General Supercharger Thread
  1. Apr 11, 2025 at 1:19 PM
    blenton
    blenton New Member
    Magnusson was also 6 weeks out last I checked. Harrop proper said to have kits on the shelf but all stage 1. For stage 2 there was a non-specified wait.
    Tundra Texan, ARES35 and HulkSmurf14 like this.
  2. Apr 11, 2025 at 1:34 PM
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    No need to buy stage 2 from Harrop. Just order a 80mm pulley and some DW650's. All Harrops really need a custom tune regardless
  3. Apr 11, 2025 at 1:35 PM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Harrop stage 2 is only a smaller pulley choice and injectors, no tune included. Get a stage 1 kit, pick out a pulley, source your own injectors, get a tune. Up and running in a weekend.
  4. Apr 11, 2025 at 2:37 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Setup and ready for tomorrow's VB upgrade!
  5. Apr 11, 2025 at 2:45 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    A lift, a giant trampoline, and a syclone? This guy knows how to party
    nags, Tundra Texan, pvmike and 9 others like this.
  6. Apr 11, 2025 at 2:54 PM
    HulkSmurf14
    2014 Tundra Limited
    It's still kinda winter...trampoline and Sy need outta the shop!
    ARES35 and Silver17 like this.
  7. Apr 11, 2025 at 3:13 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Sick syclone! Why have we not heard about this before!? Can’t wait to hear about your VB thoughts.
  8. Apr 11, 2025 at 3:24 PM
    centex
    centex New Member
    What are yall doing for fuel pumps? Specifically the folks running higher boost pressures.
  9. Apr 11, 2025 at 3:29 PM
    Silver17
    Eastern PA
    If yours is an FFV I wouldn’t bother, but if the time ever came I believe the Ti/walbro 267 (450lph) is a drop in for the FFV basket. Otherwise, the deatschwerks 300C 340LPh has been plenty adequate for most it seems.
  10. Apr 11, 2025 at 3:32 PM
    HulkSmurf14
    2014 Tundra Limited
    I have the DW300c in mine in preparation for the Sniv party pulley...I'll also be throwing in the DW650cc injectors to help feed it...
    ARES35 and snivilous[OP] like this.
  11. Apr 11, 2025 at 3:34 PM
    centex
    centex New Member
    It is a flex fuel. Reason I’m asking is I may be bumping up against the limits of my stocker (still testing). I remember reading somewhere about tricking the second pump on a flex fuel to turn on or maybe I’m thinking of a different pla
  12. Apr 11, 2025 at 3:38 PM
    HulkSmurf14
    2014 Tundra Limited
    I've been a huge Sy/Ty fan forever! That's actually one of my best bud's BaT wins that he's working on telling his wife about...next week I'll have a true gem of a Sy in the shop...Busch Racing block (4.5l v6), forged crank, 88mm turbo and boasting 1237whp on e85...she's coming in from NY and I'm holding it for another old college buddy while he makes his way down from AK to trailer it back...
    I'm anxious to see how the VB upgrade does and feels, myself!
  13. Apr 11, 2025 at 3:38 PM
    Silver17
    Eastern PA
    Every boosted FFV owner should probably read this thread. https://www.tundras.com/threads/5-7-supercharged-e85-fuel-system-diy-project.101526/#post-2605294
    Supposedly the FFV pump is 375LPH, so it should be adequate. The DW 340LPH has been fine even on ~600whp supercharged builds.
  14. Apr 11, 2025 at 3:42 PM
    carn_dogg
    carn_dogg i don't think so
    Pat
    Eastern Shore MD
    2013 Black Tundra Platinum
  15. Apr 11, 2025 at 3:43 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    Did you set it up so it's always in high pressure mode?
    ARES35, HulkSmurf14, Mdl and 3 others like this.
  16. Apr 11, 2025 at 3:44 PM
    mustang67408
    Victor
    Hot dry place in Nevada
    My truck is FFV , stock maggy and 7.1 psi. I am using the stock FFV pump, but I did bypass the F/PUMP VSV RELAY. I basically jumped pins 5 and 3 to keep the fuel pump on HIGH at all times. The stock FPR is also boost referenced. They only have 1 pump.
    ARES35, HulkSmurf14, Mdl and 4 others like this.
  17. Apr 11, 2025 at 3:46 PM
    centex
    centex New Member
    No I didn’t.
