General Supercharger Thread
  1. Apr 27, 2025 at 2:49 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    I got my original tune with the JBA headers already installed. It does lean the AFR out a bit, more airflow, so it would be a good idea to make sure you're not running too lean.
    ARES35, Tundra Texan[QUOTED] and Mdl like this.
  2. Apr 27, 2025 at 2:56 PM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Kinda figured that would be the case.
    I'm one of those who likes to get everything done in one fell swoop.
    As in install the headers as well as any other engine mods before taking it in for the retune.
    Being retired I have all the free time I'll need.
    Told the Wife this is likely to be my last truck before I Croak and She said to go all out!!!
  3. Apr 27, 2025 at 2:57 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @Tundra Texan Like @armyoffoo stated a re-tune is advised they will lean out your afr's. If they are ARH with the single air tube its not bad. I've pulled my jba's a few times and got it down but the passenger side can be a pain.
    Wynnded, armyoffoo and Tundra Texan like this.
  4. Apr 27, 2025 at 3:01 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Depending on who does your tune, it could be as simple as having them update your file, flashing the update, logging a run to verify, doesn't necessarily require a dyno tune session.
  5. Apr 27, 2025 at 3:09 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    So small update on my Magnuson2560 issue.
    Didn't get a chance to stop at the local shop but I did send a video of the issue to the guy that did my install.
    High possibility the bearings failed according to him so went ahead and filled out the warranty request form.
    I did replace my idler pulley and belt tensioner to eliminate them as possible issues, but noise is still there so going to agree on the bearing failure. I did check the pulley on the supercharger while the tensioner was off, spun it by hand, pretty sure I heard a slight noise and felt a little play, but idk.
    Crazy to me it's having an issue only a year in, barely 10k miles. I don't even beat on the thing but I'll just see what Magnuson has to say once they reply.
    HulkSmurf14, ARES35, blenton and 3 others like this.
  6. Apr 27, 2025 at 3:17 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    It’ll run, but roughly without a retune. The distance increase for the o2 sensors is substantial and impacts the feedback for fuel trims, among other changes.
    I installed ARH long tubes in my driveway with a friend and took all day. We were able to do it without removing or cutting anything (other than removing the exhaust). It’s very tight and in my case a suspension lift plus larger tires was likely needed for clearance to maneuver (or a real lift ideally). Truck drove okay afterwards but getting a real tune helped it significantly. Butt dyno says sizable improvement for LTHs. The annoyance is the resulting (potential) idle issues and catalytic converter check engine lights.
  7. Apr 27, 2025 at 3:20 PM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Had a similar issue with my TRD S/C on my 98 Tacoma.
    It was in the tensioner pulley bearing as well.
    I made my own pulley out of 316 Stainless and made the diameter for the bearing the same as German speed bearings so I could push em out and press in a new one if needed.
    Never had to replace the bearing again.
    The funny part....The bearings were intended for use in Skateboard wheels.
  8. Apr 27, 2025 at 3:22 PM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Thanks for the info!!
    Really appreciate it!!
  9. Apr 27, 2025 at 4:09 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I have about 8500 miles on mine. I will likely see it get to 10k some time this summer. If I start hearing shit on mine, I'll be sure to report it here.
    HulkSmurf14, ARES35 and Ryuu[QUOTED] like this.
  10. Apr 27, 2025 at 4:22 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Installed the ECB-1 on the left side. Upper left side is bank 2 (driver side) afr, upper right peak boost. I did not install it's fuel sensor as I have that on the ECF-1 on the right side so can't have any of the fuel related info so both bottom gauges are real time boost
    The ECF-1 on the right gauge has bank 1 afr, ethenol % fuel pressure and temp
    https://vimeo.com/1079198159?share=copy
    HulkSmurf14 and ARES35 like this.
  11. Apr 27, 2025 at 6:11 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    Then you may have slipped timing
  12. Apr 27, 2025 at 6:20 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    A little test fit. Still lots to do for this project, but feeling good about the space I’ll have to monkey around with.
  13. Apr 27, 2025 at 6:31 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    a few
    funny thing he did mention magnuson had issues with the tacoma s/c bearings in the past but seems I'm not the only one hes heard from having the bearings fail on the magnusons.
    for sure, let us know. I'm curious to hear from others with the maggy2650. give a listen to the engine bay with the hood open, at idle with my hood closed I really don't hear anything.
    Also forgot to mention went ahead and ordered a new serpentine belt. Gave it a look over since I was already there when I changed the idler pulley and the belt tensioner, didn't look too good honestly plus found a small crack.
  14. Apr 27, 2025 at 6:58 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Yeah, I've also come across that outcome reading up on this...really hoping it's not the case, but I guess I will find out when I pull the rotors.
