Trailer maintenance
Discussion in 'Towing & Hauling' started by ColoradoTJ, May 7, 2020.
  1. May 7, 2020 at 10:24 AM
    ColoradoTJ [OP] Certified tow LEO Staff Member
    This thread is for buying/maintaining all trailers:
    -Travel Trailers/campers
    -Flatbed
    -Enclosed
    -Wood Deck/Metal deck
    -Boat
    We all buy trailers for work, play, or both. Regardless of size, build quality they will need continued maintenance. Depending on geographical location, some trailers will need more attention than others (salt, wet, snow, high heat, water for boat trailers).
    What do we need to do? Great question and hopefully this thread can teach us all new ideas and best practices.
    Brand new trailers:
    - When ordering/looking for a trailer, really sit down and think about the options you want and need. Adding them later can be difficult. Things to consider would be:
    1) Size. This right here has been my own personal nemesis. The tow vehicle often can dictate this decision. In the past 15 years, I have owned 4 flatbed trailers alone (7K, 10K, 14K, 14K). All these were due to size requirements for the most part...except the 7K. That one just fell apart.
    2) Capacity. This is probably one of the most important decisions you will make. Is this for personal use only, business, or both? Local laws should be researched and understood. Local DOT and Highway Patrol can point you in the right direction. There is nothing worse than getting pulled into a DOT checkpoint and getting the book thrown at you. This can add up to thousands in fines.
    Remember, not all states require both braking axles, so be cognizant when buying a trailer and ensure you are buying what’s needed.
    3) Use. What is the best trailer for your needs? (Majority of the time)
    4) Configuration. Tie down points, width, drive over fenders, removable fenders, adjustable coupler (size), wood or steel deck, ramp(s), lights (go LED, you’re welcome).
    5) Construction. What’s the difference in 4” C channel vs 5/6” C channel? Enclosed trailer siding thickness .024/.030/.040? I’m sure we have all seen the enclosed trailers that siding looks like a piece of aluminum foil that’s been crumpled up and attempted to make smooth again. Thickness matters.
    - Never assume everything is 100% completed.
    - Inspect very closely (welds, paint, wood decking, wiring, lights work, etc).
    - Read owners manual. Find out the options your specific trailer has and maintenance suggestions.
    - Take a grease gun when picking up the trailer for the first time (if the spindles have zirks). Put a couple good pumps in each. Most quality trailers have bearing buddy spindles and self adjusting brakes.
    -Warranties. Understand what you have, and get the best one you can afford.
    When you get home with the trailer:
    - Treat the deck. Trailer deck maintenance often gets forgotten. This is my new trailer, 2017 model that was never used or treated. Deck it not in good shape.
    Used trailers:
    What to look for is important. Here are some suggestions that might help later on.
    1) Overall condition. If the trailer looks like it wasn’t taken care of cosmetically, it most likely wasn’t mechanically.
    2) Decking. This can be a real pain to replace, and expensive. Regardless if you plan to do this yourself, it’s still expensive.
    Trust me, this sucks.
    3) Frame rust and weld condition. Research the manufacturer build quality. Not all trailer manufacturers are created equal, and in most cases you get what you pay for.
    4) Axles. This is a big one, especially with 3200 lb axles. Lots of times, these are purchased with the best of intentions, but often are overloaded. This is even a bigger issue when the trailer is a single axle. Look how bent the spindles/axle is? I followed this Tundra towing at 75 mph.
    This trailer most likely eats tires.
    Axles in good condition should have an arch in them like this:D5C48555-C4AF-460A-BB85-C8079B15947E.jpg
    When was the last brake shoe replacement? Bearings repacked? Receipts? If not, I would pull a hub to inspect. The seller might not want to do this, but if they want a sale and have done due diligence with maintenance there’s nothing to worry about. Look to see what new replacement bearing hub/brake assemblies cost x 4. Hubs, bearings, brake assemblies on my trailer are 205-250.00 each.
    Inspect the bearing cap, and rubber grommet. Tire shops beat these up a lot, but the grommets are very important. If you see cracks in the rubber, you can assume water got inside the hub.
    Good sealed up bearings with 15k miles on grease.
    Seal was cracked, water was obviously inside hub and bearings/races replaced. This trailer is 3 years old with only 600 miles on it. Luckily I brought a grease gun and pumped some good bearing grease inside to make the trip home (600 miles away).
    5) Coupler. Is it in good working condition? Grease inside or ran dry?
