DIRTY SEVEN CLUB
Discussion in '2.5 Gen Tundras (2014-2021)' started by matictundra, Feb 18, 2019.
  1. Apr 11, 2025 at 10:31 AM
    #3751
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    Honestly really liked my Baja Boss A/T. I had a hard time balancing 2 out of 4 of them but MT made it easy to warranty them out (at 80% because I did put a few thousand miles on them). But the 2 new ones were perfect. No complaints about them. They are on the heavier side but they’re my favorite tire I’ve ever ran on all my vehicles. Great looking tire too. I just always switch it up because I like trying something different but if you told me I could only run 1 tire rest of my life on my truck, it would be the Baja Boss A/Ts. Got me through a huge blizzard driving home from Vermont to NJ at 2 am. Can’t go wrong with them.
  2. Apr 11, 2025 at 11:03 AM
    #3752
    Dave8699
    Dave8699 Trackrat
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Guess the baja it is.
  3. Apr 11, 2025 at 6:32 PM
    #3753
    cwmoneymaker
    cwmoneymaker New Member
    Nice! No cutting to fit those?
  4. Apr 12, 2025 at 6:09 AM
    #3754
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    So you're in Western Ore. ? I lived 6 miles east of Newport. Toledo was my home for about a year and a half. Loved Oregon.
  5. Apr 12, 2025 at 6:21 AM
    #3755
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    Need a build thread or more pictures of this. Badass build!
  6. Apr 12, 2025 at 3:23 PM
    #3756
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    I know the area well. Newport is my most visited port, by far.
  7. Apr 16, 2025 at 2:47 PM
    #3757
    Dave8699
    Dave8699 Trackrat
    NJ
  8. Apr 16, 2025 at 3:21 PM
    #3758
    Uhhhh....
    Uhhhh.... New Member
    Dave
    Virginia
    2016 Silver Limited DC
    7” BDS, 37s
    Based strictly on your pictures without any info on offset or lift, definitely.
    …cmon dude
  9. Apr 16, 2025 at 3:28 PM
    #3759
    Dave8699
    Dave8699 Trackrat
    NJ
    Seriously cmon bro they fit just like that.
    P.S. my garage is full of parts waiting to be installed. Lol
    Uhhhh....[QUOTED] likes this.
  10. Apr 16, 2025 at 3:52 PM
    #3760
    Uhhhh....
    Dave
    Virginia
    7” BDS, 37s
    lol do it!
  11. Apr 16, 2025 at 4:39 PM
    #3761
    Dr3wski
    Dr3wski New Member
    2018 SR5 4x4
    Those Icons look nice!
    Dave8699[QUOTED] likes this.
  12. Apr 22, 2025 at 6:56 PM
    #3762
    rcsbguy
    rcsbguy New Member
    Ordered new wheels. Ready for 37s!
  13. Apr 22, 2025 at 7:25 PM
    #3763
    n0rth
    n0rth New Member
    J.W.
    2019 Tundra Crewmax
    New set of 37x12.50R17LT Cooper AT3 XLT to replace the Kanati Trail Hogs.
  14. Apr 23, 2025 at 8:19 AM
    #3764
    HappyDad38
    HappyDad38 New Member
    2014 Black Tundra TSS SC 4x4
    6" BDS Lift Fox Coils and shocks 35x12.5r20 nittos
    That wheel and tire set up is going to look killer man. Hurry up and get them installed and post them pics!
  15. Apr 24, 2025 at 5:15 PM
    #3765
    Dave8699
    Dave8699 Trackrat
    NJ
    Waiting on the DRT kit so I can tackle all my suspension work Front and rear
    WinterWarlock21 likes this.
  16. Apr 24, 2025 at 9:22 PM
    #3766
    DesertRat_-
    DesertRat_- New Member
    2017 Toyota Tundra Trd Bilstein 6112/1560
    Anyone Running Kmc's with some 37 ko2?
  17. Apr 25, 2025 at 6:57 AM
    #3767
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    Maybe the tires? or may be the suspension he/she has doesn't compress as much?
    I have KO2 37s, they run small, here it is compare to my old 285/75r18 AT3W, the Falken measured 34.9" and KO2 measure 36.3 ish, I also run 17x8.5 et0 and I have almost zero rub when compressed on Bilstein 8112 with Icon billet UCAs.
    Yea, those tires run small, so easiest way to fit 37s.
  18. Apr 25, 2025 at 9:51 AM
    #3768
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    I attached a video for reference, the most rubbing occurred at the rear where the tires would grab the top lip of the bedside fender well opening. If you turn up the volume you’ll be able to hear it.
    Also will quote my build thread here which has some pictures to show rubbing at the top of the inner wheel well as well as some others. Note I do not have bump stop spacers to limit up travel. The tires meeting the inner fender wouldn’t be a problem if the friction didn’t act as a brake and slow the wheels down. Lol.
    I’m glad you aren’t experiencing rubbing issues, but my thought is that you’re not flexing out the truck as you claim you are. But if you are, and aren’t rubbing, it would be great to learn what’s different because as you mentioned so many have had the same experience as me with 0mm offset. I’m running +25mm on my current Tundra but at 35” until I can install 5.29s and figure out the right solution for a spare. There certainly are much more wheel options with 0mm offset.
    Could be a mix of things for sure. Tires could be a bit smaller, or bump stop spacers to limit the travel at full compression where the most rubbing occurs.
    tundra_20 and joonbug like this.
  19. Apr 25, 2025 at 12:44 PM
    #3769
    DesertRat_-
    Yeah! I currently have 315/70r17s but I don't want to do 35s because it's essentially around the same. So maybe 37 KO2 which are probably around the 36". I'm on stock gears also.
  20. Apr 25, 2025 at 12:46 PM
    #3770
    DesertRat_-
    Does anyone run 17s "KMC" wheels. I'm looking for some pictures with chromes ones? I really wanted the Brushed silver ones with black lip but unfortunately they don't fit.
  21. Apr 25, 2025 at 12:49 PM
    #3771
    rcsbguy
    rcsbguy New Member
    Post a picture like this of the side of your truck and I'll photoshop the set in 2 seconds.
    Side note, you can buy these Method 703s in machined that are probably lighter and +35 offset for $254 a pop.
  22. Apr 30, 2025 at 4:28 AM
    #3772
    sea_weathered
    sea_weathered New Member
    Pacific Ocean
    2018 DC Adventure Chuck Wagon
    After a few years of squeezing 37s onto my truck with Method 701’s and 0 offset, I switched out wheels for something less flashy. I went with the new Nomad Convoy in a 17X8.5” +25 offset. The difference surprised me. Not only do I get fewer “sick bro” comments from dudes at gas stations, but my tires no longer graze what is left of my cab mount. (Not much)
    And, my steering generally feels better.. With the 0 offset of the Methods, when I would hit a pothole or a water bar, I could really feel it coming through the steering wheel. With less offset, I get less feedback to the steering wheel. I know it’s only 25mm on each side, but it feels like there’s less strain on all of the components in the front end. The Bead Grip of the Methods was nice reassurance, but I don’t think I will ever actually need it. I spend a decent amount of time in the backcountry, and 18-19psi is generally the lowest I end up airing down to. IMG_3800.jpg IMG_3801.jpg IMG_6732.jpg IMG_6716.jpg IMG_6625.jpg IMG_6622.jpg
    TOYOTARIG, Dave8699, jmladdy and 9 others like this.
