Amazing 1st Gen Headlamp Upgrade
Discussion in '1st Gen Tundras (2000-2006)' started by Neo, Jul 12, 2023.
  1. Apr 18, 2025 at 7:25 AM
    #421
    They were definitely a smidge low in that picture.
    While that method of using other vehicles will work to get the height right, it won't get the rotation right. Reply #61 of this thread (page 3) has a couple of videos on aiming. I did a basic variation on a wall to get there.
    Rotation-wise, if you know this, ignore, but you want your cuttofs to be horizontally linear flowing into each other like _____/ ¯¯¯¯¯¯¯¯¯¯/¯¯¯¯¯¯¯ and not like stairs. This is the best pic I've got of mine after aiming and rotating roughly correctt; ass-end of the truck is down in this pic so the aim appears a few inches high here.
    Dblock500[QUOTED] and Hutcheson like this.
  2. Apr 18, 2025 at 8:33 AM
    #422
    Dblock500
    Dblock500 New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
    I'll try to find a wall somewhere or something that I get 3ft in front of and close to 25ft back--have a couple places in mind give or take a foot or 2. And There is no horizontal adjuster on my year assembly, just the vertical slot for the philips head. Which means having to manually rotate the led itself by hand within the housing assembly? I saw others here have said colights are already pretty much centered
  3. Apr 18, 2025 at 9:07 AM
    #423
    Honestly, I used my garage. It's almost exactly as deep as the truck is long. If you can get it at 3ft and 10ft, that's probably sufficient. I know the recommendation is up close in the 3-5ft range and far out 20-30ft range, but frankly ... that's "ideal" while "good enough" also works.
    Dblock500[QUOTED] likes this.
  4. Apr 19, 2025 at 7:22 AM
    #424
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    :thumbsup:
  5. Apr 19, 2025 at 7:23 AM
    #425
    Dblock500
    DMV
    I'm an idiot, these are clearly the high beams that are on. Removing the passenger side resistor made the high beams stay on whether I switched the lights from highs to low. This picture shows the low beams on (really highs) with the fog lights on--switching to highs only shut the fogs off while the headlights remained the same. Putting the resistor back on and they worked properly again except that the passenger side light is still not putting out barely any light. Already contacted Colight but I'm considering more readily available mini projector options since the reflector is removed--don't feel like waiting days for the email exchanges w/COlight followed by waiting another week or 2 to get the replacements from China
  6. Apr 19, 2025 at 7:24 AM
    #426
    MT-Tundra
    Montana
    Finding a flat surface to park on, and a flat surface to project the headlights on, was my biggest challenge. Finally noticed a large cargo trailer parked in the work parking lot and ran over there one night to get mine dialed in.
    Dblock500 likes this.
  7. Apr 19, 2025 at 7:25 AM
    #427
    MT-Tundra
    Montana
    D'oh! Damn.
  8. Apr 19, 2025 at 7:41 AM
    #428
    Dblock500
    DMV
  9. Apr 22, 2025 at 9:32 PM
    #429
    jv384
    jv384 New Member
    2002 Regular Cab
    Bilstien shocks all around, wheels & tires
    TYC with ppf is best for longevity... late response lol but for anyone else wondering here u go. Amazon is nice because of return policy. I got a mirror instaid of a Tundra light so hastle free no questions asked
  10. Apr 30, 2025 at 4:46 PM
    #430
    Dblock500
    DMV
    My colight replacement bulb finally come in today. Will wait until the sun goes down to get pictures of both Y16s working properly but will adjust them later.
    For anyone planning on doing this upgrade, inspect both sides of the leds to make sure neither the highbeam or low beam are burnt out. See my photos of my passenger light led visibly burnt. Also a picture of the replacement new/good led for comparison.
    G_unit3000, Hutcheson and KNABORES like this.
  11. May 1, 2025 at 12:23 PM
    #431
    rouxster70
    rouxster70 New Member
    04ac2wdv65spd
    These just arrived from summit, $35 each. Are these ok housings to install? Thanks IMG_1556.jpg
    G_unit3000 likes this.
