General Supercharger Thread
  1. Apr 12, 2025 at 2:05 PM
    ARES35
    ARES35 New member for life
    Mile high
    NatesNightMare and HulkSmurf14 like this.
  2. Apr 12, 2025 at 2:21 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I think a small hole in the piston or so my might’ve heard some pinging but thought it was heat shield rattle on the headers which I fixed but seems may have been some pinging maybe a failed ring
    HulkSmurf14 likes this.
  3. Apr 12, 2025 at 2:53 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Performance MRP makes custom length and diameter straight tubes but it may not be any help to you. If I recall the Manusons dont go straight in.
    LILTRD[QUOTED] and HulkSmurf14 like this.
  4. Apr 12, 2025 at 2:56 PM
    mustang67408
    Victor
    Hot dry place in Nevada
    I'd post some better hobby porn, but its not toyota related..Dont want to get kicked out of this forum..
  5. Apr 12, 2025 at 3:44 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Dont worry...This forum circles around to all kinds of stuff.
  6. Apr 12, 2025 at 3:45 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Hows it going?
    ARES35 and HulkSmurf14[QUOTED] like this.
  7. Apr 12, 2025 at 4:43 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    So I got her all done and buttoned up...it definitely took me 4 hours at least...but I'm happy! The new pan is a beast and I've opted to not throw on my cat shields until my next oil change in a couple thousand miles...those took me longer to take off than I'd like to admit! I only used and needed 10quarts of fluid through the whole project. A lot continues to come out once you remove the VB...it's an f'n mess but kitty litter kept it mostly contained.
    Driving impressions: f'n legit! Solid shifts, and they don't hang or make me want to curse if I was on the phone. It just feels like good, clean shifts. It definitely tightened up what I experiencing as slop. Gear engagement from Park is quiet and no longer clunks (thus far) and full WOT runs did nothing but make me smile...definitely holds so much better. Had I known about these VBs earlier in my ownership, it'd been the first thing I do.
    I also spent a few minutes putting this in:
    Thank you @memario1214 for the light!!
  8. Apr 12, 2025 at 4:48 PM
    centex
    centex New Member
    We’ve seen a Mustang, a cyclone, and a Porsche so far. Clearly we are enthusiasts.
  9. Apr 12, 2025 at 4:50 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    How many miles on your truck? Any trouble getting the pan bolts out? That is the only part I’m not looking forward to.
    Mdl and HulkSmurf14[QUOTED] like this.
  10. Apr 12, 2025 at 4:55 PM
    ARES35
    Mile high
    Badass, nice work cant wait to dig in! I see Montana also....that's where i was born and raised :cheers:
    HulkSmurf14[QUOTED] likes this.
  11. Apr 12, 2025 at 5:05 PM
    HulkSmurf14
    2014 Tundra Limited
    I crossed over 106,664 miles and had zero issues with bolts anywhere on the disassembly. I did do a fluid swap at 80k with new filter so I'd imagine that's a bonus for today's work and no stuck bolts. They only have like 39 inch/lbs of torque so they aren't hard to pop off with an impact driver. You got this...I was dreading doing this but man, that video that WAT did was super helpful! Just remember, their "driver's side" is opposite of us NA owners! I used x4 cans of brake cleaner to get the bell.housing and bits factory clean, and one in the existing VB to send back...to WAT or Cruisers, I know not, yet...
    Montana for life! HS in AK and I've lived here on either side!
    All I know is this VB upgrade (Extreme version) is a huge, noticeable driving improvement!
  12. Apr 12, 2025 at 5:18 PM
    ARES35
    Mile high
    Good to hear on the pan bolts, mines the remanufactured so fingers crossed that they come easy. Great falls for me and HS in Billings. I'll be heading to Billings in July
  13. Apr 12, 2025 at 5:25 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    You guys should really invest in the all new exhaust I’ve made now includes oil inside
    Tripleconpanna, centex, Mdl and 3 others like this.
  14. Apr 12, 2025 at 5:26 PM
    HulkSmurf14
    2014 Tundra Limited
    Come west a couple hours and I'll buy you some beer! I'm in Bozo!
    ARES35 and reywcms like this.
  15. Apr 12, 2025 at 5:35 PM
    ARES35
    Mile high
    Yes sir ol Bozeman! Shit I'll probably go fishing, if I'm West I would for sure swing by!
  16. Apr 12, 2025 at 5:40 PM
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    Stoked to hear this! I went with the extreme version too. Now if the darn thing just ships already lol. Thanks for the write up!
  17. Apr 12, 2025 at 5:55 PM
    centex
    centex New Member
    Heard the oil helps lubricate the air and makes it flow better.
  18. Apr 12, 2025 at 6:08 PM
    mustang67408
    Victor
    Is that a PML transmission pan?
    I love it
    HulkSmurf14[QUOTED] and Mdl like this.
  19. Apr 12, 2025 at 6:09 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Nice! Always got a fly rod in the truck for any chance of hitting the water.
  20. Apr 12, 2025 at 6:30 PM
    HulkSmurf14
    2014 Tundra Limited
    Yes sir, it's a PML transmission pan...got it in the GB deal a few months back. B&M also has a great pan available that @reywcms is rocking with success!
    reywcms and mustang67408[QUOTED] like this.
  21. Apr 12, 2025 at 7:15 PM
    mustang67408
    Victor
    My next project for the tundra..
    Thanks..
  22. Apr 12, 2025 at 7:29 PM
    mustang67408
    Victor
    But have you seen. CH4D, RCBS, Redding... ECT..
  23. Apr 12, 2025 at 7:30 PM
    bflooks
    bflooks New Member
    Metrowest MA
    You might want to go through a few of your recent videos and take a look at your WOT pulls. I feel like after seeing this video, she may have been hurt before today. I assumed it was just exhaust condensation somehow tied to the dumped exhaust, but now Im here writing this.
    Doesn't change anything, but might help narrow down when it started and what you recall the baseline being before hand.
    Mdl and HulkSmurf14 like this.
  24. Apr 12, 2025 at 7:31 PM
    HulkSmurf14
    2014 Tundra Limited
    All VB core exchanges go back to Cruisers...FYI...Johnny is a badass and a valued member of our community!
    Mdl likes this.
  25. Apr 12, 2025 at 7:44 PM
    ARES35
    Mile high
    Yes sir I throw on the rod vault during camping season:cheers:
    HulkSmurf14 and Mdl[QUOTED] like this.
  26. Apr 12, 2025 at 8:58 PM
    mustang67408
    Victor
    Does anyone make a "shift kit"? Rather than having to buy a whole VB..
    I'd rather do it myself..
  27. Apr 12, 2025 at 9:09 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    I also think that it may have been hurt before this as well. Would explain the plugs going bad causing the no crank issue etc.
  28. Apr 12, 2025 at 9:10 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
  29. Apr 12, 2025 at 9:12 PM
    mustang67408
    Victor
  30. Apr 13, 2025 at 5:22 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I doubly feel your pain (triply?)
    I took the BMW motor to the builder, I melted somewhat every piston & a piece of a valve!!!
    On the happy news, on the 765 mile round trip I averaged 15mpg, best tank 18 (I filled up by 1/4-1/2 trying to get as many samples as possible. worst 9.
    The Sequoia ran great!
    I left the house thinking hypermiling, made it 20 miles before an asshat was furnishing the fast lane & that was it. On the trip, I pissed off 2 F150s a twin turbo AMG Mercedes and a fuhraz 370z. :D