    Looks like I have some reading to do. I am running dw650’s in the truck. I’ll take at look at this stuff. Thanks y’all.
  18. Apr 11, 2025 at 3:48 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I had 2 out of the box bad 450s, & Walbro's customer service was a joke. DW 300 doing just fine for me.
  19. Apr 11, 2025 at 3:51 PM
    snivilous
    SW UT
    Also make sure you always check the ethanol content. I swear every time I tune a new FFV truck the ethanol is all sorts of fucked and always becomes a recurring problem. Just started tuning a dude a couple days ago, ethanol at 89% out the gate, and on low pressure mode thing is leaning out by like 4psi and can't hold 12:1
    Mdl, ARES35, HulkSmurf14 and 2 others like this.
  20. Apr 11, 2025 at 3:53 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Just to chime in on the tarrif stuff. In my job, we import server/networking equipment. It isn't the tarrifs holding things up. It's the new regulations and confusion at Customs and Border Protections needing more paperwork verifications on Country Of Origin Certificates. On every part in a shipment. And then you have to pay holding fees for the amount of time it sits in their storage before they'll release it.
  21. Apr 11, 2025 at 3:54 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Ugh. I remember being on vacation in Disney last year obsessing over fuel pumps and injectors for Stage 1, including if the FFV pump and green injectors were the answer. Happy with where I ended up, but I forget how much reading and learning this thread has caused.
    @centex you might also want to find and favorite the "conversion from FFV" thread (or whatever it's actually called) if you haven't seen it. It's a good read along with the how to recover/replace a bricked ECU.
    Hopefully you'll never need the latter, but it's good background to the have before it is needed.
  22. Apr 11, 2025 at 3:56 PM
    snivilous
    SW UT
    That's the great thing about your new engine, you can just assume literally everything is undersized now and needs to be replaced :D
    Wynnded, ZPhilip, ARES35 and 4 others like this.
  23. Apr 11, 2025 at 3:57 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Bro. What engine??? It's not even machined yet!! :(
  24. Apr 11, 2025 at 4:00 PM
    snivilous
    SW UT
    "New engine" is universally past, present, and future tense :D
    "The new engine is crazy"
    That could be a year old engine, this instant, or what has yet to be completed :D
  25. Apr 11, 2025 at 4:01 PM
    bflooks
    bflooks New Member
    Metrowest MA
    I hate your positivity. There was supposed to be a :D after this line.
  26. Apr 11, 2025 at 4:09 PM
    centex
    centex New Member
    Yes it was at 85% before I started. Last I checked a couple weeks ago it was 25% so I reset it. Mine hasn’t had issues running lean until I got into the 6psi range. Been solid in the mid 11’s. This week the weather started bumping 90’s and what we found was in the morning I’d have an extra .5psi or so and I’d be in the mid 12’s but in the afternoon I’d lose that .5psi and AFR’s would be back in mid 11’s. Jesse rescaled the MAF this afternoon as I was maxing it out. Need to try another run and see what happens and then flip this pump to high mode permanently.
    ARES35, Silver17, HulkSmurf14 and 3 others like this.
  27. Apr 11, 2025 at 4:10 PM
    blenton
    blenton New Member
    True. I think it’s also needs a fuel pump. My luck would be the injectors would get backorder for a year though.
    Just saying that no matter what I’m looking for, it’s always backordered or build/ship date gets pushed. Doesn’t matter what company - whipple, Magnuson, Bilstein, Toyota, whatever - my stuff ALWAYS gets delayed. Heck, Alcon took an extra three months to get my brakes to me because of a bracket. It’s like the check out line at the store: it doesn’t matter if there’s one person or ten people in line, my line is gonna be the slowest… :(
    HulkSmurf14 likes this.
  28. Apr 11, 2025 at 4:12 PM
    e30cabrio
    My next new engine is ready to become....
    See the red thing just past the motor? It's my stand, he has 12 & they are full.
    Good news is I go to the front of the class.
  29. Apr 11, 2025 at 4:17 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, solid Offroad engine mounts, DIY Traction Bars, Tuning by snivspeedshop.com
    https://www.tundras.com/threads/supercharger-running-lean.140825/page-5#post-3568593
  30. Apr 11, 2025 at 4:21 PM
    centex
    centex New Member
    Good Saturday morning reading. Thank you.