  12. May 1, 2025 at 12:27 PM
    #432
    My really cheap Amazonian housings (non-Capa) lasted about 3 years before the fading and yellowing began. I polished and ceramic coated them and got another year out of them. They are yellowing again.
    rouxster70 likes this.
  13. May 1, 2025 at 12:49 PM
    #433
    Eagle Eyes generally makes good stuff. DEPO, TYC, Eagle Eyes, and there's one other I always forget.
    If it's genuinely made in Taiwan as the box says, and not mainland China, that's in your favor. Taiwanese stuff is, and always has been, good stuff. It's the mass-produced mainland China garbage that tends to fall apart quickly.
    rouxster70[QUOTED] likes this.
  14. May 1, 2025 at 1:34 PM
    #434
    rouxster70
    04ac2wdv65spd
    Thanks y’all, finally a win. So next questions are the pass headlight is missing the boot and the connector is a little toasty. Is this something still available, are there upgrades to the boot or connector. I’ve read this thread 3 times and I’m still confused as what is a good headlight replacement or upgrade. I’m looking for something that is a known quantity of either replace or upgrade, a lot of this thread seems like conjecture or is hard for me to understand, I’m not the brightest bulb. thank you
  15. May 1, 2025 at 1:40 PM
    #435
    I think I’ve got some spare boots somewhere. I run the aftermarket upgrade harness to prevent plug burning like that and juice the lights up a bit more.
  16. May 1, 2025 at 1:42 PM
    #436
    rouxster70
    04ac2wdv65spd
    The headlights both work now. FYI. Thanks
  17. May 1, 2025 at 1:44 PM
    #437
    rouxster70
    04ac2wdv65spd
    May you elaborate as what is and where an upgraded harness may be found. I like Arkansas, but it’d be a drive. Thanks
  18. May 1, 2025 at 2:00 PM
    #438
    Found it
    The harness is available on Scamazon. Takes your factory light plug and adds a relay with dedicated power to the lights.
  19. May 1, 2025 at 2:03 PM
    #439
    rouxster70
    04ac2wdv65spd
    I’m
    Cool. I’ll look for the harness. Should I replace that toasty plug? I’ll hit up Toyota for some boots or just search, thanks y’all
  20. May 1, 2025 at 2:26 PM
    #440
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    If you decide to run the harness you won't be using that plug for anything anymore most likely. You'll only be using the driver side plug to control the relay harness.
  21. May 1, 2025 at 2:51 PM
    #441
    bfunke
    bfunke Tundra Curmudgeon
    Melted headlight electrical plugs are a big reality in the vintage Porsche community especially since many installed 100W halogens. Pelican and or there’s sell ceramic connectors that will fit your terminals.
    KNABORES and rouxster70 like this.
  22. May 1, 2025 at 2:53 PM
    #442
    bfunke
  23. May 2, 2025 at 6:12 AM
    #443
    Sirfive
    Sirfive Socially feral
    ‘02 Limited AC TRD
    Bassani cat-back
    Does anyone know if the ‘05-‘06 AC headlight housings have the same mounting points as the earlier trucks?
  24. May 2, 2025 at 6:14 AM
    #444
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    I can confirm the 00-04 and 05-06 turn signal housings are different.
  25. May 2, 2025 at 6:17 AM
    #445
    They adjust different too. @shifty` headlights have internal bulb angle adjustment, my 2000 moves the whole housing. Would love to swap to 2005+ housings for my next set. What’s the fitment issue with the corners @khooiii ??
  26. May 2, 2025 at 6:19 AM
    #446
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    The tabs that hold it against the headlight housing is different. You will break the tab on the headlight side before you get the turn signal to fit lol.
  27. May 2, 2025 at 6:20 AM
    #447
    Was that 05+ corners on pre 05 headlights?
  28. May 2, 2025 at 6:20 AM
    #448
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Still haven’t driven at night. Compliments of the baby, but yeah these are definitely brighter than the other mini projectors.
  29. May 2, 2025 at 6:23 AM
    #449
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Correct.
  30. May 2, 2025 at 6:24 AM
    #450
    Good deal. Hoping a whole 2005+ setup will work in a 2000
