Front axle play
Discussion in 'General Tundra Discussion' started by juan40tundra, Apr 22, 2025.
  1. Apr 22, 2025 at 10:17 AM
    juan40tundra
    juan40tundra [OP] New Member
    Juan
    2018 Toyota Tundra TSS 4wd
    none
    to all
    I noticed some play by where the axle connects to the differential (Left side). I wanted to see anyone had the same issue in the past.
    Took my truck to the dealership due to my alignment always been off, and they ended up replacing the right axle. However, the left axle has lots of play.
    Should I consider to bring the truck back?
  2. Apr 22, 2025 at 10:22 AM
    blenton
    blenton New Member
    Corndog123 and ColoradoTJ like this.
  3. Apr 22, 2025 at 11:27 AM
    juan40tundra
    Juan
    none
    is it the same on a 2018 model?
  4. Apr 22, 2025 at 12:56 PM
    blenton
    blenton New Member
    Yes. 07-21 are the same.
    Corndog123 likes this.
  5. Apr 23, 2025 at 5:54 AM
    juan40tundra
    Juan
    none
    Perfect
    another question
    How much play should be on those axles where it connects to the differential,
    I see that my left axle can go up and down easily about .200" to .300" of travel
  6. Apr 23, 2025 at 6:30 AM
    Just a bit over 1/4" is a lot of play.
