Front Sway Bar Delete?
Discussion in '3rd Gen Tundras (2022+)' started by TheManderson, Mar 17, 2023.
  1. Mar 21, 2023 at 10:48 AM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    Nope, Ironman... cheapos (relatively)... setup in sig. Blasting across the desert whoops isn't something I've tried. I doubt the IMs cool well enough to do that for long periods. Plenty of washboard and rough dirt though.
    alb1k[QUOTED] likes this.
  2. Mar 21, 2023 at 10:50 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    It would be nice to run those real whoops fast, but that’s another ballgame all together…
    rruff[QUOTED] likes this.
  3. Mar 26, 2023 at 2:54 PM
    Efreet6669
    Efreet6669 New Member
    '07 Limited Red Salsa Pearl,'23 TRD Pro Solar Octane
    This was one of the most interesting threads I’ve read. Thanx all
  4. Mar 27, 2023 at 11:25 AM
    trailhunters
    trailhunters New Member
    Time for someone to come out with quick disconnects!
    Tundratic and alb1k like this.
  5. Aug 21, 2023 at 12:39 PM
    AND
    AND New Member
    Washington, PNW
    CAn you post some pics of the front, interested because front end links also act as steering stops.
  6. Aug 22, 2023 at 8:42 AM
    mass-hole
    mass-hole New Member
    Why not leave the rear bar connected to force the IFS to do more of the heavy lifting?
  7. Jan 14, 2024 at 7:18 AM
    Strider Wolf
    Strider Wolf New Member
    2016 Tundra Platinum 4x4
    LED swap, topper, ceramic 15% tint fronts, limo for backs and topper… more to come!
  8. Jan 14, 2024 at 7:24 AM
    Strider Wolf
    Just got a 2016 Tundra 4x4, live in CO and been reading up on all of this…. I watched Tinerer’s vid and found it quite informative.
    I am curious who’s added a rear and taken off the front sway bar? What’s that ride like. I’ll admit, I know it’s a big truck, I get it, but if a rear sway bar tightens up the roll and a front delete keeps articulation, I’d be interested.
    on another note, mine is stock now. In 2-3 years I’ll likely do a 2” lift and level, slightly taller tires and a leaf add. Do folks doing this need and extension or shim addition? I’ve seen both, I just don’t want to attach a rear sway bar to the side of the rear axle.
    and for note, I do 95% city driving, no towing but appreciate the beast mode button, and do 12-20 trips to the mountains for mild dirt road 4x4ing for hunting and camping. Clearance is my only concern with the sway bar TBH.
    thanks all!
  9. Jan 14, 2024 at 7:36 AM
    AND
    AND New Member
    Washington, PNW
    You might get your answer sooner if you post this on the 2nd gen side of this forum. You posted this on the 3rd gen forum. The 3rd gen comes with both front and rear and I can say that removing the front swaybar works perfect
  10. Jan 14, 2024 at 7:53 AM
    Strider Wolf
    Ha! Thanks and apologies! But appreciate your input!
    AND likes this.
  11. Jan 14, 2024 at 11:07 AM
    ArBrnSnpr
    ArBrnSnpr New Member
    Colin
    22' AG SR5 TRD OR
    In my GX470 I ran no front with a rear, no rear with a front and no sway bars at all. It was decent off-road, but not enough of a benefit to justify the atrocious on road handling.
    I ran Icon 2.5 external resi shocks and 2.5 Radflos aldo and neither shock improved things.
    There's lot of guys with far more engineering knowledge than I have that suggest the sway bar does more to keep a wheel in contact with the ground, then no sway bar does because it's applying downward pressure, not just allowing the wheel to droup lower.
    I may be wrong, but in my experimentation, leaving both bars on provided the best results.
    dhsmith06 and Strider Wolf like this.
  12. Jan 14, 2024 at 12:27 PM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    Leaving both bars on for pavement, yes. But for off-road removing at least the front on ifs suspension allows better articulation to keep tires in contact with the ground.
    Strider Wolf likes this.
  13. Jan 14, 2024 at 1:12 PM
    ArBrnSnpr
    Colin
    22' AG SR5 TRD OR
    CaptRussia253 and Strider Wolf like this.
  14. Jan 21, 2024 at 9:08 PM
    rruff
    rruff New Member
    Who are these "lot of guys"?
    Sway bars are an extra spring that resists independent suspension motion of each wheel on an axle. It offers no resistance to wheels moving up and down in unison, just when one wants to go up and the other down, relative to the frame. Since that is basically what articulation *is*, and the sway bar is resisting it, then I don't see how it can be an aid for keeping wheels on the ground. It's good for flatter cornering though.
    Tinker's findings with the rear swaybar are due to the solid axle rear having a lot less resistance to articulation than the IFS front. I think. There is probably something to be said for having front and rear articulation stiffness in balance, if maximum articulation is your goal. And on our trucks there is very forward weight bias which factors into it.
    I have a loaded camper on my truck now, with still no sway bars. It still handles just fine on the road, with no issues at all exceeding the speed limit on twisty mountain switchbacks and freeway onramps. A little lean sure, but very secure feeling, no wallowing or tire squeal.
    My truck is the older model, but I think the new ones would naturally have less articulation, because they have torsionally stiff fully boxed frames (yes, my frame articulates!) and come with swaybars front and rear.
  15. Oct 13, 2024 at 1:12 PM
    Tundra694
    Tundra694 New Member
    AJ
    2021 Tundra Crew Max Trd Off Road
    I’m running 6112s. Anyone have experience with the handling after removing the sway bar when using Bilstein 6112s?
  16. Oct 13, 2024 at 1:44 PM
    rruff
    rruff New Member
    I'd expect it to be fine since those have digressive damping and probably a good amount of it.
    The swaybar is easy and quick to remove or install, so just try it and see what you think.
  17. Oct 13, 2024 at 1:57 PM
    Tundra694
    AJ
    Yea my 35s are kissing the bar and I always kick around just removing it.
  18. Apr 9, 2025 at 9:18 AM
    dhsmith06
    dhsmith06 New Member
    Tundra 2012
    I removed my bar last week and its going back on for now. I already fight a vibration issue but the cheap rough country 3.5 struts up front dont keep the tires grounded for highway speeds. I do like the feel of it gone in a lot of other aspects - a bump on the right side doesnt make the whole truck feel it, it feels more free but it multiplies the vibration i have from 58-68. I can get to 70 and it be good but at 75, the typical truck shutter kicks in. Rebuild drive shaft and balanced. new cv shafts, rear bearings and seals, 2nd set of tires. Not the TC but could be trans as more prevelant in 5th\6th. Dont feel a thing under 50. The after market shaft does the typical vibrations\shakes. That whole discussion is for and on another thread lol.
    My current SB bushings were hard as a rock\dead along with back shocks (just ordered the 2" 5100's to help with that). After sway bar delete, I went a had tires balanced and new alignment yesterday along with a new tire to replace one that was chopped up from the front fender well.(prev owner cut into frame and body for tire size) No help with ride this morning. My feet are falling asleep with my seat vibration at the speeds mentioned above. Have to fix the one of the bolts that got stripped and stuck inside the frame when removing nut before re-adding bar.
    Add photos of my 4wd blender. lol