  15. Apr 28, 2025 at 7:26 AM
    e30cabrio
    If it was timing how would it run fine without the SC? Not to mention, isn't noise the only symptom? So even with the SC it is otherwise running properly no?
  16. Apr 28, 2025 at 7:29 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    The rotors are timed together via gears in the case, sometimes they can skip and cause the rotors to hit either each other or the case walls.
    Wynnded, HulkSmurf14 and reywcms like this.
  17. Apr 28, 2025 at 7:45 AM
    e30cabrio
    OIC, I thought we were talking about engine timing.
    HulkSmurf14 likes this.
  18. Apr 28, 2025 at 7:54 AM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    If you can get that swap/tune sorted, I'll send the truck to you.
    It's not bad, but tedious, I didn't have a lift at the time so took me about 2 days, I don't know how some people able to do it in 6hours as I spent 6 hours just looking for dropped nuts, the driver's side is incredibly tight, I have normal sized hands for a 6+ft man, I couldn't put my hands between the steering link to tighten couple of the bolts so I had to get my kids to do it, also stock manifolds are held on via studs, so if the headers you are using requires re-use stud/nuts it can present another headache if you have stripped studs etc.
    FYI, I have Stainlessworks long tubes.
  19. Apr 28, 2025 at 8:53 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I'm happy to share any information that helps, but I don't have space/facilities to work on additional vehicles...I'll be doing this in my driveway.
    ZPhilip, HulkSmurf14, Mdl and 2 others like this.
  20. Apr 28, 2025 at 11:15 AM
    e30cabrio
    Opened the driver side valve cover, looks the same.
    HulkSmurf14 and armyoffoo like this.
  21. Apr 28, 2025 at 1:56 PM
    bmw345
    bmw345 New Member
    CT
    2018 Platinum Pro, Pro Fox's TRD Skid
    Well look what arrived today! Early Birthday present for myself! Got a whole tank of regular fuel to burn off before install! Im excited!
  22. Apr 28, 2025 at 2:43 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    SCOL says they don't have the snout bearing details, rotor bearings require a full rebuild, and will rebuild it for me if I ship it to them. Harrop said they would inspect and rebuild, so I'm shipping it to Harrop's Ohio location.
    Wynnded, HulkSmurf14 and e30cabrio like this.
  23. Apr 28, 2025 at 3:09 PM
    DesertRat_-
    DesertRat_- New Member
    2017 Toyota Tundra Trd Bilstein 6112/1560
    Are you installing it yourself?
    Tundra Texan, HulkSmurf14 and reywcms like this.
  24. Apr 28, 2025 at 3:28 PM
    bmw345
    bmw345 New Member
    CT
    My buddy is a Toyota master tech, he is doing it for me, he has done many of them.
  25. Apr 28, 2025 at 3:29 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    SCOL called me and they have the Harrop snout bearings...going to try that before shipping the rotor pack.
    ZPhilip, Mdl, e30cabrio and 4 others like this.
  26. Apr 28, 2025 at 3:56 PM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Does that not void the warranty if not done by a Magnuson approved installer?
    While I'm sure your Buddy is perfectly capable of installing it I'd hate to see you lose your warranty.
  27. Apr 28, 2025 at 3:59 PM
    Tundra Texan
    Todd
    2016 Tundra
    None at this point.
    Mines on the way.
    Ordered it right at six weeks ago so any day now!!!
    Can't Wait!!!
    bmw345[QUOTED], Jego and HulkSmurf14 like this.
  28. Apr 28, 2025 at 7:09 PM
    Land Bruiser
    Land Bruiser New Member
    2018 Lexus 5.7
    Harrop 2650, 285/70r20
    Finally resolved my warm start issue. VF tuner released some updates over the past couple months so I took it in for a re-tune. Mike at Figs said there was only 1 cranking pulse table before and now there were 6!
    So after 1.5 years of hating having to warm start my LX it finally starts well. Now to do something with this 77.5mm pulley thats been sitting on the shelf for that year and a half.
    I have ~40,000mi on my Harrop 2650 and ~30,000 on the ikh22 plugs. At what mileage should I be looking to replace plugs 30k, 60k?
  29. Apr 28, 2025 at 7:40 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    After 100k miles, swap em every 60k-ish...at least that's what ive heard and read
    Land Bruiser likes this.
  30. Apr 28, 2025 at 7:49 PM
    Ryuu
    Ryuu Hwat!?
    Oscar
    SouthEast, TX
    a few
    Heard back from Magnuson today regarding my warranty request. Sent them two separate videos and they don't believe its a bearing issue. They think it might be an air leak and want me to do a smoke test. So I'll be doing that as quick as I can.
    Going to call the local performance shop tomorrow to see if they can do it and how much. If they don't for whatever reason or price is a bit much, I'll just buy a kit off Amazon to do it myself...
    Wynnded, HulkSmurf14 and Mdl like this.
