HOW TO: Wire up your LED/aux lights to work with CAN-BUS driven hi/low/parking headlights.
Discussion in '3rd Gen Tundras (2022+)' started by 99ways2die, Jul 20, 2022.
  1. Apr 9, 2025 at 6:55 AM
    #91
    Noobo Baggins
    Noobo Baggins New Member
    Glenn
    2025 Platinum Lunar Rock
    OE 3" Lift, 35" BFG KO2
    I appreciated your input on not interrupting the signal to the fog lights and I would have had to interrupt both.
    I was able to do it with just a signal from one of the fog lights by incorporating the light bar relay into the plan. (see post above).
    And yes, I would never use parking / taillights as a power source for the light bar. The original diagram that I posted literally said "To Light Bar Relay #86". I thought it was obvious that relay would have it's own proper power source. Suppose I should have specified that.
    In the end, I tapped the positive wire to the fogs and the parking light feed at the tailight. No too invasive considering I was willing to tap the high beam signal if there was one. I think people are tapping into the taillight for the lighted rear fender flares so same same.
  2. Apr 12, 2025 at 6:57 PM
    #92
    Spacecowboy863
    Spacecowboy863 New Member
    great post! thanks for the write up
  3. Apr 14, 2025 at 9:06 AM
    #93
    Noobo Baggins
    Glenn
    Next level would be a switch on the dashboard to interrupt power to the lightbar. (I would use another relay)
    This would allow normal headlight functions while having the lightbar off.
    I could easily add the switch but I like the fact that I didn't have to go thru the firewall or under the dash to this point.
    So yes, code officially cracked, light bar function with high beams ... without a $120 Canbus reader.
    Really no downside to this method if you use a switch.
  4. Apr 14, 2025 at 11:57 AM
    #94
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    While the dual relay works, it does not replace the canm8 functionality. The canm8 functions independent of fog light status. In my case, the high on signal from canm8 routes to a dash enable switch then to relay to drive the light bar. When switch depressed, light bar can only come on with highbeam. Often, if I'm in a urban area, I'll have my fogs off to reduce reflections. The dual relay approach as described will have the lightbar on with low beam by default. This drives adding a on/off switch that you must remember operate when you turn the fogs off. With canM8, not need to remember turning high beam switch on/off.
    For clarity, the cost is greater than the canm8 alone. Waterproof connectors (weatherpack or metri), fused terminal block and quality relays, lined shrink are not trivial $$.
    99ways2die[OP] likes this.
  5. Apr 15, 2025 at 3:15 PM
    #95
    Noobo Baggins
    Glenn
    That's the advantage to adding a switch (which usually comes with the light bar anyway). You can run headlights without fogs and without the light bar by cutting power to the light bar with the switch.
    So no drawback function wise
    As far as the cost, does the cambus reader eliminate the need for a waterproof relay with waterproof connectors? Fused terminal block? No other wiring, loom, ties, connectors needed?
    I can list the components that I used that didn't come with the light bar and it literally would be about $20-$30. Although the components may not be up to your standards if you're spending $35 on a relay and adding a fused terminal block for whatever reason.
    I won't go so far as to say the cambus reader is a waste of money. It definitely makes the job faster/ easier ... but there is another way if someone wanted an option.
  6. Apr 15, 2025 at 3:55 PM
    #96
    jctmundra
    Northern VT
    With the canM8, don't need to remember to use a switch to kill the lightbar when fogs are off which is important to me as I'm not the only one driving the vehicle.
    With the canM8, at least my install, the wiring is interior, waterproof would not be required. I did use a fuse block as I also run puddle lights and compressor. They are loomed and shrink wrapped. Lightbar came with a weatherproof pigtail.
    CanM8 may not be faster install as carefully opening the dash for install is not trivial.
    The relay solution is novel and will work for some, but it's not the same function a canM8 provides.
    Noobo Baggins likes this.
  7. Apr 15, 2025 at 5:37 PM
    #97
    99ways2die
    99ways2die [OP] New Member
    NJ
    2022 Tundra Platinum
    Relax kids.