    6) Jack. Accidents happen and jacks are left down. Is the jack in good operating condition? Bolted on or welded? Replacement costs? Some jacks are 300.00 and then you need to cut the damaged one off, and weld a new one on. Then you have paint/Powder coating to deal with.
    7) D-Rings, stake pockets, tie down mounts in good condition?
    8) Safety chains. Have they been drug on the ground? Safety clips still work?
    9) Tires. There will be a lot of opinions about trailer tires. Some people I know that tow huge RV's never let their tires get 3 years old. Good rule of thumb is 3-6 years old. Personally, my flatbeds never last over 5. On the RV, every 3 years due to what is located right above the tires (refrigerator, hot water heater) and can cost thousands in repairs.
    Speed ratings. Buy the tires that have the best speed rating. My RV has ST tires that are rated to 75 mph and the flatbed has tires rated to 81 mph.
  2. May 7, 2020 at 11:20 AM
    Opened for comments/suggestions. This is just a start, so share your experiences.
    Personally, I would like to learn more about boat trailers and enclosed trailers. I may be owning some of those in the future.
    Tundyfundy likes this.
  3. May 7, 2020 at 11:23 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I re-packed my bearings and adjusted my trailer brakes. It’s an RV so it also has other maintanence points such as replacing heater anode, oiling slides, ouling blades for tank emptying and rolling on a new rubber roof. Also there’s paint chipping at the trailer tongue so I’ll sand and repaint soon to prevent rust. Also make sure to check you suspension for leaks!
  4. May 7, 2020 at 11:24 AM
    Tundyfundy
    Bay Area, CA
    Also don’t forget about the module and cable that locks the brakes of the trailer runs away. Leaving your chain down is very dangerous as if it snags it will pop the lock on the brakes.
  5. Jun 2, 2020 at 9:42 PM
    Silver4x4trd
    Silver4x4trd New Member
    2017 Tundra SR5 & 2012 Sequoia SR5
    Jba long tube headers, dirty deeds TRD exhaust (2x24), 19+ Pro lights and grill painted sky silver, TRD rear sway bar, TRD reusable air filter, PnP sliders, pnp full set skid plates, 275/70/18 ko2’s, bully dog bdx (trail setting), c4 hybrid bumper with DD lights(sae fog and driving)
    Thanks, after reading this it pushed me to replace my boat trailer tires. I upgraded to Goodyear endurance load D 8 Piles had 6 piles before. Two of the old tires were manufactured in 2010!!! :anonymous:
    GODZILLA and Tundyfundy like this.
  6. Jun 29, 2020 at 9:26 PM
    Jpneely
    Jpneely New Member
    White SR5 5.7
    Just replaced the trailer lights and the coupler on the in-laws boat trailer. next thing on my list is the bearings and leaf springs. apparently these have never had the covers on them. they still seem pretty solid to me. no wiggle or noise. gets dunked in saltwater pretty regularly. i grease them up a few times a year or before moving her any real distance (20+miles). the boat ramp is only 2 miles from the house so we dont put many miles on her normally.on her normally.
  7. Jun 29, 2020 at 9:36 PM
    AZTundra
    Paul
    Phoenix, AZ
    Excellent write up and great advice. :thumbsup:
  8. Sep 13, 2021 at 1:27 PM
    Retired...finally
    Coming from a background where safety is paramount I was shocked at the overall condition of my new TT that had just been prepped by the dealer. Little green valve stem caps on tires 20 psi too low, 18 of 20 lug nuts not torqued too 100 ft/lb, wires, water hoses and LP lines against steel edges with no chaffing protection, trailer brake wires not secured and hanging in the breeze and that's just the safety related items. Many more items inside showing evidence of Covid era assembly quality.
  9. Sep 13, 2021 at 1:34 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    @ColoradoTJ when replacing deck on a trailer, do you know if the wood needs to be spaced out like when putting up a fence? Or just lay them together as they are treated wood?
  10. Sep 13, 2021 at 3:18 PM
    Space them out for shrink and swell. This also helps drain (water/snow, etc).
  11. Nov 21, 2024 at 5:05 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Wake up :)
    Cleaned, inspected, and repacked wheel bearings on a '22 Winnebago Hike, looks good last a long time. Also stuck borescope down toilet to have a peek in black tank. Not horrible but we can do better. :rofl:
  12. Jan 8, 2025 at 6:03 PM
    Bought2Pull
    Bought2Pull New Member
    Greg
    WV
    2006 Tundra 4 door
    After I had to install a new hub due to my ignorance concerning maintenance, I do a much better job keeping one of my Number One tools up and running.
