  1. Apr 21, 2025 at 2:03 PM
    #9661
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    I don't think there is a consensus. I think there's preference.
    I'm gonna go Dry.
    IIRC, oiled flows better but a typical oiled cotton gauze filter lets more dirt through. At least that was the case with K&N's.
    Different makers use different/better filtering material? Possibly.
    I'm sticking with better filtration over marginally better flow.
    DubfromGA and az 3rdGen[QUOTED] like this.
  2. Apr 21, 2025 at 2:05 PM
    #9662
    BlackNBlu
    Rich
    MN
  3. Apr 21, 2025 at 2:07 PM
    #9663
    az 3rdGen
    az 3rdGen New Member
    Arizona
    2022 Black Tundra SR5
    I am leaning Dry and replaceable. One item on my long list of things I want.
  4. Apr 21, 2025 at 2:07 PM
    #9664
    Derfla
    Derfla 2025 TRD PRO
    Mudbath TRD Pro
    I did the Magnaflow Overland exhaust. Killed me having dual tail pipes and the side step. This is how she looks now:
    R1Style_, Yaboy, DubfromGA and 5 others like this.
  5. Apr 21, 2025 at 2:07 PM
    #9665
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    yeah...only reason I passed on those was due to color. Seller is local to me, cant buy directly from AFE in Cali either. Cant do red though...lol. I dont live my life a 1/4 mile at a time.
  6. Apr 21, 2025 at 2:11 PM
    #9666
    Derfla
    Derfla 2025 TRD PRO
    Mudbath TRD Pro
    I’ve had my current oiled AFE intakes and inlet pipes from my previous 22 Tundra since November of 2022. I never had issues with it and bought an extra 2 oiled filters. I clean and rotate them once a year. I never had any oil on my MAFs or sand/debris (I live in Vegas) passed the filters in the intake tubes.
    I can see if someone over oils them. That’d be a huge problem.
    eddiefromcali likes this.
  7. Apr 21, 2025 at 2:25 PM
    #9667
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    Derfla and eddiefromcali like this.
  8. Apr 21, 2025 at 2:34 PM
    #9668
    SilveradoSwap
    Why do all the blanks have wiring going to the back of them in the panel??!?
  9. Apr 21, 2025 at 2:35 PM
    #9669
    Derfla
    Derfla 2025 TRD PRO
    Mudbath TRD Pro
    Looks like a board from the LC2i. It was too wide for any of mine. If you have a blank where I have my TRD Light bar button, it should fit there.
  10. Apr 21, 2025 at 2:36 PM
    #9670
    Derfla
    Derfla 2025 TRD PRO
    Mudbath TRD Pro
    They are live wires for the buttons that go there for other trims. When I installed my ditch light button, I tapped into the beige wire from the connector I pulled out to get illumination.
  11. Apr 21, 2025 at 2:40 PM
    #9671
    SilveradoSwap
    It looks like it will fit here. YT vids say to push it from the back to pop it out the front. I pushed pretty hard and wouldnt trust doing it any harder. IMG_8410.jpg
  12. Apr 21, 2025 at 2:42 PM
    #9672
    Derfla
    Derfla 2025 TRD PRO
    Mudbath TRD Pro
    I installed mine to the right of that. That button pushes in. The retaining teeth are at the top and bottom. The videos you are watching are for the other ones where the teeth are on the left and right and push out.
    DM me if you got any more questions. Sorry for flooding the thread!
  13. Apr 21, 2025 at 5:15 PM
    #9673
    Derfla
    Derfla 2025 TRD PRO
    Mudbath TRD Pro
    Just installed my new Baja Designs covers. Loving the Amazon brackets with cable management holes for my OCD!
  14. Apr 22, 2025 at 7:06 AM
    #9674
    eddiefromcali
    Eddie
    100% Stock
    Intake is on....lord was that a bit of a pain. Looks cool and no CEL though, I'm happy :)
    BlackNBlu and Derfla like this.
  15. Apr 22, 2025 at 7:08 AM
    #9675
    Derfla
    Derfla 2025 TRD PRO
    Mudbath TRD Pro
    Do you have the JB4? It’s a must with intake and exhaust!
  16. Apr 22, 2025 at 7:09 AM
    #9676
    eddiefromcali
    Eddie
    100% Stock
    Yessir...got one as soon as it was released. JB4 with ethanol sensor, running E30 blend on map 5. :burnrubber:
    ziznack and Derfla[QUOTED] like this.