    We're slowly turning this into a pissing match, for no good reason.
    ( I can easily say "well, if your fog light circuit blows a fuse/etc your lightbar is rendered useless; if your truck never came with fog lights what would you do?...etc")
    Both solutions achieve the same outcome; thank you for sharing your approach as a viable alternative to the CANM8 device/solution.
    We could argue benefits of one vs another approach for some time, and ultimately it's up the user/installer to decide which "system" they want.
    IMO the "double relay/fog lights" method is basic, in design/execution.
    CANM8 is "advanced" as I see it.
    Last, but not least example and something to consider:
    Most (perhaps) ppl in this thread as interested in "light bar ON when high beams ON" solution, but as I exemplified before, the multiple output CANM8 device is awesome for anyone (me, for example) that wants to use other "triggers" from the truck's lighting system for additional functionality.
    Instead of running multiple "double relay" solutions (or who knows what other ways to get a trigger), I love the fact that a single small box can simply read the truck commands and give me "high beams ON, low beams ON, parking lights ON, etc" outputs.
    Through 1 easy solution I have long range light bar on with high beams, aux/amber fogs with low beams ON, and could have used other outputs for a myriad of applications.
    To each their own I guess...
    -99
    Noobo Baggins and jctmundra like this.
  8. May 8, 2025 at 1:51 AM
    #98
    beer30
    beer30 New Member
    Hooked up a Deutch connector for integration, haven't had a chance to install yet though.
    I have an sPOD BantamX, so I wanted to take advantage of the triggers.
  9. May 8, 2025 at 6:26 AM
    #99
    99ways2die
    NJ
    I like pro-level wiring jobs; boys @ the dealership always appreciate "professional" wiring and never give me any hard time about all of my aftermarket wiring/accessories.
    sudobash likes this.
  10. May 8, 2025 at 6:28 AM
    #100
    beer30
    beer30 New Member
    I'm a controls engineer, so I have to somewhat make it look good and function correctly.
    I can't stand some of the way stuff is slapped together.
  11. May 19, 2025 at 5:53 PM
    #101
    Trunty
    Trunty New Member
    I wanted to propose another method of solving this, though will only be applicable to TRD-PRO folks. First, thank you to @99ways2die for this post and sharing. This helped me a ton as I was looking to solve how to upgrade the factory TRD-PRO light bar, without losing the functionality. After realizing the factory light bar uses CANBUS signals and has generally constant 12V, I realized it only made sense that the factory light bar must have an embedded CANBUS reader. I was able to find a cracked light bar on ebay, disassemble it, and confirm this. I separated the logic board and put it in a waterproof project box and used the signal the logic board was sending to the embedded light bar, to trigger my relay. Overall very clean and maintained the functionality I wanted! Sharing is caring, in case it's helpful to anyone else.
    t300 and Tundrastruck91 like this.
  12. May 19, 2025 at 7:29 PM
    #102
    99ways2die
    NJ
    Nice work MacGyver.
    Now we know who to call when the real Zombie Apocalypse happens!
    :D
  13. May 19, 2025 at 7:44 PM
    #103
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    Are you planning to pick up your connection behind the glove box or somewhere else? I've got my reader I just haven't hooked it up yet.
  14. May 21, 2025 at 6:57 AM
    #104
    beer30
    beer30 New Member
    Behind the glove box, I've had my dash apart so many times already. It's not a big deal anymore.
  15. Jul 11, 2025 at 12:19 PM
    #105
    tundradoan
    tundradoan New Member
    Hello All,
    I have the 2022 Platinum with the premium headlights. I've recently installed the TRD Pro marker lights on the TRD Pro grill and also the TRD Pro fender flares. The lights are tapped into the fuse but I really only want the marker lights on at night only. I used the Rave OffRoad wire harness/kit to install the fender flares and the front marker lights. Currently they are power on all the time but I think they should only come on at night.
    Do I use the canm8 high beam to see the signal from the low beams? I though this only reads the high beam signal? What would I need to read only when my headlights come on? Also does that mean if I flash my brights, will the marker lights flash since the low beam is on/off?
