New here and need some help
Discussion in '1st Gen Tundras (2000-2006)' started by zmixon54, Apr 16, 2025.
  1. Apr 16, 2025 at 8:45 AM
    zmixon54
    zmixon54 [OP] New Member
    Zachery mixon
    2004 white Toyota tundra 4.7 2wd
    Cold air intake
    Thanks for the add! I have a 04 with the v8 and recently the idler pulley by the fan went out and my serpentine belt broke, I was told there may be a way to remove/ replace just that pulley so I don’t have to replace the waterpump/timing belt. Or is there a way to do away with this pulley and re route the (shorter) belt? Thanks in advance
    Corndog123 likes this.
  2. Apr 16, 2025 at 8:53 AM
    kentuckyMarksman
    kentuckyMarksman New Member
    Idler pulley is easy, just remove your serpentine belt, unbolt your idler pulley, bolt the new one on, then reinstall your serpentine belt. I would highly suggest you check all your other pulleys for play and your belt as well.
    Your timing belt is a separate belt, and takes a bit more work to get to.
  3. Apr 16, 2025 at 9:08 AM
    zmixon54
    Zachery mixon
    Cold air intake
    Yeah I’ve already removed the pulley but the piece it bolts to is where the bearing is and that’s the bearing that has failed. It’s in the water pump housing. It’s the flange the pulley bolts to it’s on a shaft, the shaft is short and inset into the water pump.
  4. Apr 16, 2025 at 9:20 AM
    kentuckyMarksman
    Can you post a picture? The bearing is a part of the pulley assembly. The bearing is what the bolt goes through when installing the idler pulley.
    G_unit3000 and Corndog123 like this.
  5. Apr 16, 2025 at 9:29 AM
    zmixon54
    Zachery mixon
    Cold air intake
    I’m in the ER with my wife right this minute but as soon as we get home I will definitely do so
  6. Apr 16, 2025 at 9:35 AM
    Hope it’s nothing too serious!
  7. Apr 16, 2025 at 9:36 AM
    zmixon54
    Zachery mixon
    Cold air intake
    She has POTS bad and had a bit of an episode this morning that scared us, all good now. Thanks for asking though
  8. Apr 16, 2025 at 9:38 AM
    Stay hydrated!
  9. Apr 16, 2025 at 10:21 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! I hope your wife is OK, and that you can get away with just replacing the pulley!
  10. Apr 16, 2025 at 10:29 AM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    Welcome from TN. Hope everything is good with the SO.
  11. Apr 16, 2025 at 11:15 AM
    Had to look that up. In my world, POTS means Plain Old Telephone Service / Publicly Offered Telephone Service!
    Fragman and chunk like this.
  12. Apr 16, 2025 at 11:35 AM
    chunk
    chunk New Member
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    My G/F's son's G/F has POTS, I had to look it up too.
    shifty`[QUOTED] likes this.
  13. Apr 16, 2025 at 11:41 AM
    I kinda miss having a landline. Best I can get is VOIP these days.
  14. Apr 16, 2025 at 4:39 PM
    zmixon54
    Zachery mixon
    Cold air intake
    First off, thanks everyone for the kind words and worry for my wife. We’re back home, with no answers… we’re in southern MS btw. Here’s a pic where the pulley bolts on.
  15. Apr 16, 2025 at 4:46 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Thats the fan clutch bracket. Can't do away with it.
    Good news is, that bolts in front of the water pump and timing belt. So those don't have to be changed (unless it's time for them).
  16. Apr 16, 2025 at 4:47 PM
    zmixon54
    Zachery mixon
    Cold air intake
    Ok so can I remove it without tearing out the waterpump? Or do I need to go ahead and tear this thing down and do the water pump and timing belt
  17. Apr 16, 2025 at 4:48 PM
    zmixon54
    Zachery mixon
    Cold air intake
    I think I just answered my own question, I found them online and don’t have to do all that
  18. Apr 16, 2025 at 4:49 PM
    See video below.
    https://www.youtube.com/watch?v=9M3hFSiKs_U
    zmixon54[QUOTED][OP] likes this.
  19. Apr 16, 2025 at 4:53 PM
    zmixon54
    Zachery mixon
    Cold air intake
    Thank y’all for the help! Definitely put everything in perspective for me! While I have yall here, is there a buy and sell thread for these tundras on this forum?
  20. Apr 16, 2025 at 4:55 PM
  21. Apr 16, 2025 at 4:56 PM
    For parts, you need to have been here for a certain period of time, and have 50 contributive (i.e. non-spammy, legitimate) posts before you can post. I don't remember the time frame. The moderators take Buy/Sell ("BST") violations and reply-padding to reach BST thresholds very seriously.
    The marketplace for 1st gen is here - anyone NOT selling can reply all they want: https://www.tundras.com/forums/1st-gen-tundra-parts-marketplace-2000-2006.4/
  22. Apr 16, 2025 at 5:18 PM
    zmixon54
    Zachery mixon
    Cold air intake
    I’m just looking to buy no interest in selling anything atm. Thanks again!
    Corndog123 and shifty` like this.
  23. Apr 16, 2025 at 5:27 PM
    Fragman
    Fragman New Member
    2006 Tundra DC SR5 2WD V8
    Same thing for me!
    Corndog123 and shifty`[QUOTED] like this.
  24. Apr 17, 2025 at 3:14 AM
    Corndog123
    Sam
    Tennessee
    Oh....yeah, that one......
  25. Apr 19, 2025 at 3:22 PM
    zmixon54
    Zachery mixon
    Cold air intake
    I got the fan clutch bracket and new belt installed, thanks for y’all’s help! Y’all got any knowledge on which wires go where on this passenger headlight harness? The old one was burnt up!
  26. Apr 19, 2025 at 3:56 PM
    The community megathread contains links to every possible piece of maintenance info you could need for your 95%+ of your new-to-you truck: https://www.tundras.com/threads/so-you-wanna-buy-just-bought-a-1st-gen-tundra-eh.115928/
    Near the top, like the 5th line or something is a link to the electrical wiring diagrams: https://www.tundras.com/threads/ultimate-tundra-wiring-diagrams-collection.81448/
    Grab the diagram for your year. The connectors you're looking for are H1 (driver side) and H2 (passenger side) if I recall right, and sometimes I don't.
  27. Apr 20, 2025 at 6:02 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    According to the OEM harness conductors you're pinching, they appear to be Red w/White tracer(high beam), Blue(low beam) and the last wire can't really tell but it's either White w/Blue tracer(ground) for a DC or White w/Green tracer(ground) for an AC. It also appears to be passenger side.
    Red is hooked up, so I would assume the Blue of OEM harness goes to the light blue?? of the Non OEM black connector. The ground conductor of the OEM harness would then go to black of the Non OEM black connector.
    Seeing the backside of the black connector would help. The below is OEM connector....
    shifty` likes this.
