2019 tundra 38 gallon tank.
Discussion in 'General Tundra Discussion' started by Doz3r, Apr 17, 2025.
  1. Apr 28, 2025 at 3:28 PM
    #61
    2mchfun
    You're right, hydroplaning on slick tires didn't happen because I changed them preemptively. It happened because of several factors, one of which was my failure to have adequate tread depth on my tires during a time when conditions were unsafe. Hope you feel better now!
  2. Apr 28, 2025 at 4:04 PM
    #62
    blenton
    blenton New Member
    Uhhhh… semi truck passing on the shoulder within inches, other truck passing in the left lane, at 75 mph… maybe I wasn’t dramatic enough?? That was one of the times in life I wasn’t sure if I was going to make it out the other side. Similar experiences in life I would compare it to include such things as: malaria in a 3rd world country without access to healthcare, meningitis, rock strike on exposed face of the grand Teton..
    2mchfun likes this.
  3. Apr 28, 2025 at 5:59 PM
    #63
    seydou
    seydou Distinguished Member
    Almost being hit by a truck is not the same as almost dying. Nothing actually happened. Even a near miss is still a miss.
    I too have had malaria, three times. First time I did almost die. Categorically different than something that almost happened.
  4. Apr 28, 2025 at 6:55 PM
    #64
    smokint
    smokint New Member
    Is this standard on most car fuel pumps? I never gave it much thought (my 38 g Tundra takes 29 g when says empty)
  5. Apr 28, 2025 at 10:00 PM
    #65
    blenton
    blenton New Member
    Booker, 2mchfun and PermaFrostTRD like this.
  6. Apr 29, 2025 at 3:39 AM
    #66
    Bammer
    Monroe, CT
    My old loved me, as well as it's recall replacement.
    vtl[QUOTED] likes this.
  7. Apr 29, 2025 at 3:41 AM
    #67
    Bammer
    Monroe, CT
    It does send a Christmas card every year, so I'm taking it that I am on the plus side of affection ! :hearteyes::rofl:
    2mchfun[QUOTED] likes this.
  8. Apr 29, 2025 at 3:58 AM
    #68
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Yes, they all look pretty much the same way.
    smokint[QUOTED] likes this.
  9. Apr 29, 2025 at 8:13 AM
    #69
    seydou
    Brilliant retort!
  10. Apr 29, 2025 at 8:17 AM
    #70
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
    Not for a column shift apparently? I could not get the large tank with the column shift when ordering new? Referring to a 21 model SR 4x4 longbed
  11. Apr 29, 2025 at 9:05 AM
    #71
    PermaFrostTRD
    Northern NY
    Read the bold/underlined parts of your first quoted post out loud. See if just one single synapse fires.
    If not, don't worry about it.
    blenton likes this.
  12. Apr 29, 2025 at 12:41 PM
    #72
    seydou
    So in your mind, almost being hit by a truck(which btw happens every time you are on the shoulder of a road or at an intersection) is the equivalent near death experience as actually contracting a life threatening illness. Got it.
  13. Apr 29, 2025 at 2:48 PM
    #73
    2mchfun
  14. Apr 29, 2025 at 7:08 PM
    #74
    blenton
    blenton New Member
    Correct.
    I believe the logic from the factory went something like this: either pick the additional weight of the column shift (which comes with an additional seat and increased possible occupancy number of 6) or the added weight of 13 gallons of fuel. But you can’t have both.
    My ‘21 DCRB TRD has the larger tank but no column shift. Weight savings seems to be the popular idea as to why you can’t opt for both, but in reality that doesn’t make a huge difference. My truck empty and stock scaled WAY lighter than the payload curb weight would suggest, even with me in it and a full tank of gas.
    Lifer[QUOTED] likes this.
  15. Apr 30, 2025 at 3:09 AM
    #75
    PermaFrostTRD
    Northern NY
    No, you almost got it.
    blenton likes this.
  16. Apr 30, 2025 at 7:16 AM
    #76
    seydou
    LOL If you can't defend your position, just say so.
  17. Apr 30, 2025 at 8:40 AM
    #77
    PermaFrostTRD
    Northern NY
    "even a near miss is still a miss"
    You said it, not me. Then you go on to say that you almost died from malaria, confusingly measuring your almost, with someone else's and coming to the conclusion that your almost, is somehow more.
    On the entire internet, that's the dumbest thing I've ever read.