    Sorry, I'm still learning about wiring and electronics so not 100% confident in my skillset yet.
  16. Jul 11, 2025 at 12:38 PM
    #106
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    Order the IDR8 from the same website, it's a bit more expensive, but will give you 8 different CAN based outputs, including "running lights" which is what you'll want
  17. Jul 11, 2025 at 1:32 PM
    #107
    tundradoan
    Thank you for this. I saw this option to from OP but wasn't 100% sure if that was cleared. Thank you for clarifying running lights as low beams.
  18. Jul 11, 2025 at 1:49 PM
    #108
    tundradoan
    Outputs - Standard IDR8
    Speed Signal > 12v square pulsed output at approximately 4 pulses per 1 MPH.
    Ignition On > 12v (1A max) when the ignition is switched on.
    Left Indicator > 12v (1A max) when the left indicator is active.
    Right Indicator > 12v (1A max) when the right indicator is active.
    Service Brake > 12v (1A max) when the brake pedal is pressed.
    Dipped Beam > 12v (1A max) when the dipped beam is active.
    High Beam > 12v (1A max) when the high beam is active.
    Side Lights > 12v (1A max) when the side lights are active
    Which one is consider the running light output?
  19. Jul 11, 2025 at 2:12 PM
    #109
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    "Side lights' should equate to running lights. Or you could go with "Dipped beam" which is low beams
  20. Jul 15, 2025 at 9:05 AM
    #110
    Noobo Baggins
    Glenn
    Not 100% positive, but I think that you could tie into the taillight to get what you are looking for.
    The only way that wouldn't work is if the taillight comes on with the daytime running light ... which I don't think it does.
    By tapping in at the taillight, the grill and flare TRD Pro marker lights would come on the same as they would had the truck come equipped with them.
  21. Jul 15, 2025 at 9:26 AM
    #111
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    Best way is to get a 7pin to 4 pin and make your own harness. Super simple. What I did and they act as oem
  22. Jul 15, 2025 at 10:36 AM
    #112
    Noobo Baggins
    Glenn
    Good idea ... so long as it doesn't cause the truck to think there is a trailer plugged in.
    Sometimes that will affect the function of the backup sensors.
    I've used these adaptors before to provide a hidden plug and play connection to the trailer wiring; Putco #529004
    With this adaptor you would tie into the brown wire for marker lights.
    t300 likes this.
  23. Jul 15, 2025 at 10:44 AM
    #113
    Ipaddick
    Ipaddick New Member
    Canada
    It doesn’t. I have it. Along with a vled plate and hitch pod and diodes reverse kit. It know when a trailer is connected and not. Never have it thinking there is one when there isn’t.
    t300 and Noobo Baggins[QUOTED] like this.
  24. Aug 1, 2025 at 4:56 PM
    #114
    tundradoan
    Thank you everyone for your input and helping out an electrical noob like me.
    An update on my Platinum:
    I finally got all the parts in and was able to start doing the install. I went with the 7pin to 4pin harness and the rear are wired up with the fenders like OEM. The marker lights only come up on when its night time (low beams).
    The front fenders is a different story. I certain I have to get the CanM8 IDR8. Currently they always on no mater time of day.
  25. Aug 1, 2025 at 5:36 PM
    #115
    Ipaddick
    Ipaddick New Member
    Canada
    Why not run the wiring up to the front? That’s what I did.
  26. Aug 1, 2025 at 6:08 PM
    #116
    tundradoan
    I'm trying to get the OEM look where the marker lights are not on 100% of the time. What's the opinion on marker lights on all the time?
  27. Aug 1, 2025 at 6:16 PM
    #117
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    CANM8 IDR8 like you stated is probably the quickest, shy of running the trigger from the back to the front
  28. Aug 1, 2025 at 7:31 PM
    #118
    Ipaddick
    Ipaddick New Member
    Canada
    I agree. Mine are all wired up to act like oem. Wire the front up from the rear.
