How-to guide for converting your 2007-2013 Tundra to Full Time AWD capability
Discussion in 'Performance and Tuning' started by ViktorG, Oct 8, 2019.
  1. Jan 15, 2025 at 5:28 AM
    #181
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Correct. FWIW I almost never lock the T-case, my truck is street orientated, I don't off-road it.
    blenton[QUOTED] likes this.
  2. Jan 15, 2025 at 8:13 AM
    #182
    LILTRD
    LILTRD New Member
    East Bay, California
    2013 Tundra SC'D AWD RCSB
    Supercharged All Wheel Drive Lighting Suspension/Air bags Wheels/Tires Audio Center Console swap
    Correct spring under and additional lowering with shackle position.
    Wynnded[QUOTED] likes this.
  3. Jan 15, 2025 at 10:15 AM
    #183
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Post 163 has a decent wiring diagram for the Sequoia switch.
  4. Jan 15, 2025 at 6:54 PM
    #184
    blenton
    blenton New Member
    Thanks. I pulled that down the other night but it disappeared in to the aether somewhere on my machine.
    Truck is at my buddy's shop tonight, thawing out. We'll pull the driveshaft in the morning to get it shortened, then swap transferases. Then I'll tackle the wiring :)
    Wynnded likes this.
  5. Jan 22, 2025 at 2:17 PM
    #185
    ViktorG
    ViktorG [OP] Lexus/Toyota Master Tech
    Viktor
    Calgary, Canada
    2010 RCSB and 2008 DCLB
    World's fastest supercharged Tundra - 2010 RCSB - 10.8 @122 - All wheel drive conversion, lowered, supercharged 2008 DCLB - All wheel drive conversion, 13" lift on 37's
    My truck has a 4" rear drop and 2 leaves out of the leaf springs. I ran into an issue with the driveshaft bottoming out and had to take a little bit of the spline portion off to be safe. I also had the driveshaft hitting the crossmember, so cut it out and welded an ugly but functional square tube brace there. Also was hitting the bottom of the cab, so had to notch that a little bit as well. But my truck is very low, you most likely won't have those issues.
  6. Jan 22, 2025 at 3:03 PM
    #186
    blenton
    blenton New Member
    Transfer case is swapped - woohoo! But driveshaft is stuck at the machine shop. Was supposed to be ready Monday but the guy doing it was sick the last couple of days (small mom and pop shop). Hopefully it will be ready tomorrow.
    As for the front driveshaft, the boot over the splines appears to be cracking as we stretched it out. We still haven’t stretched it all the way. Anybody know if that boot is user serviceable?
    Bearings for the rear diff didn’t show up until today, so it’s still got some time on the lift.
    M3Tundra-JK, Wynnded and snivilous like this.
  7. Jan 25, 2025 at 11:12 AM
    #187
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Just loosen one of the clamps on the boot and move that end to a more neutral location.
  8. Jan 25, 2025 at 11:17 AM
    #188
    blenton
    blenton New Member
    Thanks. I’ll give that try.
    I picked up the driveshaft at 4:59pm yesterday. They were very apologetic for the delays and gave me an unsolicited discount on an already low price. Small mom and pop shop, and I completely understand the delays. It happens.
    The case is in and buttoned up, just need to install the 4wd ecu and see how it rolls!
    Mdl and Wynnded[QUOTED] like this.
  9. Jan 25, 2025 at 3:15 PM
    #189
    blenton
    blenton New Member
    It’s in, it runs, and it’s smooth. I like it.
    Does this make me the first AWD Whipple-charged tundra? :D
    Yes, I see the irony of being 7 years late to the AWD party…
    I snuck the 4wd ECU out and installed the sequoia unit without pulling the dash apart. There’s just enough rough to sneak a 1/4” drive 10mm deep socket on a stubby driver underneath the dash. When I wire in the momentary switch, I’ll pull it back in to the shop and pull it all apart.
    I drove around town in 4hi on basically dry roads, turning around in parking lots with zero binding. Fabulous. Like driving my sequoia, but angrier… :) Can’t believe it took me so long to get this installed :frusty: As many have said, it should have come from the factory this way. 1000000% happy so far.
    BenAZ, M3Tundra-JK, Wynnded and 3 others like this.
  10. May 2, 2025 at 12:20 PM
    #190
    TunaDr
    TunaDr New Member
    2007 Tundra
    I joined to see what is possible
    To piggy back off this question, if I dont care to do the lockers, what electrical wiring will be needed to be done? I got a 26ft boat and would like the awd option to get up the ramp in case its slippery. I dont off road.
    Mdl likes this.
  11. May 2, 2025 at 3:04 PM
    #191
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    None. Just swap out to sequoia 4wd ecu/ shorten drive shaft and your good to go.
    Wynnded and TunaDr[QUOTED] like this.
  12. May 2, 2025 at 3:17 PM
    #192
    TunaDr
    TunaDr New Member
    2007 Tundra
    Oh and sorry im coming from 2wd. The switch that goes to 4lo 4hi, is there a plus behind my coin holder that's ready to go? Also is there a plug for the 4wd ecu already there?
  13. May 2, 2025 at 3:48 PM
    #193
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Is your Tundra 4wd already?
  14. May 2, 2025 at 3:51 PM
    #194
    TunaDr
    TunaDr New Member
    2007 Tundra
    Nope 2wd
  15. May 2, 2025 at 4:00 PM
    #195
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It won't work and will cost some $$$ to convert front end etc.
    This is for converting 4wd to awd as the Sequoia employs a torsen transfer case that bolts up to the ab60.
  16. May 2, 2025 at 4:15 PM
    #196
    TunaDr
    TunaDr New Member
    2007 Tundra
    Ooooh okay, darn it.
    Mdl[QUOTED] likes this.
