JBA UCA's arrived/ install
Discussion in 'Suspension' started by OBXTundra, Oct 18, 2017.
  1. Dec 11, 2017 at 4:09 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    I have the same UCA's. I got 3.4 and 3.7, left to right, for my caster. The guy said that's as high as he could get it. The JBA's just come with a new set of inner washers, so you maintain the factory washers on the outside. It's a very well made product. For those that aren't going uniball, I'd definitely recommend JBA.
  2. Dec 11, 2017 at 4:37 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Thanks! What’s your wheel/tire setup and do you clear the cab mount easily?
  3. Dec 11, 2017 at 5:08 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    I have Method NV's with 25mm offset and STT Pro's in 295/70R18. I clear the cab mount with about 1/2" of room at the closest point. Mudflaps are removed.
    BlueBottle[QUOTED] likes this.
  4. Dec 11, 2017 at 6:40 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Thanks bud.
  5. Dec 11, 2017 at 6:48 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    No problemo!
  6. Dec 12, 2017 at 12:59 PM
    OBXTundra
    OBXTundra [OP] Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Clear cab mount easily. Could get a little more caster on each side with a little more work. These settings kept everything else in check and the truck drives perfect.
    You reuse stock outside washers, not a big deal.
    I'm really pleased with these and they've been on a few long road trips now. All around handling is better.
    Krewcial, equin and BlueBottle like this.
  7. Jan 20, 2019 at 1:59 PM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    I know its a pretty old thread but any updates on the upper control arm now since you have had them for awhile? Looking to maybe order some asap
    OBXTundra[OP] likes this.
  8. Jan 20, 2019 at 3:16 PM
    OBXTundra
    Southeast USA
    My only issue was the original ball joints had surface rust on them within 6 months. This was an issue with the clear powder coating.
    JBA made good on this and sent me a set of the new Cerakote'd ball joints for free. They did that for anyone that wanted to swap them.
    All the new UCAs have the Cerakote'd ball joints. Everything else about the UCAs are perfect.
    Krewcial and equin like this.
  9. Jan 20, 2019 at 4:32 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Nice looking setup!
  10. Aug 27, 2019 at 3:01 PM
    smalls_ADV78
    smalls_ADV78 New Member
    This is one of the threads I researched when looking for UCAs. Just wanted to update and add to it. Got the JBAs on today. Very nice and customer service was spot on. Plus the red matches my red caliper cover from the XSP package.
    equin, Krewcial, TRDblvd and 3 others like this.
  11. Nov 30, 2021 at 1:15 PM
    Tundra___myboiBlue
    Tundra___myboiBlue New Member
    2011 Tundra Natuical Blue
    6"RC - 35"X12.50 R20 XD Rockstar
    Does anyone know if these JBA'S will work with 6" Rough Country lift with coil overs???
  12. Dec 6, 2021 at 5:56 PM
    Chuck1188
    Chuck1188 New Member
    Charles
    2016 TUNDRA BLACK SR5 CM 4WD
    If I remember correctly, these are made for 0”-3” of lift
  13. Dec 6, 2021 at 6:06 PM
  14. Apr 11, 2025 at 7:02 PM
    therealjonwick
    therealjonwick New Member
    JR
    2019 OR
    I have zone control arms and am switching to JBA. Think I can use the zone washers and be fine? Also, what did you have to move on the passenger side to get at the bolt in the engine bay? Thanks!!
  15. Apr 11, 2025 at 7:07 PM
    I'll have to look tomorrow but there are a couple harness clamps that need to be opened so that you can move the harness. If you start sliding the bolt out you will easily see what is in the way...it's not bad at all.
  16. Apr 12, 2025 at 9:21 AM
    therealjonwick
    JR
    2019 OR
    Got it done. Wasn’t too bad. Thanks for the tips.
    Tundra234[QUOTED] likes this.