  17. Apr 22, 2025 at 7:14 AM
    #9677
    Derfla
    Derfla 2025 TRD PRO
    Mudbath TRD Pro
    Nice!! How about charge pipes? Those are next on my list! Just haven’t decided which ones!
  18. Apr 22, 2025 at 7:22 AM
    #9678
    eddiefromcali
    Eddie
    100% Stock
    I had the AFE pipes but ended up selling them...never got around to it. Only K&N claim any hp gain...everyone else just says it can flow more...makes me think K&N just went with the random dyno run that showed some gain in hp and called it good.
    ziznack likes this.
  19. Apr 22, 2025 at 7:45 AM
    #9679
    Daedalus
    Daedalus New Member
    Charge pipes i think at this flow level are a waste of money.
    Unless you are upgrading past stock turbos, you wont see an recognizable improvement.
    I bet you the major restriction in this system is the Air to Water intercooler brick. Upgrade that, and you reap the benefits of a more efficient core (heat transfer) and airflow through the unit.
    eddiefromcali and Derfla like this.
  20. Apr 22, 2025 at 7:46 AM
    #9680
    Derfla
    Derfla 2025 TRD PRO
    Mudbath TRD Pro
    I’m not for the peak numbers any way. I want gains I can feel in the low and mid range because I never floor the gas pedal and rev her out. I want that immediate and available power.
    Flow will increase efficiency and response. Hopefully making the twins spool even faster/earlier.
  21. Apr 22, 2025 at 7:49 AM
    #9681
    Derfla
    Derfla 2025 TRD PRO
    Mudbath TRD Pro
    Increase in flow was evident when I did the turbo outlets. I think I gained more from those outlets than the intake itself.
    The S&B intake you installed already has them incorporated with their system. I wonder if they are as big (inner diameter) as AFE’s are.
  22. Apr 22, 2025 at 7:52 AM
    #9682
    Derfla
    Derfla 2025 TRD PRO
    Mudbath TRD Pro
    After I installed these, I was a believer in better flow. I felt the difference in my previous non-hybrid. Installing them in my hybrid, the gains were even more noticeable (probably because of the electric motor assisting).
    Yaboy likes this.
  23. Apr 22, 2025 at 7:59 AM
    #9683
    eddiefromcali
    Eddie
    100% Stock
    Yeah, those s&b tubes look like big ol whale dicks
  24. Apr 22, 2025 at 8:30 AM
    #9684
    Daedalus
    Daedalus New Member
    My hangup with the S&B is the MAF sensor is scaled to a specific cross-section diameter of the OEM tube. Change that and it alters the measurements that it takes.
    If Banks ever comes out with an intake for these trucks, that's what I will go with.
    Stop making these air intakes! | Fact Check
    Derfla likes this.
  25. Apr 22, 2025 at 8:34 AM
    #9685
    eddiefromcali
    Eddie
    100% Stock
    I thought it was a different diameter but I looked at the insert and it chokes it down a lot. It would throw codes or fuel trims would be out of whack if the lbs/min were way off. Fuel trims this morning (First drive with intakes) was spot on though.
    Derfla likes this.
  26. Apr 22, 2025 at 8:42 AM
    #9686
    Goobax
    Goobax New Member
    2024 SR5 4x4 Tundra
    im close to pulling the trigger on a magnuson upgrade but I just wish there were more people out there, or vocal enough, to give more reviews. Not sure if their radiator is needed/worth it either at this point
  27. Apr 22, 2025 at 8:45 AM
    #9687
    BlackNBlu
    Rich
    MN
    @Daedalus
    @Derfla
    @eddiefromcali
    Not tellin' you gents what to do or nothin'...not my place. So take as a suggestion.
    BUT.... a dedicated thread with input from you 3 outlining/showing the various pros/cons/differences between S&B, AFE, other intakes?, would likely be appreciated by more than just myself.
    (Who only want to make this purchase once.) :D
    Just putting it out there.
    Daedalus, Derfla and eddiefromcali like this.
  28. Apr 22, 2025 at 8:46 AM
    #9688
    eddiefromcali
    Eddie
    100% Stock
    I can give you my thoughts here, having had all 3. Go S&B
    ziznack, sudobash and Derfla like this.
  29. Apr 22, 2025 at 8:51 AM
    #9689
    6rian
    6rian New Member
    I've been on these guys a while to give some updates on gains along with their tuning. Should be announced soon. I'm also planning on this upgrade pending the results.
  30. Apr 22, 2025 at 8:59 AM
    #9690
    Daedalus
    Daedalus New Member
    The one intake thread to rule them all....
    LowcountryDave and eddiefromcali like this.
