  1. Apr 9, 2025 at 9:51 AM
    Sirfive
    Sirfive Master Procrastinator
    ‘02 Limited AC TRD
    Bassani cat-back
    Couldnt fit my ceiling with the foam, so just bubblewrap & cardboard for now.
    Now to figure out curtains.
  2. Apr 9, 2025 at 9:54 AM
    front bumper is a replacement that was finished in black, but I need to refinish it. Back bumper was chrome, got scuffed, etching primed and bedlinered. Mirror caps were factory body color painted (limited) but faded and got wrapped, that faded, then wrap removed, scuffed, primed and bedlinered. Same for side trim. All the badging got plastidipped.
    Dblock500[QUOTED] and oscardog86 like this.
  3. Apr 9, 2025 at 9:54 AM
    @des2mtn has some tricks for curtains
    Nicklovin likes this.
  4. Apr 9, 2025 at 10:12 AM
    Wrap is a temporary fix with future pain. Just gonna get it painted.
    khooiii and The Black Mamba like this.
  5. Apr 9, 2025 at 10:40 AM
    Dblock500
    Dblock500 New Member
    DMV
    2002 SR5 AC 4.7 V8 4WD
    Nice, I'm definitely planning on bedlining mirror caps and side trim at the least
  6. Apr 9, 2025 at 10:47 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Washed it. Tried the H4 headlight harness with the colight projectors. Not a huge difference if I’m going to be honest. New CAPA cert headlight housings went in. Just waiting on the clear corner lights. I’ll probably hang onto the black housings and colight just in case I don’t love this rabbit hole I’m going down. lol.
    Hutcheson, abcinv and BroHon like this.
  7. Apr 9, 2025 at 10:50 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Only thing that has kept me from running these is that I figure the stick won't last forever and they'll be drooping down at some point. For $33 I probably should just give it a go (I don't need the fancy colors)
    jerryallday likes this.
  8. Apr 9, 2025 at 10:50 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Paint > wrap every single time.
    KNABORES[QUOTED] likes this.
  9. Apr 9, 2025 at 10:53 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    Prep with isopropyl alcohol or glass cleaner - never use a detailer. Grab a can of adhesion promotor (I believe these come with a little swab of them?) then install. The adhesion promotor basically turns it into super glue and is way more resilient to heat and the adhesive failing.
  10. Apr 9, 2025 at 10:53 AM
    I did these in 2019. So 6 years later they look like this. A little fade, but not much chipping really.
    Dblock500[QUOTED] and khooiii like this.
  11. Apr 9, 2025 at 11:01 AM
    It’s nice to have the option to dim and switch between regular white light, and green or red for the conditions. When we park before dawn on hunting trips the red or green on dim helps preserve night vision.
    Also, I just stuck mine up there and they have been great. Comes with what looks just like the 3M trim and body tape on the back. If you have carpeted headliner, you can put Velcro on the back instead.
  12. Apr 9, 2025 at 12:35 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    My new Denso radiator is supposed to arrive sometime tomorrow.
    MooreKen, Nicklovin and KNABORES like this.
  13. Apr 9, 2025 at 12:38 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    Finished the airbags.
    I didn't think about the plastic over the bumper...but this'll work.
    And I almost forgot I had done this while I was in temporary self-exile. I could not get the damn front diff drain plug out. Took it to a friend's who welds, figuring we'd weld a nut onto it. But this tool was all it took.
    Installed this while I was there. I love the concept, but I don't love how far it hangs down. Hopefully it's never an issue.
  14. Apr 9, 2025 at 12:53 PM
    oscardog86
    oscardog86 New Member
    Southern California
    I have a fumoto drain plug valve. Hangs a little low too, but with an aftermarket oil pan skid, its a non issue.
    MT-Tundra and 455h0le_dachshund like this.
  15. Apr 9, 2025 at 1:06 PM
    NickB_01TRD
    KY
    Good tips. Hadn't given any of that much thought. The inside of my topper looks like bare fiberglass but it might be coated I'm not for sure of the top of my head, that probably isn't the best surface for adherence.
    Yeah I see your point about color, I probably won't even use mine much honestly. For only $10 more though it might be worth it.
  16. Apr 9, 2025 at 1:07 PM
    Every time you open it at night, it’s 100% worth it.
  17. Apr 9, 2025 at 1:11 PM
    NickB_01TRD
    KY
    KNABORES likes this.
  18. Apr 9, 2025 at 1:27 PM
  19. Apr 9, 2025 at 2:12 PM
    Nicklovin
    Nicklovin Yap Yap
    Huntington Beach, CA
    00’ 4.7 AC 4x4
    Interesting. Funny how it’s usual the first year of a new model that has a problem, not this where it’s better than the rest… at least for the LBJs haha
    Used JB weld on a radiator leak before and never thought about it again… works well sometimes :anonymous:
    Oooo nice. I was just over at a Joann’s looking at fabric options. Thinking I might use a little wood rod and some Velcro for curtains
  20. Apr 9, 2025 at 2:27 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    I JB Welded it before lunch today.
    The new unit comes in sometime tomorrow, so we postponed our wrenching plans til next week. Apart from putting off crucial mods for T2S, it's actually going to be better for both us of to wait.
  21. Apr 9, 2025 at 3:21 PM
    Dakillacore
    Georgia
  22. Apr 9, 2025 at 6:47 PM
    jerryallday
    jerryallday New Member
    Jerry
    Pasadena, Ca
    2006 DC SR5 V8 Grey
    I bought the same lights, cut them to size and glued them to the lip on my back window using E6000.IMG_5778.jpg
  23. Apr 9, 2025 at 7:08 PM
    Dblock500
    DMV
  24. Apr 9, 2025 at 7:11 PM
    Dblock500
    DMV
    Replaced the struts on the shell. Is it ok that the news ones are a couple inches shorter?
    Nicklovin and Filthyphil like this.
  25. Apr 9, 2025 at 7:11 PM
    My 2019 had the carpet and the velcro. It was money.
  26. Apr 9, 2025 at 7:12 PM
    If you're happy with how it works, then it's fine.
    Dblock500[QUOTED] likes this.
  27. Apr 9, 2025 at 7:16 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    As long as you’re happy with how high your backglass extends then you’ll be good.
  28. Apr 9, 2025 at 7:24 PM
    I'm kinda pissed I went with heavier-duty ones. I've banged up my back window's lower aluminum panel because I failed to catch it a couple of times now, and it smacked into the garage door. It opens pretty violently. I think I'd prefer going several pounds less force, and about an inch shorter.
  29. Apr 9, 2025 at 7:38 PM
    455h0le_dachshund
    Reverend Hotdog
    TX...big surprise
    Have you tried only using one strut?
    I got too heavy duty of struts too, so I kept one worn out one and replaced the other. It still has plenty of power.
    Iirc I got 38lbs and I should've gotten 30lbs. I definitely feel like mine should've been an inch shorter as well.
    oscardog86 likes this.
  30. Apr 9, 2025 at 7:42 PM
    I dunno if my OCD would allow me to do that.
    But yeah, similar story. I got the 35lb and I think I should've gotten the 28.
    Dakillacore and oscardog86 like this.
