Toyota OEM TRD Front Recovery Hooks
Discussion in '3rd Gen Tundras (2022+)' started by RatPanda, Nov 12, 2024.
  1. Apr 29, 2025 at 9:41 AM
    #361
    sudobash
    sudobash New Member
    Headlights are not the Premium LED Headlights.
  2. Apr 29, 2025 at 10:19 AM
    #362
    Breckler23
    Breckler23 New Member
    Georiga
    2025 Limited TRD OR Black
    is that the 4 bulbs vs 2?
  3. Apr 29, 2025 at 10:40 AM
    #363
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Looks like a Platinum (Smoke/black chrome) mustache too. But his info says its a 24 Limited Hybrid
  4. Apr 29, 2025 at 1:23 PM
    #364
    Derfla
    Derfla MUDBATH PRO
    2025 TRD PRO
    Mine just shipped. Glad it didn’t get canceled. Modern Toyota had free nationwide shipping. $525 shipped.
    Blufin, sudobash and Delray like this.
  5. May 2, 2025 at 7:19 AM
    #365
    Derfla
    Derfla MUDBATH PRO
    2025 TRD PRO
    Installing my hooks this weekend. Would removing/loosening the lower mustache on each side make the side tabs come easier?
    I went underneath last night and see how the bottom and top tabs pop out and was very simple. The sides do look wedged in there. From a video I watched the side tabs are between the fascia coming out and the bottom mustache.
    How long did it take those who have installed the kit to remove those side tabs?
  6. May 2, 2025 at 7:46 AM
    #366
    Derfla
    Derfla MUDBATH PRO
    2025 TRD PRO
    how did you trim the side tabs? Snip the middle or snip everything exposed from the back side? I may just do this because there are like 20 other tabs lol
    sudobash likes this.
  7. May 2, 2025 at 9:12 AM
    #367
    Calif-Tundra
    Calif-Tundra New Member
    Bob
    2023 Tundra Limited TRD
    I just pulled the valance cover off by bending the middle section out first. The pop off one side then the other came right off. I trimmed the two tabs after the valance was off before putting it back on. You could also just use a screw drive and break them off from behind I would think.
    Yeah with all those tabs the valance is NOT going anywhere.
    Good luck!
    sudobash and Derfla[QUOTED] like this.
  8. May 2, 2025 at 9:15 AM
    #368
    eddiefromcali
    Eddie
    100% Stock
    I did the same...bent it and slid out. Clip tabs off before re-installing and Bob's your uncle
  9. May 2, 2025 at 9:37 AM
    #369
    Derfla
    Derfla MUDBATH PRO
    2025 TRD PRO
    Thanks fellas! Makes me feel like I can knock it out even faster now.
    Do you guys think if I snip them with dikes from behind will work?
    the kit comes with a new valance so I don’t think I’ll ever go back to stock unless I sell the truck.
  10. May 2, 2025 at 10:31 AM
    #370
    eddiefromcali
    Eddie
    100% Stock
    IDK if it'll make removing any easier...its a must for reinstall w/o removing the front end though.
    Do it
  11. May 2, 2025 at 10:51 AM
    #371
    Derfla
    Derfla MUDBATH PRO
    2025 TRD PRO
    Sounds good! Appreciate the advice!
  12. May 2, 2025 at 8:52 PM
    #372
    Calif-Tundra
    Bob
    Yes I had to clip the tabs on the new one. Fit perfect and not going anywhere.
  13. May 3, 2025 at 10:26 AM
    #373
    Derfla
    Derfla MUDBATH PRO
    2025 TRD PRO
    So I got bored and decided to pop that lower trim while I patiently wait for FEDEX lol. I was surprised… Popped right off. Took 2 minutes lol. Hopefully that was the hardest part of the install.
    Here’s a pic of the tab snipped off the old trim. Going to do the same to the new one. Appreciate all the advice!
