General Supercharger Thread
  1. Apr 17, 2025 at 7:48 PM
    ARES35
    ARES35 New member for life
    Mile high
    I couldn't wait around, absolutely shifts are much better! Bites good now, reminds me of quick shifting a manual. Didn't get into the higher gears but 1st through 4th feel tight
  2. Apr 17, 2025 at 9:02 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
  3. Apr 17, 2025 at 9:12 PM
    Ctaylor76
    Ctaylor76 New Member
    Chaz
    Houston
    2021 Tundra Supercharged
    BDS 4.5 inch coil over lift BDS UCA’s 35 inch ridge grapplers AT 20 inch methods with offset 5.29 Nitro Gears ARB rear air locker with dual stage air compressor RC switch panel Both bumpers are RC LED Bumpers (6 pods and lower LED light bar) AMP Research power steps Lower RC Tow hooks B&M Transmission Pan CSF Radiator Radium Duel Catch Can BDS recoil traction bars Helwig adjustable rear sway bar Retrax Power Trax tunnel cover NSV LED front light bar Morimoto XB LED Head lights DOOD Rear smoked LED Tail lights (Amazon) NSLUMA Smoked 3rd brake light (Amazon) Morimoto 4 Banger LED A pillar lights Boostautoparts LED tow mirrors w/ power fold (smoked black) Full 3 inch true duel with XF Flowmaster mufflers custom Vbands Steelworks Longtube Headers RC seat covers OEM Audio plus full sound system duel sub 13 inch Phoenix Automotive In dash screen Stater X remote start system Uniden R8 Radar detector Odyssey Extreme Battery RC Seat Covers RC Rubber Mat Bed Cover Full body color door handles & TRD Grille OEM Magnuson TVS2650 Supercharger
    Yeah I need to do this to mine asap
    ARES35[QUOTED], Mdl and HulkSmurf14 like this.
  4. Apr 17, 2025 at 11:28 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Would like to know if anyone with a IPT/Level10 VB and a WAT VB owner meet up to check each other's out to see if they are comparable driving wise...
  5. Apr 18, 2025 at 3:05 AM
    bflooks
    bflooks New Member
    Metrowest MA
    I'm not sure if everyone has received theirs yet. I know I haven't. :pout:
  6. Apr 18, 2025 at 3:11 AM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
    Same, I sent them an email on Wednesday asking for an ETA but no response.
    ssmokedz, ARES35 and HulkSmurf14 like this.
  7. Apr 18, 2025 at 3:14 AM
    bflooks
    bflooks New Member
    Metrowest MA
    I'm going to assume we depleted their core supply.
    ssmokedz, Mdl, ARES35 and 2 others like this.
  8. Apr 18, 2025 at 3:15 AM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    I’m thinking the same thing. Do you have to return your stock VB or could people keep it and eat the $450 core charge?
  9. Apr 18, 2025 at 4:00 AM
    bflooks
    bflooks New Member
    Metrowest MA
    If you don't want the core charge back, you keep the core.
    Mdl, ARES35, Abell207 and 1 other person like this.
  10. Apr 18, 2025 at 5:07 AM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    For the guys who have changed out their VB’s, did you change your trans tune at all?
    HulkSmurf14 likes this.
  11. Apr 18, 2025 at 6:14 AM
    ARES35
    Mile high
    If anyone locals to me, Denver area I'm willing to test.
    Mdl[QUOTED] and HulkSmurf14 like this.
  12. Apr 18, 2025 at 6:16 AM
    ARES35
    Mile high
    With the short drive last night I did not tune any of the Trans tables. Albeit didn't do WOT runs.
  13. Apr 18, 2025 at 6:23 AM
    HulkSmurf14
    2014 Tundra Limited
    Nope! If anything, it feels better with the transmission stuff that was done previously from OvT...
    reywcms, ARES35 and Abell207[QUOTED] like this.
  14. Apr 18, 2025 at 6:32 AM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    Okay I wasn’t sure if we had to dial anything back within the tune with the new VB.
    HulkSmurf14[QUOTED] likes this.
  15. Apr 18, 2025 at 6:48 AM
    ARES35
    Mile high
    Oh just a heads up to make life easier when refilling the trans. All the transfer pumps out there are shit imo. So went with simple funnel through engine bay with 5/8" outside diameter hose. 5/8" fits the Trans fill hole tight making it easier to fill quickly. May save some unnecessary waste of time using a pump
    Abell207, HulkSmurf14 and e30cabrio like this.
  16. Apr 18, 2025 at 6:50 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    My transmission is stock but on the highway, it seems to not be regularly shifting to 6th (rpms are not super high, just feels not up there) If I shift to S, it is at 4th & I have to bump the shifter 2x to get 6th.
    Is that normal?
