1st gen manufactured cabin air filter interest
Discussion in '1st Gen Tundras (2000-2006)' started by axtawesomizer, Jul 3, 2023.
  1. Sep 20, 2024 at 4:27 AM
    #61
    G_unit3000
    G_unit3000 New Member
    Gman
    North East
    2005 Tundra DC 4x4
    It's been over a year since you installed this cabin filter. What are your thoughts? Did you swap out the supplied filter for real a MERV8 filter? Is the air speed sufficient with the added resistance?
    KNABORES likes this.
  2. Oct 8, 2024 at 11:37 AM
    #62
    axtawesomizer
    axtawesomizer [OP] ABG
    Alec
    Pullman, WA
    2001 Sequoia SR5 4x4
    It's been fine I suppose. It hurt my airflow but I do think there has been less dust in the cabin. However, I haven't used my truck much this summer - only like 2k miles since April - so I don't have a comparable reference compared to last summer. I never swapped out the filter, and I haven't even removed it since I installed it lol. I probably should do that before it gets cold here.
    G_unit3000[QUOTED] likes this.
  3. Oct 20, 2024 at 11:37 AM
    #63
    Otakutoaster
    Otakutoaster New Member
    WI
    2002 Tundra AC limited Black V8 4wd
    Radio, subwoofer & amplifier, Roll-N-Lock, Cabin air filter,
    If anyone is interested I'm making a filter as well. I'll be selling the model for anyone to print it'll be $6. I'm still printing and testing the fit first. It's designed for merv 7 carbon filter or merv 8. I don't mind if anyone buys the model and prints the part for others for free. I may sell it fully assembled if you don't have a printer. I'll probably try for around $25 free shipping.
    Dakillacore and G_unit3000 like this.
  4. Nov 2, 2024 at 5:59 AM
    #64
    Neo
    Neo New Member
    Alabama
    I'm interested. Is there an actual vendor page for purchase or is everything done offline?
    G_unit3000 likes this.
  5. Nov 2, 2024 at 10:50 AM
    #65
    G_unit3000
    Gman
    North East
    2005 Tundra DC 4x4
    I'm definitely interested. I do not have a 3D printer. I am less interested in filtering out leaves, pine needles, ect and am more interested in removing fine particulate such as road dust or pollen. It appears to me that merv 7 or 8 filters out larger items? I am hoping to be able make an off the shelf air filter to fit this cabin air filter housing
  6. Dec 6, 2024 at 8:23 PM
    #66
    Otakutoaster
    WI
    I wanted to go with higher merv value too but merv 8 already cuts airflow in half. This is a link to the model https://www.printables.com/model/1057824-gen-1-tundra-cabin-air-filter
    You definitely can go with higher merv but it will decrease airflow a lot. So you would definitely want to upgrade the fan.
    Lundy and G_unit3000[QUOTED] like this.
  7. Dec 7, 2024 at 6:25 AM
    #67
    I feel like there’s a balance here guys. The big thing is filtering out the stuff that will clog evap coil or get in the fan and make noise. I’m sure dust removal is important for folks in dusty areas or who live on/drive on dirt roads. But I fail to see how a higher MERV rating is really going to be beneficial. This is a car. Higher filtration = more airflow restriction. At some point you’re sacrificing airflow performance (and potentially hardware longevity, via strain) the higher you go with your filtration. I thought the original point of this was to stop random debris from getting into blower motor and evap coil housing?
    Otakutoaster and G_unit3000 like this.
  8. Dec 7, 2024 at 6:28 AM
    #68
    noahrexion
    noahrexion New Member
    Washington
    2005 4WD DC
    Have any pics of this guy installed?
  9. Dec 7, 2024 at 9:07 AM
    #69
    G_unit3000
    Gman
    North East
    2005 Tundra DC 4x4
    Yea, you are probably correct here when retrofitting a filter using the stock fan/blower motor. I have a 1.5 hr daily round trip commute so I think about breathing in the fine road dust.
    shifty`[QUOTED] likes this.
  10. Dec 7, 2024 at 9:27 AM
    #70
    Otakutoaster
    WI
    That's exactly why I didn't go higher than merv 8 I read what other people experienced and decided to not go higher.
  11. Dec 7, 2024 at 1:49 PM
    #71
    Lundy
    Lundy New Member
    San Diego
    2004 Dual Cab V8, Automatic, 4x4, SR5 w/tow pkg
    Thanks for doing this offer. I would like to download and print one. You have 7 files listed .......Which file do you recommend?
