00 Frame Swap
Discussion in '1st Gen Tundras (2000-2006)' started by gparker, Apr 22, 2025.
  1. Apr 22, 2025 at 6:27 AM
    gparker
    gparker [OP] New Member
    Grayson
    00 Access Cab 4x4
    i have an 00 access cab v8 4x4 in need of a frame. i found an 00 access cab v8 2wd frame. is it a direct swap or will fabrication be required?
  2. Apr 22, 2025 at 6:51 AM
  3. Apr 22, 2025 at 8:04 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Not eligible for the frame recall?
  4. Apr 23, 2025 at 7:11 PM
    gparker
    Grayson
    00 Access Cab 4x4
    it was coated then it sat for years
  5. Apr 23, 2025 at 7:15 PM
    Yeah, sadly the coating is lipstick on a pig. The steel continues to rot underneath. Bummer. But also utter bullshit coating was allowed as a “remedy”.
  6. Apr 23, 2025 at 9:09 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    I'm pretty sure the 2wd and 4wd frames are exactly the same. Your main problem will be removing all of your rusty components from your 4x4 onto the 2wd frame...unless the 2wd frame still has most of the parts still on it.
    The Black Mamba likes this.
  7. Apr 24, 2025 at 3:50 AM
    The Black Mamba
    BlackSnek
    Flower Mound, TX
    Black 00 SR5 AC 5VZ PreRunner
    Imma keep it stock
    All AC/DC frames are the same. The transmission cross member (very easily removable and swapped as it has 2 bolts that attach to the trans tail shaft and 4 bolts that secure it to the frame) is the only frame difference. All of the AC/DC frames have the notching in the front cross member to accept the ADD.
    whodatschrome, rouxster70 and shifty` like this.
