Member
    06 DC V8 2WD
    Darrel Waltrip decals removed, soon to be debadged tundra racing rear leaf drop billstien 5100s on 2nd notch flat grey BBS 285/65R18 terra grappler g3
    Where are you located? I would be interested in the silver DC bed if you find another option
    Hi06silver likes this.
  22. May 4, 2025 at 12:42 PM
    Seepick1
    VA
    I'm in VA but I already have an appt to have the new one painted blue steel metallic. I will either fix the old one, in time, and sell it, or sell it as is as a project bed
  23. May 6, 2025 at 10:41 AM
    Seepick1
    VA
    Freight shipment arrived early today. Luckily I had two other guys in hand to lift it off the flat bed trailer.
    Going in for painting, but the under side of this thing is clean as he'll. Almost zero rust. The plan is to coat the bottom it with Eastwood encapsulator and lather with 5th wheel grease before I recount.
    Unless anyone has any suggestions on the best way to prevent any build up of rust underneath. Looking for one and done.
  24. May 6, 2025 at 11:47 AM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I don't know how necessary it is to coat the bottom. If it's in good shape I would maybe just wash in and fluid film it (along with the rest of the truck) once a year.
  25. May 7, 2025 at 6:53 AM
    Hi06silver
    2006 DC 4x4 Waltrip
    While you have it off maybe try and clean out the area where the wheel well and bed side meet with air and spray something up in that area? Sand, small rocks n shit gets up in there and chisels from the inside out over time and rust starts eventually
  26. May 7, 2025 at 7:55 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Are you talking about rust encapsulator or something different? All I know is the rust encapsulator shouldn't be used if the surface isn't rusty.
  27. May 7, 2025 at 11:52 AM
    Seepick1
    VA
    That's good to know. I guess id be in the market for some kind of rust preventative then. Honestly, a good layer of grease seems like the best option.
  28. May 7, 2025 at 12:06 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Fluid Film. Hit the carwash with the undercarriage wash and then spray with fluid film in the fall before the snow falls. That's how I do it every year and no rust.
  29. May 7, 2025 at 12:17 PM
    Seepick1
    VA
    Ive used the fluid film before. Good stuff. For underneath the bed, I'm wanting something that won't wash off after a season. Probably looking at 5th wheel grease