  18. Apr 30, 2025 at 8:58 AM
    #78
    seydou
    So in your mind there is zero difference between being almost hit by a truck and actually contracting a life threatening illness and almost dying from it. Got it. So when you are on the side of a road and trucks are speeding by and "almost" hitting you, this is almost dying. If you are stuck there for some time, do you almost die each time a truck passes? If that is your definition of a near death experience, we have different definitions.
  19. Apr 30, 2025 at 9:05 AM
    #79
    PermaFrostTRD
    Northern NY
    I haven't said anything about near death experiences. Or speeding trucks. I am only contesting your inability to grasp why your "sliding scale" interpretation of the word almost has not only been a logical fallacy, but at this point continues to be comically idiotic.
  20. Apr 30, 2025 at 9:07 AM
    #80
    mustang67408
    Victor
    Hot dry place in Nevada
    You are correct, but with a little elbow grease the 38 gallon tank can be installed into any 2007 and up Tundra. Like you said, I had to move the brake lines and space the E-Brake pivot up and we welded the front tank crossmember in and I also changed the straps to the ones with built in studs so I could use the OEM skid plate. the only things I cant fix is the MILES TO empty in the combination meter. The 2010 was never offered with the 38gal so the calculation isn't there. I just know I have an extra 120 miles on top of what my miles to empty says.
  21. Apr 30, 2025 at 9:19 AM
    #81
    seydou
    This is entirely about near death experiences, or put another way, almost dying. We apparently have different interpretations about what almost dying means. How would you define almost dying?
  22. Apr 30, 2025 at 9:21 AM
    #82
    blenton
    blenton New Member
    PermaFrostTRD[QUOTED] likes this.
  23. Apr 30, 2025 at 9:24 AM
    #83
    2mchfun
  24. Apr 30, 2025 at 9:50 AM
    #84
    TheMuffinMan
    TheMuffinMan New Member
    Idaho
    2021 DCLB SR5
    If you were trailering that 6 gallons would only be about 60 miles. So they had to account for if you were towing in their calculations, they'd rather underestimate remaining miles to empty then have people run out of gas thinking they had more.
    HulkSmurf14, caboj and mustang67408 like this.
  25. Apr 30, 2025 at 10:09 AM
    #85
    PermaFrostTRD
    Northern NY
  26. Apr 30, 2025 at 10:11 AM
    #86
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    I upgraded my 2016 to the large tank, it’s not a piece of cake but if you are mechanically inclined and have the appropriate tools you can do it yourself. It’s a little harder on a 2014 vs 2016 and up as the 14/15 need holes drilled for the crossmember and the e-brake cable needs modification.
    mustang67408 likes this.
  27. Apr 30, 2025 at 10:18 AM
    #87
    mverkaik
    mverkaik New Member
    Hamilton, MI
    2021 TRD PRO CrewMax
    WeatherTech Floorliners Toyota Running Boards Reflex Liner Truxedo X15 Pro cover.
    This is it right here. If you are towing to the max and getting 7mpg, you will have 50 miles to solve your problem. This sounds like a lot but when I was out west it is very easy to chew up those 50 miles. When driving empty of lightly loaded you have what seems like a huge reserve.
    I have found that this 50 mile rule seems to ring true on every vehicle that I have owned with a fuel light.
    Personally, I don't buy the keep the pump cool theory. I agree that it is better for the pump but I do not believe that if I run my tank low that it will harm the pump. That seems like crappy engineering if I need to do that.....
  28. Apr 30, 2025 at 10:26 AM
    #88
    TheMuffinMan
    Idaho
    2021 DCLB SR5
    It's totally a thing that'll burn fuel pumps up but that needs to be a repeated thing over awhile like a year that every tank you run it below a few gallons remaining. Most of us don't do that. I see pump issues on motorcycles that could have only a gallon for a reserve, but that's 50 miles. People who routinely run that reserve to half can see pump issues.
  29. Apr 30, 2025 at 11:10 AM
    #89
    seydou
    Good job! You're on the right track.
    Thinking you almost died because you almost got hit by a truck is not the same as thinking you almost died because you, for example, got a life threatening illness or got shot in the chest and had emergency medical intervention to save your life. One is actually almost dying and one is not. Can you pick the right one? How far away does lightning need to strike before you consider that it almost struck you? How far away from, or close to death do you have to be before you think you almost died? Or perhaps are you a relativist and think that as long as you believe something is true, then it's true? Lots of people nowadays seem to hold that position.
  30. Apr 30, 2025 at 11:28 AM
    #90
    2mchfun
