Ode to FGT; a refresh story
Discussion in '1st Gen Tundras (2000-2006)' started by KNABORES, Jun 20, 2024.
  1. Apr 8, 2025 at 4:12 PM
    #331
    Makes sense. That's how our RAV4 is. Even since new, the AC has always underperformed. On really hot days here I have to use the recirculate button. My truck gets way colder.
  2. Apr 8, 2025 at 4:13 PM
    #332
    KNABORES [OP] Sarcasm incoming
    I use recirc to get the air cooled down and the humidity removed. Otherwise I’m sucking in super humid air constantly.
    Weagle and FrenchToasty like this.
  3. Apr 8, 2025 at 5:30 PM
    #333
    BroHon
    BroHon Bitch in the Mitten
    Bro
    2000 SR5 AC 4x4 4.7
    Sketchy street barnacle
    Like a LandFill in July, same here.
  4. May 5, 2025 at 3:05 PM
    #334
    Got some door sill protectors from Toyota.
    Part number PT747-34010.
    Easy install, prep with alcohol, windex or 3M surface prep. Apply so that it lines up with the pattern on the plastic door sill trim.
    Before
    after
  5. May 5, 2025 at 3:10 PM
    #335
    Driver side. Note the amazing fit of the weather tech mats o_O
    Before
    after
  6. May 5, 2025 at 3:34 PM
    #336
    Weagle
    Weagle I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    looks great. I didn't know Toyota made such a thing
    a little heat won't make that WeatherTech mat lay down? Mine seemed to lay down perfectly on the front
  7. May 5, 2025 at 3:37 PM
    #337
    I'm pretty sure it's been 130 plus degrees in the truck in summer and they haven't relaxed. Have not tried a heat gun or anything though.
    Weagle[QUOTED] likes this.
  8. May 5, 2025 at 3:45 PM
    #338
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    I have he door sill thingies too. Previous owner must have installed em.
    As for my weather techs, I never thought to hit em with my heat gun. Might do that this weekend
  9. May 5, 2025 at 5:28 PM
    #339
    shifty` You can call 1 (800) PP5-1-DooDoo
    It didn't do shit for mine. It just made it ripple.
  10. Jun 3, 2025 at 7:47 PM
    #340
    Falling behind on the rehab documentation. Here’s my Light bar install. Not sure if it will stay here (who am I kidding, it will be there till it gets knocked off). Drilled two holes in the lower bumper brace and used the same hardware I used to mount it to the previous bull bar. Wired it up to come on with the ditch lights. Might separate them into two switches at a later date. May need to add a spacer to the mounting bolts to get it to peek out from under the bumper a little more.
  11. Jun 3, 2025 at 7:49 PM
    #341
    Some jack wagon at the hotel we host trainings at must have backed my truck into some bushes. Thanks.
  12. Jun 3, 2025 at 7:59 PM
    #342
    Big project today. Sound deadening. After finishing my son’s big stereo upgrade, we had about 50sq.ft. of kill mat left over. So I tore into the Tundras interior and starting applying to any panel with appreciable resonance to it. Front and rear doors and rear cab wall got the bulk of it.
    Stripped all the trim, rear seats and factory insulation out
    rear doors got killmat inside the door itself applied to the inside of the outer door panel. This was the most resonant area of the door. The interior framing of the door wasn’t so bad, so it got some applied to the largest open panel areas. Applied some to the flimsy plastic door card / panel too.
    rear cab wall was the worst offender and got lots of killmat. Probably more than it needed, but the exhaust really makes that panel ring.
    Front doors got killmat inside the door shell on the inside of the outer door panel, and it took a lot. About 3 full sheets a piece. The inner door frame was mostly stamped with ridges for stiffness and didn’t have any open flat panel areas to resonate, so it didn’t get any. You can see the killmat through the moisture barrier. Door card got some killmat as well.
  13. Jun 3, 2025 at 8:03 PM
    #343
    FiatRunner
    FiatRunner 2003 rich
    Jack
    Chicago Suburbs/Milwaukee
    Looks great! I really want to do this to my truck. Quieter inside? Noticeably?
    Weagle likes this.
  14. Jun 3, 2025 at 8:05 PM
    #344
    Haven’t driven it yet to hear. Since I had it all torn apart, I got sucked into a new sub box build. Haven’t finished.
  15. Jun 4, 2025 at 7:28 PM
    #345
    Sub box finished today, waiting for the glue and caulk to dry before firing it up. Went ahead and installed it after the finish dried. Will load the sub tomorrow. This has been 15 years in the making. Always wanted to build a box in the storage cubby. This Solabaric 8 is a good candidate. Needs 0.44cuft of airspace. I used caveman math and trial and error to build this box. Old skool with my skillsaw and jigsaw. One 2x4ft sheet of 1/2” mdf, some glue, brad nails, caulk, bedliner and a speaker terminal.
    started with leftover materials from 3 previous speaker boxes and came up with a box that wasn’t using the space very well so it was short on cuft, and it also looked like ass.
    Not that anyone will be able to see it, but I hate doing shitty work, so I grabbed a sheet of mdf and started over. Improved the angles to use more of the space and added a brace to the inside of the box to help with flex since it’s only 1/2” material
    built a “trim piece” of sorts to fill in the space of the opening and flush the speaker to prevent damage when the seat is closed.