  13. Feb 5, 2025 at 4:48 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Went camping Monday so on Sunday I ran all system checks and found one propane bottle pigtail leaking gas at the connector. We normally just run the left bottle so I decided to run the right bottle this time and got an immediate stench of propane. Soapy water sprayed it and it was pissing out from back of connector. Just another failure point I never expected. 20250205_164720.jpg
    Wallygator likes this.
  14. Feb 5, 2025 at 6:00 PM
    If i recall, propane lines are on a 5 year replacement schedule.
    Tunrod[QUOTED] likes this.
  15. Feb 8, 2025 at 8:07 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Swapped out one of the stabilizer jacks control switch that died. Amazing the little shit that goes wrong on something that's only taken out 4-5 times a year. 20250208_065705.jpg
    ColoradoTJ[OP] and Wallygator like this.
  16. Feb 8, 2025 at 9:15 AM
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
    My RV tires cost me $3600! I keep it inside and have tire covers for camping.
    3 years and maybe 3K miles is a short period to replace them IMO.
  17. Feb 8, 2025 at 9:18 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Manual stabilizer jacks FTW.
  18. Feb 8, 2025 at 9:21 AM
    szabo101
    szabo101 New Member
    ED
    2018 MGM Platinum 4WD
    How many and what type of tires cost you $3,600?
  19. Feb 8, 2025 at 9:21 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    I do retract them manually on occasion when leaving early in the morning during quiet hours.:)
  20. Feb 8, 2025 at 9:26 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    At least you're more considerate than the bros who use an impact on theirs.
  21. Feb 10, 2025 at 10:24 AM
    Lifer
    Lifer New Member
    Vince
    6 Michelin 19.5 XRV's. Price was mounted and installed. Not sure if they balance big tires. DSC_0397.jpg DSC_0398.jpg
    szabo101[QUOTED] likes this.
  22. Feb 16, 2025 at 9:01 AM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Washed and waxed.
  23. Apr 4, 2025 at 5:02 PM
    atc250r
    atc250r New Member
    Orange County, New Yorkistan
    2020 Tundra Double Cab 6ft Bed SR5 TRD OR
    Nothing yet except for some LED interior & exterior bulbs.
    Wallygator and Tunrod like this.
  24. Apr 4, 2025 at 5:56 PM
    blenton
    blenton New Member
    I’ve watched a few of his videos - he seems to be pretty knowledgeable.
    My 7x16 enclosed is due for some maintenance. It’s my workhorse and has treated me very well, so I need to repay the favor. This weekend or next, I’ll be installing some Lippert Equaflex equalizers and greasable shackles, along with packing bearings and checking brakes and such. I replaced the tires last year but they are wearing down again (tires do that…); hopefully they make it through the summer.
    My travel trailer came with CRE3000 equalizers and it seems to tow smoother. Hopefully the Lipperts are worth the upgrade
    Anybody have experience with them?
    Hopefully this summer I will also get to retrofitting my single axle enclosed with brakes. I did the same thing on my last one and it made for a more comfortable tow, especially in inclement weather.
    KNABORES and atc250r[QUOTED] like this.
  25. Apr 5, 2025 at 5:43 AM
    atc250r
    atc250r New Member
    @blenton I put a set of those Lipperts on the 6.5x16 I'm currently refinishing so we can haul or SXS around. I also replaced all the leaf springs (a couple were bent), added a set of greaseable shackles, replaced the brakes, replaced the bearings, installed new tires, and painted it. I just have to install the rest of the lights so unfortunately I haven't road tested it yet. It was a lot of work but my wife's uncle retired from his stone mason business and hadn't used it in years so he gave it to us. It's a 2003 and has had zero maintenance. LOL. Here's a before and after, it still needs the lights finished and deck installed. Hopefully Sunday I'll wrap up the lights.
  26. Apr 29, 2025 at 8:30 AM
    atc250r
    atc250r New Member
    @blenton I finally got to take a trip with those Lipperts and it towed really well. Did about 1300 miles of mostly interstate but there were some tight, curvy, WV back roads along the way with some pot holes and it seemed to soak them up well.
    blenton likes this.
  27. Apr 29, 2025 at 7:13 PM
    blenton
    blenton New Member
    Good to hear. Thanks for the update. Mine have been collecting dust in the box.. :oops:
    Life decided I was too complacent and placed some extra demands on my time. Haha. But it’s all good - mostly means I have to spend more time with my kids carting them around to activities in the evenings. So a win by default.
    atc250r[QUOTED] likes this.
