2003 Tundra OEM Fob search
Discussion in '1st Gen Tundras (2000-2006)' started by badbob, Apr 13, 2025.
  1. Apr 13, 2025 at 12:39 PM
    badbob
    badbob [OP] New Member
    Robert
    Rural Oklahoma
    2003 Tundra V8 4WD Regular Cab SR5 Phantom Grey w/tan interior 210k miles
    None
    I've got one fob and its on it's last leg, only one button works. Does anyone know an affordable source for factory installed fobs for 2003 tundras?toyota fob.jpg
  2. Apr 13, 2025 at 12:41 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
  3. Apr 13, 2025 at 12:54 PM
    ATBAV8
    ATBAV8 New Member
    Tempe, AZ
    Haven't tried for my Tundra, but I did find some for my 2001 Isuzu Trooper on Ebay that worked well. I would like to find OEM for the Tundra, but I kind of think that ship has sailed.
  4. Apr 13, 2025 at 1:23 PM
    badbob
    Robert
    Rural Oklahoma
    None
    just got two for 30 bucks thanks
  5. Apr 13, 2025 at 1:47 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Not that you would but don’t throw away the case that still has a good key ring intact.
  6. Apr 13, 2025 at 3:30 PM
    badbob
    Robert
    Rural Oklahoma
    None
    Oh definitely AND it has the FCC ID on the back
  7. Apr 13, 2025 at 4:22 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I got mine on eBay. Make sure the FCC ID matches, AND that it has the little tiny LED above the lock button.
  8. Apr 13, 2025 at 7:43 PM
    And when you need programming instructions, the ODFs and instructions are in the megathread.
  9. Apr 13, 2025 at 7:49 PM
    Dook55
    Dook55 RCLB Guy
    Montana
    My 2006 didn't come with a fob because it's a base model. When I bought my 2004 it came with a fob and I don't know if it works, never tried it. I tossed it in a kitchen drawer and forgot about it. I can't imagine why anyone would want to carry that bulky thing in their pocket.
  10. Apr 13, 2025 at 8:04 PM
    badbob
    Robert
    Rural Oklahoma
    None
    Ok these don’t have the little led but it says they will work with the fcc id. Hope they work
  11. Apr 14, 2025 at 1:39 AM
    w666
    Maryland
  12. Apr 14, 2025 at 4:57 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
  13. Apr 14, 2025 at 5:31 AM
    badbob
    Robert
    Rural Oklahoma
    None
    That is my fcc ID, the pic looks the same as the ones I ordered from eBay. Did you’re original fob have the led on it?
  14. Apr 14, 2025 at 5:59 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    No fobs when I bought the truck. Cleared the keys and reprogrammed both new fobs without any issues.
  15. Apr 14, 2025 at 7:21 AM
  16. Apr 14, 2025 at 7:23 AM
  17. Apr 14, 2025 at 4:05 PM
    w666
    Maryland
    I don't know...I bought a new one (aftermarket) with the same FCC ID, but no LED (I knew not nor cared not at the time). I tried to program it on and off many times, but could just not get it to work. I presumed that was because the memory was full (4 fobs max), and I'd have to blow it away to reprogram the one OEM fob I had, along with the new eBay model. Since I had one that worked, I was reluctant to erase them all and wind up with none. Finally I got the courage to blow away the memory, and add them back. By this time I was so good at the programming sequence I could do it from memory! The OEM fob connected on the first try, but the new one (no LED) did not, even after many, many tries over several days. I gave up in disgust! Later, I read somewhere (not here) about the LED, so I bought a used OEM fob on eBay for ~$30. It worked on the first try!
    I don't know why this is, and since I now have two working fobs I don't need to understand (my little brain is already full of other stuff). I'll gladly send it to you, or anyone else who's willing to try.
    shifty`[QUOTED] likes this.
  18. Apr 23, 2025 at 9:50 AM
    badbob
    Robert
    Rural Oklahoma
    None
    Damn. Just got them today and no led light like the factory but they programmed fine on the first try. I lucked out!
    shifty` likes this.
  19. Apr 23, 2025 at 2:51 PM
    I think @w666 may've just gotten a bad fob or something? Super weird.
    w666 likes this.
  20. Apr 23, 2025 at 3:31 PM
    w666
    Maryland
    Indeed! I still offer to send it to anyone willing to have a go...
