2013 Sequoia Limited to TRD FAUX build now with BOOST!
Discussion in 'Sequoia Builds' started by e30cabrio, Apr 19, 2021.
  1. Apr 14, 2025 at 5:26 PM
    #1711
    e30cabrio
    e30cabrio [OP] I'm e30cabrio, I'm a modaholic
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Another bad tune on a supercharger.
    Nice hood!
    M3Tundra-JK likes this.
  2. Apr 15, 2025 at 7:07 AM
    #1712
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Dang. I'll probably just leave the M3 engine alone. All I've done to it so far are adding a larger Mishimoto oil cooler, and e-fan conversion.
    I like that vented hood a lot better than almost every other option. A lot less aggressive looking than the GTR hood. That one just doesn't look right on a convertible.
    e30cabrio[QUOTED][OP] likes this.
  3. Apr 16, 2025 at 11:01 AM
    #1713
    e30cabrio
    Don't blame you.
  4. Apr 16, 2025 at 12:05 PM
    #1714
    M3Tundra-JK
    Scott
    2005 GX470
    I do recommend the oil cooler though! It's twice as large as the original, and it did bring my engine temp down a little. Also had the radiator replaced with a new OEM. These years are notorious for running hot. Not surprising with an 8k rpm redline
    e30cabrio[OP] likes this.
  5. Apr 16, 2025 at 12:12 PM
    #1715
    e30cabrio
  6. Apr 16, 2025 at 12:14 PM
    #1716
    M3Tundra-JK
    Scott
    2005 GX470
  7. Apr 17, 2025 at 11:46 AM
    #1717
    e30cabrio
    Head will be ready tomorrow, block Monday or Tuesday, I got lucky, he found one for 350.
    Water and methanol starting to go in.
    Tapped the intake elbow for the injection nozzle.
    Based the location on the only picture from the elbow's perspective I had.
    Test fit the pump & reservoir.
  8. Apr 25, 2025 at 6:13 PM
    #1718
    e30cabrio
    New block & head picked up by the builder, he will assemble it this weekend.
    M3Tundra-JK and AZTundra like this.
  9. Apr 27, 2025 at 11:18 AM
    #1719
    e30cabrio
    Opened bank 1 valve cover, looks great to me. (has 100% loss on leak down in piston1)
    M3Tundra-JK and armyoffoo like this.
  10. Apr 27, 2025 at 11:22 AM
    #1720
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Damn that's clean. Looks like the valves are still in place, held by keepers to the retainers. Do you see or hear anything when rotating it over with a socket on the crank pulley?
  11. Apr 27, 2025 at 11:39 AM
    #1721
    e30cabrio
    143k, I got it a 120. I took very good care of it & it was dealer servivced every 5k for 90% of it's life.
    That is why I was very surprised when it failed & also is why I feel like a light reconditioning will be ok. (for the less than 20k miles that I need)
    armyoffoo likes this.
  12. Apr 27, 2025 at 12:26 PM
    #1722
    armyoffoo
    armyoffoo Member
    Cypress, TX
    That motor I bought supposedly had 170k and looks like it's had 3 oil changes. I've never seen that much oil caked on anything...it's a disaster. I was amazed the bearings and journals look as good as they do.
    Mdl likes this.
  13. Apr 27, 2025 at 12:49 PM
    #1723
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, DIY Traction Bars, Tuning by snivspeedshop.com
    One thing to think about...what is the brass fitting, iat temp? Depending on direction of flow the W/M can cool the probe and give a false reading. But either direction it looks close and could skew readings.
  14. Apr 27, 2025 at 1:28 PM
    #1724
    e30cabrio
    I haven't rotated it, I will & report.
    The brass fitting routes vacuum to the ICV (IDLE control valve) it's a stupid ancient OBD1 POS that the car needed to idle properly, I need to ask the tuner of the MAP sensor based stand alone needs it I'd love to get rid of it.
    Due to under hood clearances, that was the only place/angle to put the nozzle and have it facing into the TB which the tuner said was critical.
  15. Apr 27, 2025 at 1:46 PM
    #1725
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'm sure it's all good. I just wanted to point out that w/m can give false temps if sprayed on a iat sensor.
  16. Apr 27, 2025 at 2:04 PM
    #1726
    e30cabrio
    I appreciate the input, thanks
    Mdl[QUOTED] likes this.
  17. Apr 27, 2025 at 5:10 PM
    #1727
    e30cabrio
    Installed the ECB-1 on the left side. Upper left side is bank 2 (driver side) afr, upper right peak boost. I did not install it's fuel sensor as I have that on the ECF-1 on the right side so can't have any of the fuel related info so both bottom gauges are real time boost
    The ECF-1 on the right gauge has bank 1 afr, ethenol % fuel pressure and temp
    https://vimeo.com/1079198159?share=copy
  18. Apr 27, 2025 at 5:58 PM
    #1728
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Just to clarify bank 1 is drivers side and bank 2 is passenger side.
  19. Apr 27, 2025 at 6:51 PM
    #1729
    e30cabrio
    Guess I have been thinking of them backward. The gauges are connected to the side that I'm looking at from the seat, ECB is on the left, ECF right.
  20. Apr 28, 2025 at 11:15 AM
    #1730
    e30cabrio
    Opened the driver side valve cover, looks the same.
  21. Apr 30, 2025 at 5:43 AM
    #1731
    e30cabrio
    Moving forward again!
  22. Apr 30, 2025 at 10:59 AM
    #1732
    e30cabrio
    The old Sequoia motor apparently had a ton of oil blowing through piston 2, the clean one is 1.
  23. Apr 30, 2025 at 11:03 AM
    #1733
    armyoffoo
    armyoffoo Member
    Cypress, TX
    What's the part with the engraved numbers on it?
  24. Apr 30, 2025 at 11:57 AM
    #1734
    e30cabrio
    I think it is a valve, I can't get the piston to go much lower, I have the upper left side bolt through the starter gear ring as I could not get it lined up. I plan to pick it up off the stand & move it.