    Delray, MAC25Tundra, TheDo114 and 2 others like this.
  14. May 4, 2025 at 11:40 AM
    #374
    motogon
    motogon New Member
    2024 Tundra Limited Wind Chill Pearl
    For me, it was. Took me around 30 minutes to take original panel off. My truck has air dam, that wasn't helping. Bolt on part was easy. Installing new panel took around 10 minutes, mostly trying to put side tabs in place. Weather was hot, I guess it helped as plastic was flexible enough. I didn't cut anything.
  15. May 4, 2025 at 1:11 PM
    #375
    Delray
    Delray New Member
    '23 Tundra Capston
    S&B CAI
    I installed mine yesterday and did not cut off any tabs (or cut anything). The two body-colored blocks at the bottom of the mustache / either side of the popped off fine for me. I did not take them off fully to pop the new piece in. I think it helps to have a lot of light beneath vehicle so you can see and release tabs as needed. Also, it seemed to me the tape was not necessary, as I just rotated the hooks as they went through the valance
    Derfla likes this.
  16. May 4, 2025 at 4:31 PM
    #376
    Derfla
    Derfla MUDBATH PRO
    2025 TRD PRO
    My two mustache bottoms also popped out when I took the old valance off. I ended up not trimming the tabs on the new valance as well because they went right in. I also didn't use any tape.
    Delray[QUOTED] likes this.
  17. May 10, 2025 at 7:43 AM
    #377
    Osolemio
    Osolemio New Member
    24 Limited Hybrid
    It's just the TRD Pro version of the front light bezel. I actually prefer the flat black non-TRD version but couldn't find in stock anywhere
    Breckler23[QUOTED] likes this.
  18. Jun 4, 2025 at 11:47 AM
    22Tuns
    22Tuns New Member
    Dave
    2022 Tundra SR5 Crewmax 5.5
    Just finished installing the recovery points on my 2022 TRD 4wd crewmax.
    Thanks to all who have contributed to this thread on their experience with the kit, especially lavey and Chad 47. The posts from those who have installed the kit were really helpful in understanding what actually needs to be removed and trimmed, or not.
    My experience was that I did not need to trim anything. Neither the lower valance nor the air dam required any trimming. I mounted the new pieces and left them slightly loose, then I held up the new valance, centered the mounts, and tightened the mounting bolts. I had plenty of clearance to the bottom plastic piece that backs up the lower valance. Their was no interference with the air dam.
    I used a pair of ramps to raise the front end up for easy roll around access underneath.
    As others have reported, I also did not have to remove any panels other than the lower valance. First, I removed the two center 10mm air dam bolts, which allows the air dam to drop down. Then I removed the 10mm pivot bolts on each side of the air dam, and set it aside. After the air dam was removed, I was able to remove the two phillips head screws in the trim on either side, and then I gently disengaged each corner plastic. Each one loosened pretty easily. I didn't remove them, just flexed them out of the way when removing the valance. The valance was held in place with little clips along the bottom, side, and top edges. After I got the bottom and sides released, I could reach up and release the top edge, and remove the valance. Last, I removed the 4 bolts holding the bottom cover under the oil pan (I don't have a bash plate).
    Mounting the new components was easy. Do as the instructions say and support the center of the sway bar with a floor jack and it will be easy to remove and replace the mounting bracket bolts on either side.
    The only quirk I saw in the instructions was the inclusion of 8 "extra" washers. They are not called out in the parts list, but the instructions have a reference to including them in mounting the new bracket for the hooks to the bumper bracket.
    Installing the kit didn't require any special tools. I used a ratchet, power ratchet, and impact gun and a torque wrench. I think I used 10, 12, 14, 16, and 17 mm sockets, long and short phillips screwdrivers, and a long flat blade screwdriver and pair of pliers to bend the tabs on the front of the sway bar mounting bracket out of the way.