    Then pulled all of the pieces and finished them in bedliner.
    BroHon, Weagle, shifty` and 5 others like this.
  16. Jun 4, 2025 at 7:29 PM
    #346
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    Came out awesome! How's it sound?
  17. Jun 4, 2025 at 7:30 PM
    #347
    o_O First sentence of post….
    des2mtn likes this.
  18. Jun 4, 2025 at 7:34 PM
    #348
    455h0le_dachshund
    Rev. Hotdog
    TX...big surprise
    " Sub box finished today, waiting for the glue and caulk to dry before firing it up"
    Bust out the heat gun
  19. Jun 5, 2025 at 5:42 AM
    #349
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    Pro work, my guy
  20. Jun 5, 2025 at 7:44 AM
    #350
    Install complete, interior back together, carpet cleaning at a later date. Sounds great! Better than the other box, which I discovered was smaller than recommended. The box Crutchfield forced you buy with the Solobaric cause they knew you would screw it up.
  21. Jun 5, 2025 at 8:30 AM
    #351
    You need to Edit/Copy/Paste your reply over here: https://www.tundras.com/threads/subwoofer-in-an-access-cab-the-right-way.77900/
    Because you just did it the right way, IMO. Looks better than most.
    On the airspace calculations, did you factor in your stiffener and the driver volume? :D
    (j/k)
    And on the C-field box reference, are you talking about the Q-logic box? They show the volume as 0.7ft³. I went with a pair of 43CWRT8 CompRT8 DVC's and they show the min/max as 0.2ft³ - 1.0ft³ airspace. I'm expecting the bass to be a little on the tight side with only 0.35ft³ per driver, but with how much rock/country/EDM/hiphop stuff I listen to 80% of the time, I'm expecting that to hit just about right.
    If I'm not thrilled with the sound, I may baffle the 2nd hole in the Q-logic and wire the dual-1ohm driver in series for a 2ohm load to a single driver. I specifically went with DVC 1ohm so I'd have the option to play around with loads.
    (Of course, these #s are only for the CompRT I'm referencing above to point out the range, not your driver)
    The Black Mamba likes this.
  22. Jun 5, 2025 at 8:34 AM
    #352
    Also, interesting your picture reveals how the rear door driver sits - apparently firing down directly at someone's pelvis - in the rear seat. I feel like Toyota should've reversed the position to fire up and toward the dome light.
  23. Jun 5, 2025 at 8:44 AM
    #353
    The 0.44cuft is the recommended box size, without driver. Mine is 0.456 minus the stiffener, so should be dead nuts on.
    The Crutchfield box I am referring to is the original box the 8" Solobaric came in when I bought it in 1996 from them after my 10" JL got stolen out of my 1995 S-10. They would not sell the driver without their special box. Which turned out to be only 0.386cuft by my calculations.
    I've looked at that Q-Logic box several times and didn't want to spend the money, or hack into my truck to install it.
    shifty`[QUOTED] likes this.
  24. Jun 5, 2025 at 8:51 AM
    #354
    Yeah, I was sketched about cutting the carpet, specifically, but used an extremely sharp blade and made two precise vertical lines, then rolled the piece of carpet downward so it'd be super-easy to melt a standard patch into the backside and tease the tufts to (hopefully) fully conceal the carpet ever being cut.
    Seeing your install, it makes it pretty clear there's really no way to plop a single shallow-mount 10" in there, at least not without angling the driver so the widest part of the sub's basket lip was sitting lower than the cubby trim ring.
  25. Jul 11, 2025 at 12:05 PM
    #355
    Today’s adventure, new battery terminals.
    The old ones are the factory, they are stretched, deformed, mangled, overloaded and don’t really stay tight around the posts. I’ve added some electrical accessories as well and do not have a distribution block (would be ideal) so I need some extra terminal attachments for those.
    Current state of affairs. Also some corrosion of the battery hold down and the body support beneath the tray.
    Battery removed, cleaned up, water level inspected, terminals test fitted, and placed on the charger while I restore the rusty bits and attach the new terminals to the wiring.
    Hold down and body panel rust remediated and painted.
    Battery reinstalled and cables rerouted. All good now.
    Dustdog, bmf4069, ToyotaDude and 2 others like this.
  26. Jul 11, 2025 at 12:08 PM
    #356
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
    Link, please
  27. Jul 11, 2025 at 12:09 PM
    #357
    Nimitz_
    Nimitz_ LA face with an Oakland booty
    Sam
    Seattle-ish
    06 DC LTD 4X4 4.7 V8
    Which ones did you go with? My battery situation is …terminal :anonymous:
  28. Jul 11, 2025 at 12:12 PM
    #358
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    I've considered buying a set of these battery terminals but then always see a review showing a photo of a cracked terminal made apparently of some sort of pot metal. Maybe these are made of legit metal
  29. Jul 11, 2025 at 12:18 PM
    #359
    Link below, but might wanna wait for the 1 month review or something to make sure they aren’t shit
    https://a.co/d/0j0fTGF
  30. Jul 11, 2025 at 12:24 PM
    #360
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Imma keep it stock
