General Supercharger Thread
  1. Apr 19, 2025 at 2:09 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I did add the Improved Racing FSM145 degree thermostat. In the 15-20's I didn't experience any delayed shifting. Not sure how cold your area sees.
    ARES35 and HulkSmurf14 like this.
  2. Apr 19, 2025 at 2:33 PM
    centex
    centex New Member
    Maybe a week in the 30’s and that’s it.
    Mdl and HulkSmurf14 like this.
  3. Apr 19, 2025 at 2:37 PM
    mustang67408
    Victor
    Hot dry place in Nevada
    just finished working on a 2021 S/C tundra from alabama..
    Lean codes P0171/P0174
    found a broken PCV hose..JUST an FYI
    it has the Magnusson TVS2650 and was tuned with a VF tuner.
    ARES35, Tripleconpanna, Jego and 6 others like this.
  4. Apr 19, 2025 at 2:40 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    P0171 has been PCV related every time in my experience...or another vacuum line not connected. Nice find! They hide those things!!
    mustang67408 and M3Tundra-JK like this.
  5. Apr 19, 2025 at 2:41 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Tiny is a unit! Last I checked was a bit over 9mpg round trip with cruise set at 78mph. Too bad the flat bed is too short for the Tundra, upside is my trailer doesn't have fenders since Reys truck is so wide it overhangs both sides of the deck :rofl:
  6. Apr 19, 2025 at 2:43 PM
    HulkSmurf14
    2014 Tundra Limited
    Hahaha that's a solid pull efficiency! Good thing your trailer fenders aren't on! I could.image you building a ramp/bed extension on the semi to maximize that flatbed! You should've thrown the camper on it for the trip!!
    ARES35, e30cabrio and snivilous[OP] like this.
  7. Apr 19, 2025 at 2:45 PM
    snivilous
    SW UT
    That's been my thought, could add a cradle that indexes to the flat bed and slides into the hitch receiver without too much hassle. But that's a project for another day, especially now that I have another project at my door step :D
  8. Apr 19, 2025 at 2:57 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    That hose is a bugger. :(
  9. Apr 19, 2025 at 3:14 PM
    snivilous
    SW UT
    That hose was my sole reason originally to get a catch can.
  10. Apr 19, 2025 at 3:48 PM
    mustang67408
    Victor
    And that's why I have a catch can....Thank You
  11. Apr 19, 2025 at 3:49 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    It sure as hell influenced my motivation. At least now I know where I'm least likely to have an air leak.
  12. Apr 19, 2025 at 4:40 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Damn. And I just figured you were freighting him the engine…
  13. Apr 19, 2025 at 5:22 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Got some other things on the hit list and also the opportunity to scan the front suspension and maybe make our own LT kit later
  14. Apr 19, 2025 at 5:48 PM
    HulkSmurf14
    2014 Tundra Limited
    Leaf or no leaf, that is the question! :cookiemonster:
    Mdl and reywcms like this.
  15. Apr 19, 2025 at 5:56 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Still leafs for now.. gotta show these linked rigs leafs party harder before making the switch lol
  16. Apr 19, 2025 at 6:17 PM
    HulkSmurf14
    2014 Tundra Limited
    Good!!
    reywcms likes this.
  17. Apr 19, 2025 at 6:34 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Real trucks have leaf springs. :quickdraw:
  18. Apr 19, 2025 at 6:45 PM
    Silver17
    Eastern PA
    Pretty cool swap. It must bolt up fairly well given the use in the 200.
  19. Apr 19, 2025 at 7:06 PM
    blenton
    blenton New Member
    Didn’t @ViktorG do the same swap for somebody several years ago? I think it ran $40k or somesuch. Pretty cool swap, though.
  20. Apr 19, 2025 at 7:26 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Winks4x4Toy, ARES35 and HulkSmurf14 like this.
  21. Apr 19, 2025 at 7:29 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    HulkSmurf14 likes this.
  22. Apr 19, 2025 at 7:30 PM
    HulkSmurf14
    2014 Tundra Limited
    Clever idea...I wonder if one could ask Frozenboost to try something like this?
  23. Apr 19, 2025 at 8:23 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    :eek:
    I am seriously out of my league here :anonymous:
    nobodyintexas and HulkSmurf14 like this.
  24. Apr 19, 2025 at 8:52 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think that there was a company that did the diesel swaps, but the EPA may have shut them down. I think that @ViktorG did a Sequoia AWD swap to one of his Canadian pals truck who had the diesel swap done in the U.S. prior to the shutdown.
    ViktorG, ARES35 and blenton[QUOTED] like this.
  25. Apr 19, 2025 at 8:52 PM
    blenton
    blenton New Member
    That might have been it.
    HulkSmurf14 and Wynnded[QUOTED] like this.
  26. Apr 19, 2025 at 9:24 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
  27. Apr 20, 2025 at 4:38 AM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
    Oof. How many miles?
    Saltyhero13, ARES35 and HulkSmurf14 like this.
  28. Apr 20, 2025 at 4:46 AM
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    this
    I just come here to remind myself not to fuck with anything more than I have
  29. Apr 20, 2025 at 5:34 AM
    HulkSmurf14
    2014 Tundra Limited
    Can't stop, won't stop...buuuut, wife says I should at least stop messing with her cars...shhh, I'm not.
    Silver17, mustang67408, Mdl and 5 others like this.
  30. Apr 20, 2025 at 6:20 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Came out of a 2010 Tundra with 170k miles. I'm guessing regular oil changes every 50k miles, whether it needed it or not.
    Mdl, Silver17, Saltyhero13 and 7 others like this.
