Non JBL factory amp bypass
Discussion in 'Audio & Video' started by BigdaddyII, Jul 13, 2023.
  1. Jul 10, 2024 at 11:16 AM
    bluecrab
    bluecrab New Member
    2017 Tundra Limited CrewMax TRD Black
    I'm running the dash tweeters (no center dash speaker).
    aVs75 likes this.
  2. Jul 17, 2024 at 7:07 PM
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    Glad I saved this thread. Harness finally came in after ups lost my first one.
    All crimped together and ready to plug in tomorrow.
    Appreciate all the info posted, very helpful.
  3. Jul 31, 2024 at 11:59 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Think im going to remove my aftermarket amp and use this method since the kenwood and the Dasaita have the same wattage ...
    Did you retain proper fade ability (i may have asked this already) by doing this?
  4. Jul 31, 2024 at 3:59 PM
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    a few
    I messed with the settings a bit in the amplifier app on the Dasaita unit and everything seemed to do what its supposed to.
    purplenova[QUOTED] likes this.
  5. Aug 9, 2024 at 1:21 PM
    boomsling
    boomsling New Member
    ‘18 SR5 Double Cab 4x4
    Magnuson, Rough Country 2” coil overs
    How did it sound with the factory amp bypassed?
  6. Aug 9, 2024 at 1:32 PM
    purplenova
    Tom
    Ohio
    I haven't disconnected the amp yet.
    boomsling[QUOTED] likes this.
  7. Sep 5, 2024 at 9:10 AM
    jrd0222
    jrd0222 New Member
    Jeffrey
    2020 Tundra SR5 4x4
    Alpine ixl f511
    I have the ixl f511 from trail grid pro. Had issues after install where my door speakers sounded like garbage. They never called me back to try and address my issue so I began messing around in the settings and reset my audio settings in the mastro and it sounds much better. I’m going ti do this bypass trick and switch power to the HU.
    Question - at some point I’m going to add a 4 channel amp, can I at that point just run RCA’s from the HU, or will I have to re-do my bypass harness?
  8. Sep 5, 2024 at 7:07 PM
    jrd0222
    jrd0222 New Member
    Jeffrey
    2020 Tundra SR5 4x4
    Alpine ixl f511
    Sorry to double post but I did the harness solution and it worked beautifully.
    Ryuu likes this.
  9. Nov 19, 2024 at 2:06 PM
    haysr1
    haysr1 New Member
    2015 Tundra TRD 3'' Toytech Boss on 34'' Nitto Ridge Grapplers
    Is the factory amp still powering the sub? Thanks!
  10. Nov 19, 2024 at 4:58 PM
    jrd0222
    jrd0222 New Member
    Jeffrey
    2020 Tundra SR5 4x4
    Alpine ixl f511
    My trim did not have a factory sub. The amp was powering the door speakers. Now after the bypass my alpine head unit is powering the door speakers. I did add an amp and subs.
    haysr1[QUOTED] likes this.
  11. Apr 8, 2025 at 5:19 PM
    yougators914
    yougators914 New Member
    Buddha
    2014 Tundra CM Non JBL with amp
    Rims and tire level kit and lights all around and a new Dasaita G13 head unit
    So I have a 14 Tundra CM and just installed the Dasaita G13 head unit and everything works but my front speakers and dash speakers. I got the bypass harness and matched up everything but when I plugged it in it got worst any idea what could have went wrong. My back door speakers are jamming at the moment.
  12. Apr 9, 2025 at 4:21 PM
    20manny1996
    20manny1996 New Member
    Manuel (Manny)
    2017 Limited Super White CrewMax
    Make sure the center dash speaker is unplugged. Is it JBL or non-JBL?
  13. Apr 10, 2025 at 8:03 PM
    yougators914
    Buddha
    It’s a non JBL
  14. Apr 12, 2025 at 6:32 AM
    20manny1996
    Manuel (Manny)
    Do you have any sound at all coming out from front speakers?
  15. Apr 12, 2025 at 6:35 AM
    yougators914
    Buddha
    I mean just barely when I mean barely it’s like volume 1. But the rears are better than ever that’s why I thought using the bypass would work but it was low all around when using harness
  16. Apr 12, 2025 at 6:50 AM
    20manny1996
    Manuel (Manny)
    Check the simple things first:
    -check HU & make sure sound is not faded to the rear
    -check the wiring for the bypass harness. Verify you didn't cross some of the wires for the front (positive w/negative, etc)
    -check the connections behind the new HU
    Have you tried using the factory amp with the new HU? & If so, does it sound normal/more balanced all around the vehicle?
  17. Apr 12, 2025 at 7:49 PM
    yougators914
    Buddha
    Yes I have done this all. Factory amp only the rear speakers works and it bad ass. Fronts and dash sounds maxed out on volume 1. With the bypass harness all around sounds like volume on 2. Idk at this point I assume just running new wires to each and changing them out. Idk
  18. Apr 12, 2025 at 9:24 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    The dash speakers are powered from the HU.
    The front doors from the underseat amp, when it was there.
    The amp bypass should have both front and rear doors running from the HU.
    You did omit the OEM undereat amp, correct?
    You can use these diagrams to make sure you did the bypass correctly..
    You may have crossed some wires which would have messed up the entire front speaker output, dash and doors.
    The front signal goes out the HU and splits to the dash speakers and the OEM amp then to the front doors.
    Maybe try unplugging the amp bypass and see if the dash speakers are working.
    For the rear the signal goes out the HU and splits to the rear tweeters and then the OEM amp to the rear doors.
    Welcome to the forum.
    20manny1996 likes this.
  19. Apr 13, 2025 at 7:10 PM
    yougators914
    Buddha
    I think I wired it correct not sure tho
  20. Apr 28, 2025 at 7:38 PM
    #50
    etxdude
    etxdude New Member
    2016 White Tundra SR5 Crewmax
    How do you guys like the dasaita head units? I am thinking about pulling the trigger on one…
  21. Apr 28, 2025 at 7:41 PM
    #51
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Does everything work OK?
    Back in the day we had to make our own harness adapters...:eek:
  22. Apr 29, 2025 at 6:59 PM
    #52
    yougators914
    Buddha
    No not yet when using the bypass harness I barely hear anything on max. So at the moment I’m just using the rear speaker which works fine.
  23. Aug 7, 2025 at 12:30 PM
    #53
    stevon
    stevon New Member
    Stephen
    San Diego
    2003 Tudra
    20" rims
    Hey Guys,
    I have a 2002 extra cab 4 door SR5 Tundra and want to replace the factory radio with an aftermarket double din head unit and use the factory speakers for now. My truck has the OEM amp in the dash. So all I need is the Metra 70-1761 or the AutoHarnesHouse AHH-4438 kit to bypass the factory amp? where do you plug it in? at the removed amp input plug? I'm confused, probably not the only one.
    Stephen