    Also, while I am waiting for the new motor, I am installing AEM water/meth injection in the BMW, I have Boost Juice, do I dilute it with distilled water or run it 100%?
    https://www.amazon.com/dp/B079HHYDTR
    Abell207, HulkSmurf14 and ARES35 like this.
  17. Apr 18, 2025 at 6:51 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I'm just curious as a mofo....:p
  18. Apr 18, 2025 at 6:55 AM
    ARES35
    Mile high
    Are you on a flat or hilly? Mine will downshift to 5th dependent on terrain it seems. And 4th in S at higher speeds
  19. Apr 18, 2025 at 6:55 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Not sure about shifting to 6th but going to 4th is normal. The boost juice is already mixed at 51/49(w/m). You can cut it with distilled water for 60/40 or 70/30 if interested but 50/50 is standard. 100% can be dangerous and caustic to certain parts
  20. Apr 18, 2025 at 6:59 AM
    e30cabrio
    At the time I noticed it, I was in the middle of the desert about 100 miles before Az, it's pretty flat. I guess it is just me. lol
    Thanks MDL on the boost juice info!
  21. Apr 18, 2025 at 7:07 AM
    blenton
    blenton New Member
    I do the same thing, or if the bottle accepts a fill top cap, I just plug that straight in to the line from the engine bay. Works a charm.
    I was going to ask if your transmission was warming up (it will refrain from overdrive if not warm) but remembered that you live immediately adjacent to the surface of the sun…
    Curious what the motor and trans temps are when it does that? I don’t recall my tree holding gears when we drove 8 of 18 hours hours in 110+ temps on the freeway.
    On the tundra at highway speeds on a windy day (or pulling a trailer), it will hold overdrive gears until engine load gets above -3. Somewhere between -3 and +2psi it will downshift. But I’m at altitude and much further from the surface of the sun.
    ARES35[QUOTED] and HulkSmurf14 like this.
  22. Apr 18, 2025 at 7:15 AM
    e30cabrio
    I was 5 hours into the 7+ hour return home. As a rule, the trans is 195-203, and the engine is 200-208. The ambient was about 95. I was averaging 75-80 when not getting around asshats that furnish the passing lane.
    There was a stretch where the right lane sucked & all the fucking semis were in the passing lane, lots of frustrated passing then.
  23. Apr 18, 2025 at 7:44 AM
    HulkSmurf14
    2014 Tundra Limited
    That is normal...it's annoying for sure. On trips or longer hauls around, I throw it in S6 and it does fantastic...but I'm not sure if that hurts anything...I dis this for a year prior to the VB upgrade. Still, in D, it only goes into 6th if I'm above 78mph...it is normal to throw it into S and start in S4...I do the same with the quick taps to S6...nuances of the truck but perfectly normal.
    e30cabrio[QUOTED] likes this.
  24. Apr 18, 2025 at 7:47 AM
    HulkSmurf14
    2014 Tundra Limited
    Good call and I forgot to suggest...transfer pu.os are still annoying and messy...I bought 10ft of 1/2" ID tubing and a right-angle barbed fitting and threw a funnel on...made it so much easier to fill. Cost me $18 at Ace Hardware for that easy button!
    ARES35[QUOTED] likes this.
  25. Apr 18, 2025 at 7:52 AM
    centex
    centex New Member
    Run it as is. It’s already mixed.
  26. Apr 18, 2025 at 7:56 AM
    centex
    centex New Member
    Truck defaults to 4th when you move the shifter to S mode. That’s normal. If you are running 75mph and go from D to S, you should feel a big downshift and the rpm’s should shoot up.
    My truck will go into 6th at around 50mph so if you are at highway speeds you should definitely be in 6th gear.
  27. Apr 18, 2025 at 8:47 AM
    e30cabrio
    Thank you gentlemen! Having just replaced all the fluid & the torque converter, I'm sensitive to it's behavior, on my 185k 2010 Crew Max, I killed the transmission 2k after 2 drain & fills.
  28. Apr 18, 2025 at 9:26 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    remember overfill is good on these from what we've heard
    HulkSmurf14 and Abell207 like this.
  29. Apr 18, 2025 at 10:40 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    1/2 to a quart. No more than a full quart after the trickle.
  30. Apr 18, 2025 at 11:45 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I did a 5k mile drain and fill on mine this past weekend. It seemed like an awful lot of fluid came out. I didn't measure it, I just drained it into one of the big pans at work that hold like 30 quarts. My memory says that I may have been nearly a quart over, but this time I refilled with 4.5 qts and called it good, I didn't bother with the trickle shenanigans. It actually shifts much better, particularly what used to be the hard 1-2 shift. That mellowed markedly, same with a vast majority of the F-R transitions. I ain't touching it for another 5k.
