Replacing rear wheel bearings
Discussion in '2nd Gen Tundras (2007-2013)' started by FuegoMCS, Nov 17, 2024.
  1. Nov 17, 2024 at 1:38 PM
    FuegoMCS
    FuegoMCS [OP] New Member
    East Texas
    2011 Crewmax 2WD
    Does anyone know what book or the expected cost would be for replacing a rear bearing? I have a 2011 CrewMax 2WD (186k miles) with a clicking right rear wheel. I've already replaced both front wheel bearings on my own within the past year, and do as much DIY maintenance as I am comfortable with. I don't have a torch or a press to attempt to remove and replace a rear wheel bearing from the hub/shaft. YouTube videos on the subject have me convinced to let a shop/pro do the work. TIA
  2. Nov 17, 2024 at 5:28 PM
    TomsTundra
    TomsTundra New Member
    2011 DC 4.6L AT 4WD SR5
    blackdemon_tt and FuegoMCS[OP] like this.
  3. Nov 17, 2024 at 6:28 PM
    koditten
    Kirk
    Midland of the Mitten
    I just did my buddy's '09 last week. Both rear bearings cost $850.
    If you can do brakes, you can do wheel bearings.
    Unbolt the axle flange and slide out the axle. Take the assembly to your automotive machine shop and have them press off the old bearings and press on the new bearings.
    This is exactly what your dealer shop will be doing.
    The axles slide into the differential with a little fiddling. No need to open up the diffy.
    My bud got quoted $3500 for the bearings. It is steep, but you are paying for the truck to be on a hoist overnight. No chance for the dealer to get income from that hoist for 24 hours. I have no issue with the dealership quoting those numbers. They need to stay in business.
    FuegoMCS[OP] and blenton like this.
  4. Nov 17, 2024 at 7:01 PM
    TomsTundra
    Thats reasonable, Parts and machine shop labor for completing both axels ?
    koditten likes this.
  5. Nov 17, 2024 at 7:09 PM
    koditten
    Kirk
    Yes. This also included the cost for 4qts of mobile 1 gear lube. Figured why not change the gear lube as it had 300k miles on the truck.
    TomsTundra[QUOTED] likes this.
  6. Nov 18, 2024 at 10:14 AM
    FuegoMCS
    East Texas
    2011 Crewmax 2WD
    Thanks for the feedback. It's interesting that replacement axle, and repairs to the existing would be approximately the same cost. I had considered removing the axle(s) and taking them to a shop along with replacement Toyota bearings and let them do the hard part. Now I need to to find a reputable shop here in Tyler (East Texas) for this.
  7. Nov 18, 2024 at 11:52 AM
    koditten
    Kirk
    Any automotive machine shop can do this job. Let them source the bearings as well.
  8. Nov 18, 2024 at 11:55 AM
    TomsTundra
    I assume the parts quality is comparable but who knows for sure.
    I havent decided to go that route as yet. I will call you for a tow if my axel snaps late one night lol
  9. Nov 18, 2024 at 12:51 PM
    koditten
    Kirk
    I figured rear wheel bearing failures were so common, I wanted anything else other than OME.
  10. Nov 18, 2024 at 2:27 PM
    FuegoMCS
    East Texas
    2011 Crewmax 2WD
    I'm going to let a reputable local shop diagnose before I invest in a hub bearing or replacement axle and go from there. That shop will R/R the hub if I bring the axle to them but their labor plus the bearing and two replacement oil seals is getting close to the cost of the Dorman assembly from RockAuto above. In the meantime I found that RockAuto has really great pricing on replacement Stabilus hood struts and the tailgate support strut so taking care of those too.
  11. Nov 18, 2024 at 3:49 PM
    koditten
    Kirk
    Sounds good, but anything involving Rock Auto or Doorman is my last " go to" supplier. If I'm flipping the rig, no problem.
    I drive my trucks to 300k miles before selling. I want quality, not the best price.
  12. Nov 18, 2024 at 8:02 PM
    lr172
    lr172 New Member
    07 DC
    More expensive is not always better. I just did rear bearings. Bought bya brand from rock auto for $90 each. Bearing are stamped “koyo”. Same place Toyota gets them, but $750 cheaper . I bought a carrier bearing fro RA, spicer brand, which is where Toyota gets them. It was badged with “Toyota “. Exact same part at 1/4 of the cost.
    Yes, a lot of stuff out there is a lesser quality, but certainly not all of it! And sometimes cheap is ok. Broke a wheel speed sensor doing the bearings. Toyota wants over $200 for one. I got a pack of four from Amazon for $28. It can fail 4 times and still be money ahead. Now, obviously i did that because replacement takes 5 minutes. Wouldn’t go that way with a rear bearing that takes half a day.
    Yakisoba likes this.
  13. Nov 18, 2024 at 8:05 PM
    lr172
    lr172 New Member
    07 DC
    Or buy a 20 ton press from HF for $200 and do it yourself. Good learning experience and save thousands. It is not all thar difficult to press the bearings on and off.
    koditten[QUOTED] likes this.
  14. Apr 12, 2025 at 9:38 AM
    Yakisoba
    Yakisoba New Member
    NC
    2010 Dbl Cab SR5 4.6
    Anyone have p/ns for the following:
    Rear Axle Shaft Oil Seal
    O-Ring
    Rear Axle Shaft Snap ring
    Rear Axle Bearing Inner Retainer
    Rear Axle Shaft Washer
    Rear Axle Hub and Bearing Assembly (Drivers & Pass)
    Am I missing anything for a Rear bearing replacement?
  15. Apr 12, 2025 at 12:01 PM
    Yakisoba
    Yakisoba New Member
    NC
    @lr172
    What adapters in addition to the press did you need to remove/replace the bearing?
  16. Apr 12, 2025 at 12:09 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, DIY Traction Bars, Tuning by snivspeedshop.com
    Yakisoba[QUOTED] likes this.
  17. Apr 14, 2025 at 9:25 PM
    Yakisoba
    Yakisoba New Member
    NC
    @FuegoMCS
    My right rear bearing is on the way out.
    Local shop quoted me $950.
    Dealership quoted me $2000 (My Tundra is a pre-April 2010 build and dealership "has" to perform the TSB for the backing plates.)
    Option I'm exploring is buying parts, pulling the axle, and taking it to someone with a press (4WD or driveline shop).
  18. Apr 15, 2025 at 4:33 AM
    koditten
    Kirk
    That's what I do. I've done it twice.
    I do both sides, just for the piece of mind.
    It was $1200 for everything.
    Pull the axle assemblies and run them down to the local automotive machine shop.
    I don't know what the backing plate recall work you needed done, so that may change things a little.
