Fuse box under dash no power but to ignition
Discussion in 'General Tundra Discussion' started by Scottlloyd, Apr 19, 2025.
  1. Apr 19, 2025 at 10:36 AM
    Scottlloyd
    Scottlloyd [OP] New Member
    2005 toyota tundra v6
    I have a 2005 toyota tundra v6 and I have power to the ignition fuse under dash but no where else under dash fuse box panel. Does anyone know what could be the problem. All fuses are good.
  2. Apr 19, 2025 at 10:46 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Have you checked the ground? Might be loose or corroded - I would start there.
  3. Apr 19, 2025 at 11:35 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Welcome to the forum.
    Wiring diagrams can be found here.
    Ultimate TUNDRA Wiring Diagrams Collection | Toyota Tundra Forum
    What is the model of your Tundra: standard, access, or double cab?
    The double cab can be different from the other 2.
  4. Apr 19, 2025 at 12:42 PM
    Scottlloyd
    It's a standard cab. We have replaced the 100 amp main fuse. What ground are u referring to? You will have to forgive me I'm not the brightest when dealing with electrical issues on vehicles
  5. Apr 19, 2025 at 1:33 PM
    shawn474
    MoCo, Maryland
    not sure on your year; however I seem to recall a recent member having a fuse issue where they weren’t getting any power to the box - had to chase down the wiring. Not sure if there was a resolution but will try to find it. And not sure if it was a similar year
    here it is; may or may not give some ideas on what to look for
    https://www.tundras.com/threads/half-of-fuse-box-not-working.156455/