    I was kind of dreading this install as I did not have any prior experience with the front end plastics. It wasn't that bad. All in all, it took about 2.5 hours start to finish.
    It took less than a half hour to figure the mounting out and remove the existing valance. Next time, it would take about 10 minutes.
    The first set of recovery point mounting bits took about 15 minutes to install as I figured out what went where. For the pieces which have a left and right, they are marked LH and RH for easy identification. The second set took about 5 minutes.
    Replacing the plastics was pretty easy. Be sure to get the corners of the new valance behind the corner pieces prior to reseating those. I ended up losing one clip from a corner when I tried to bend it a little too far, but there are lots of clips, and this one will not be missed. :rofl:
    I like this kit much better than any of the aftermarket alternatives I looked at. The pieces are substantial castings, and the front valance looks great. The kit replaces the sway bar mounts with a substantial casting. The recovery point is a heavy casting that "hooks" over the new front bolt of the new sway bar mount, and has further support from the replacement bumper backer to frame bracket (see pic below). Be sure to put the black washer on this bolt when mounting. The "D" rings are substantial pieces as well. I won't be letting them dangle out front, but if I ever need them, I'll attach them.
    All in all, not a bad job and does exactly what I want - provides a secure set of points to hook onto should I ever need to pull, or be pulled.
  19. Jun 4, 2025 at 5:54 PM
    #379
    Calif-Tundra
    Bob
    After installing this on my 2023 Limited, I’m bummed it will NOT work on my 2024 Platinum with the Factory 3” lift.
  20. Jun 4, 2025 at 8:22 PM
    #380
    Keeptipsup52
    Keeptipsup52 New Member
    22 SR5 TRD OR
    Got the kit installed while the truck was in for heart surgery.
    holy they didn’t mess around with the shackles. I’ll probably opt for the Reno ones others here have done.
    now I just need to figure out the license plate. Unfortunately need it where I live. may try the 3d printed one shared on the forum.
    Blufin likes this.
  21. Jun 5, 2025 at 5:39 AM
    #381
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 Capstone
    My kit will arrive today, when I get home and open it I'm bringing to my local paint shop to get the valance done.
    Hopefully it will be only a couple of days and then it's off for a layer of PPF and when it's all said and done I can do the install and swap...
    Super stoked can't wait.
    75tranzam likes this.
  22. Jun 5, 2025 at 5:58 AM
    #382
    tbird462002
    tbird462002 New Member
    2025 Tundra Limited TRD
    Will this fit with sway bar drop brackets?
  23. Jun 5, 2025 at 7:35 AM
    #383
    22Tuns
    22Tuns New Member
    Dave
    The OEM brackets and bolts are designed for the stock height - not for lifted trucks. They won’t work on the TRD OEM lifted model.
    Calif-Tundra likes this.
  24. Jun 5, 2025 at 7:52 AM
    #384
    sudobash
    sudobash New Member
    Nope.
  25. Jun 5, 2025 at 10:23 AM
    #385
    Calif-Tundra
    Bob
  26. Jun 5, 2025 at 1:47 PM
    #386
    Blufin
    Bob
    Cape Cod,MA.
    23 Capstone
    Just dropped off the valance for color match hopefully will get it back the tail end of next week.
  27. Jun 5, 2025 at 2:21 PM
    #387
    Crawldad
    Crawldad New Member
    2024 Tundra Limited TRD OR w/3” Lift
    Unfortunately the AFE tow hooks are not compatible with the factory 3” liftIMG_2666.png
  28. Jun 5, 2025 at 7:57 PM
    #388
    Calif-Tundra
    Bob
    Well bummer!
  29. Jun 6, 2025 at 4:18 AM
    #389
    tbird462002
    Looks like I'm going to have to weld up my own set of hooks that work with the lift
    Blufin likes this.
  30. Jun 6, 2025 at 7:02 AM
    #390
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    Do we just need longer bolts if we have a swaybar drop kit?
