Replacement bed question
Discussion in '1st Gen Tundras (2000-2006)' started by Seepick1, Apr 30, 2025 at 11:51 AM.
  1. Apr 30, 2025 at 11:51 AM
    Seepick1
    Seepick1 [OP] New Member
    VA
    2006 SR5 Double Cab 4.7L
    Just discovered when I removed the plastic bedliner to spray on a liner, that i have some serious rust issues toward the front bulkhead of the bed. Frame is in good shape for now, but now I need to either replace the bed, or attempt to fix this with the limited time I have. Without an infant and a toddler, this would be a fun welding project, but I just don't see how it's possible.
    My question: Found a replacement double cab bed (I have the one without fender flares), but it is listed as a 2WD version. Is there a difference between 2WD and 4WD beds? Both are for a double cab. Thanks in advance
  2. Apr 30, 2025 at 12:44 PM
    rouxster70
    rouxster70 New Member
    04ac2wdv65spd
    My understanding is that dbl cab body same 2wd & 4wd. Check fuel filler door location and mounts to verify those line up. How’s the color difference?
  3. Apr 30, 2025 at 12:45 PM
    Seepick1
    VA
    Oh it is totally different. Silver vs my blue steel metallic. But since I have the model without flares, I'll have to take what I can find
  4. Apr 30, 2025 at 2:09 PM
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    It's too bad you're so far away. I literally just swapped my bed for a new one and am trying to sell my old one, which is blue steel metallic. But there shouldn't be any difference between 2WD and 4WD beds. 4WD stuff is all up front.
    Seepick1[OP] likes this.
  5. Apr 30, 2025 at 2:17 PM
    Make sure you understand which cab type you have. The Access cab has the 4 doors that the rear doors open clam shell or suicide style only after the front doors are open. The Double cab has the 4 full doors that open independent of each other like normal doors. The beds are not interchangeable between AC and DC trucks. Doesn't matter what drive train you have, all the AC beds are the same and all the DC beds are the same. You can swap your fenders over to the new one.
    shifty` likes this.
  6. Apr 30, 2025 at 4:49 PM
    Seepick1
    VA
    Yes, I'm fully aware of the differences between the bed for access, double, etc. Here are some photos. The tail lights should be indication enough that it is double cab. My only concern is if there is some weird thing that makes a 2WD bed different. I have the vin number of the bed I'll have to run it through my dealership to double check.
    Also, looks super clean underneath and only surface rust on top
  7. Apr 30, 2025 at 4:59 PM
    I only mentioned it because you listed yours as a “dual cab”.
    Seepick1[QUOTED][OP] likes this.
  8. Apr 30, 2025 at 5:04 PM
    Seepick1
    VA
    Never noticed that was on my profile. Appreciate the heads up.
    KNABORES[QUOTED] likes this.
  9. Apr 30, 2025 at 5:05 PM
    2wd and 4wd beds are
