General Supercharger Thread
  1. Apr 18, 2025 at 11:45 AM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    I’m still waiting also.
    ssmokedz, ARES35, bflooks and 2 others like this.
  2. Apr 18, 2025 at 2:03 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, solid Offroad engine mounts, DIY Traction Bars, Tuning by snivspeedshop.com
    For some reason the little extra helps with shifts/p2757 /torque converter lockup which makes no sense. Some ab60's respond to it others no difference.
  3. Apr 18, 2025 at 3:12 PM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    Damn!!
    I bet that thing Scootes!!
    HulkSmurf14[QUOTED] likes this.
  4. Apr 18, 2025 at 3:32 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yep pops is still waiting for his valve body as well.
    Mdl, HulkSmurf14, ARES35 and 2 others like this.
  5. Apr 18, 2025 at 5:17 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Initially I was having pretty hard 1-2, 4-5, and F-R shifts. I tweaked fluid levels three or four times trying to get rid of them. After the first 5k miles, the 4-5 hard shifts have totally disappeared, and the others mellowed a little. But after the drain/fill, they got significantly better. I will probably do another in another 5k just to see if it changes further.
  6. Apr 18, 2025 at 6:07 PM
    centex
    centex New Member
    What’s the final fluid qty with the deep pan and drain and fill and what not? Starting to prep myself for this endeavor.
    HulkSmurf14 likes this.
  7. Apr 18, 2025 at 6:15 PM
    koditten
    Kirk
    Midland of the Mitten
    Same.
    I don't get worked up anymore.
    4-5 qts comes out. Most of a 5 qt jug gets pumped in.
    Will repeat in 25-35k miles.
    Pushing 275k miles. I'm happy.
    Mdl and Wynnded[QUOTED] like this.
  8. Apr 18, 2025 at 6:22 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    I bought x18 qt's and used x10, which included the check drip that started as a deluge... I'm going to put x1 additional qt in when I throw the cat plates back on...~1500 miles before that happens...
    On a side note...things are getting more serious since this showed up!
  9. Apr 18, 2025 at 6:26 PM
    AZTundra
    Paul
    Phoenix, AZ
    Did you get that from the eBay seller? I would have shipped you mine to use if you needed one. I think @e30cabrio has the same puller also.
  10. Apr 18, 2025 at 6:37 PM
    HulkSmurf14
    2014 Tundra Limited
    Damn, I sure did get it from eBay! WHY DIDNT I ASK?! Haha lemme see how this weekend goes and I still may ask to borrow and return this bugger...THANK YOU IN ADVANCE!!
    AZTundra likes this.
  11. Apr 18, 2025 at 6:48 PM
    AZTundra
    Paul
    Phoenix, AZ
    No problem, happy to help.
  12. Apr 18, 2025 at 7:37 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    The anti-seize helps A Lot!
  13. Apr 18, 2025 at 7:48 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    That's the one that came with my ebay pulley.
  14. Apr 18, 2025 at 7:48 PM
    e30cabrio
    qft
    Mdl[QUOTED] and HulkSmurf14 like this.
  15. Apr 19, 2025 at 8:59 AM
    ssmokedz
    Shelton CT
    Me either. :(
    HulkSmurf14 and bflooks[QUOTED] like this.
  16. Apr 19, 2025 at 9:51 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Double-checking my Haltech configuration, does this look right? The axes are limited to the number shown, so I can't add any additional values. I just want to make sure I don't screw anything up in the base configuration.
  17. Apr 19, 2025 at 10:43 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    I found out that with the Haltech in a piggy back configuration, the stock ECU still controls the throttle body. I'll need to keep it until I can test moving that functionality over to being controlled on the 2500.
  18. Apr 19, 2025 at 10:49 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    All good! Keep us posted on that trans upgrade. I’m curious how that Haltech does as well
  19. Apr 19, 2025 at 10:54 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Does anyone have information on our crank/cam trigger system? Haltech doesn't have ANY information for the 3URFE...I opened a ticket, and the dude said this was the first time he'd been asked about it. I should be able to figure it out with the Oscilloscope once I hook everything up but wanted to get as much configured as possible.
  20. Apr 19, 2025 at 11:26 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    Trans should be here Tuesday, then I can get the TCM removed and shipped out to CANTCU for bench flashing. The 8HP/CANTCU harness will be a few weeks, but I'll be waiting for the TCM as well so no rush there. I should be able to configure it at my desk before I get the harness.
    Here is the Boomslang wiring documentation, and some screenshots of what I have configured so far in the Haltech Elite 2500. Adjustments for fueling and dwell are specific to the 8AR coils and Five-O 750cc injectors. Knock frequency is based on 94mm piston size.
    **Note, I haven't adjusted any of the values in the base fuel or base ignition tables, only the axes for RPM and MAP**
    Saltyhero13, ARES35, ZPhilip and 4 others like this.
  21. Apr 19, 2025 at 11:45 AM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Off she goes with the mad scientist @snivilous
  22. Apr 19, 2025 at 11:58 AM
    bflooks
    bflooks New Member
    Metrowest MA
    So awesome!!
  23. Apr 19, 2025 at 12:26 PM
    AZTundra
    Paul
    Phoenix, AZ
    TRD air flow accelerator arrived today. Going to be installing this on the OEM lower airbox along with the SABM which is currently in route.
    e30cabrio, ARES35, Jego and 2 others like this.
  24. Apr 19, 2025 at 12:40 PM
    HulkSmurf14
    2014 Tundra Limited
    I sent my core back so...;) it'll happen soon and without notice...just be ready to throw it in!
    Mdl and Abell207 like this.
  25. Apr 19, 2025 at 12:42 PM
    ssmokedz
    Shelton CT
    Every Saturday that I work I have my lift available. I just worked today so hopefully it comes in before the next Saturday that I work!
    Mdl and HulkSmurf14[QUOTED] like this.
  26. Apr 19, 2025 at 12:42 PM
    HulkSmurf14
    2014 Tundra Limited
    It's good to see the toy hauling semi is in action!! She's a beaut!!
  27. Apr 19, 2025 at 12:44 PM
    centex
    centex New Member
    So I should be good with 12 quarts then?
  28. Apr 19, 2025 at 12:45 PM
    HulkSmurf14
    2014 Tundra Limited
    Yes sir, I feel you'll be good to go!
  29. Apr 19, 2025 at 1:35 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I used 18qts but I did a flush through the cooler line.
    HulkSmurf14 and centex[QUOTED] like this.
  30. Apr 19, 2025 at 1:56 PM
    centex
    centex New Member
    Not a bad thought but you also reminded me to grab the 90’s and delete the thermostat from the transmission since I’m going to be in there.
    Jego, bflooks and HulkSmurf14 like this.
