Increase the Turbo Sound?
Discussion in '3rd Gen Tundras (2022+)' started by AWDDude, Jan 15, 2023.
  1. Apr 14, 2025 at 6:31 PM
    #91
    Daedalus
    Daedalus New Member
    Only happens when throttle plate closes.
    Otherwise you will have compressor surge.
    PNW Tundra Mike likes this.
  2. Apr 14, 2025 at 6:47 PM
    #92
    Foster1
    Foster1 New Member
    2023 TRD Off Road
    I’m just running the TRD air filters. They increased the turbo noise a noticeable amount without being annoying.
    Tom976 likes this.
  3. Apr 14, 2025 at 6:54 PM
    #93
    Frank_TRD23
    Frank_TRD23 New Member
    Frank
    2023 Tundra TRD Mag grey
    1.5 Wescott lift 20" wheels on 37s Stillen Trucontroller
    Guy at work has a ecoboost f150 and has some wastegate. Makes me wanna get one. Then drive the roads where hookers hang out and say psss all around town.
  4. Apr 15, 2025 at 6:00 AM
    #94
    Daedalus
    Daedalus New Member
    Wastegate is in the exhaust, this is on the charge pipe, pressure section.
    Two different things. Wastegate controls boost with reference to MAP and MAF sensors, along with throttle position and load calculations.
    Recirc/diverter valve, dumps metered pressurized air back into the charge pipe system to keep from screwing up fuel trims.
  5. Apr 15, 2025 at 6:12 AM
    #95
    Frank_TRD23
    Frank
    In a way it is a waste type valve. I just couldn't remember the BOV name!!!
  6. Apr 15, 2025 at 1:08 PM
    #96
    559Tundralona
    559Tundralona New Member
    Alex
    Fresno
    2023 Ice Cap Tundra Limited TRD OR Hybrid
    Diamondback switchback Eibach Pro-Lift Rays Gram Lights 57DR-X 17x8.5 +0 YotaLEDS grille lights Tufskinz overlays
    Agreed, Turbosmart is top notch. Had one on my old Mazdaspeed3.
    Daedalus likes this.
  7. Apr 16, 2025 at 9:39 AM
    #97
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    As you can see here, when 4 and d Open they allow exhaust (d) to bypass the turbo straight to the Cat and on the compressor side (4) to go back around to the intake.
    Linuxrules and oddhours like this.