    Thanks again, Tim
  12. Dec 7, 2024 at 2:15 PM
    #72
    Otakutoaster
    WI
    The files are just different tolerances depending on the printer and material. 4 or 8 bumps are just the contact points that fit in the hole where the fan is. I right now am running the middle tolerance with 4 bumps.
  13. Dec 7, 2024 at 8:18 PM
    #73
    Lundy
    Lundy New Member
    San Diego
    Cool, thanks again
  14. Apr 28, 2025 at 12:55 AM
    #74
    Otakutoaster
    WI
    #74
  15. Apr 28, 2025 at 3:58 AM
    #75
    G_unit3000
    Gman
    North East
    2005 Tundra DC 4x4
    Your price is fine @ $30, less than a half tank of gas. I just ordered one. I presume that I can swap out the filter material when needed at a later date.
    #75
  16. Apr 28, 2025 at 11:52 AM
    #76
    Otakutoaster
    WI
    Yes I haven't tried washing it yet, but it should be washable too.
  17. Apr 29, 2025 at 10:21 PM
    #77
    StrawberryBlowpopPrincess
    StrawberryBlowpopPrincess New Member
    2002 sequoia RWD
    If it’s not to much trouble, you should make a video on how to install these. Im sure the sales would go up for people like me who are new to the car world. Im a bit apprehensive on purchasing simply because I don’t know my way around my car like some do on this forum, and im sure it’s easier than what I’m thinking in my head. But itd help ease the anxiety going in, im not too sure if this would even fit a 2002 sequoia but here I am if it does. Thanks
    #77
  18. Apr 30, 2025 at 1:11 AM
    #78
    Otakutoaster
    WI
    I plan on it when I'm not at work. Because if you pull it out in a certain way you could accidentally break it. I really don't want anyone to accidentally break it. As for fitment shifty` might know. But I know the Instagram and Facebook sellers seem to say the fit is the same.
  19. Apr 30, 2025 at 1:54 AM
    #79
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I kept wishing I had one of these while driving across TX, NM and AZ this last week. So much dust.
  20. Apr 30, 2025 at 3:22 AM
    #80
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    There are many other videos out there since these filters came out but this Sequoia video should help ya. It's also applicable to our Tundras.
  21. May 2, 2025 at 8:58 AM
    #81
    DJ_JimmyJam
    DJ_JimmyJam New Member
    Jimmy
    2000 Tundra AC 2WD
    Bone Stock
    Putting this on the list of things to purchase in the near future. It would be nice to cut down on all the xtra dust. Has anyone seen a decrease in windage with AC or outside air with these in place?
  22. May 3, 2025 at 11:58 AM
    #82
    Otakutoaster
    WI
  23. May 3, 2025 at 12:09 PM
    #83
    G_unit3000
    Gman
    North East
    2005 Tundra DC 4x4
    I received the filter Thursday and I am getting on this right now. Will update. Thanks!
  24. May 3, 2025 at 7:30 PM
    #84
    G_unit3000
    Gman
    North East
    2005 Tundra DC 4x4
    First off, thank you @Otakutoaster for making a product for the FGTs.
    I am going to send a DM with some questions.
  25. May 3, 2025 at 7:38 PM
    #85
    Otakutoaster
    WI
    It takes a bit of force to push it in and make it flush. Go around the lip with you fingers and make sure there's no gap Even the tiniest gap will make it rub the fan. Also Even if you hear it clip on the first push. Push around the entire perimeter until no more clipping sounds.
  26. May 3, 2025 at 7:41 PM
    #86
    Otakutoaster
    WI
    It's dark out but I'll make another video with sound real quick.
  27. May 3, 2025 at 8:02 PM
    #87
    G_unit3000
    Gman
    North East
    2005 Tundra DC 4x4
    I just sent a DM. I will give it another go tomorrow. No rush. It's probably just my own issue trying to get it to seat properly. Don't feel like you have to rush out.
  28. May 4, 2025 at 1:50 PM
    #88
    G_unit3000
    Gman
    North East
    2005 Tundra DC 4x4
    Success!
    I just reinstalled the cabin air filter and made certain that the printed holder "snapped" into the opening above the blower. When I tested the fan on my climate control, the blower is functioning well and the blades are obviously clearing the printed filter holder. Yesterday when I attempted to install, I didn't get the solid snap that I got today. It requires more force than I initially used, not an extreme amount but more than I initially thought was necessary. Thank you!
