Marker Lights for a 2024 Tundra Limited TRD 4x4
Discussion in '3rd Gen Tundras (2022+)' started by CorpsMarine, Apr 20, 2024.
  1. Jan 28, 2025 at 11:55 AM
    swen0332
    swen0332 New Member
    MN
    2022 Tundra SR5 TRD Sport - Army Green
    Old thread - but I looked for this for a while and finally found it. Here is the part number you need if you want to make your own harness to plug into the factory raptor grille marker lights. 90980-12416
    Noobo Baggins likes this.
  2. Apr 8, 2025 at 9:25 AM
    Noobo Baggins
    Noobo Baggins New Member
    Glenn
    2025 Platinum Lunar Rock
    OE 3" Lift, 35" BFG KO2
    Anyone tap into this harness yet for a marker light feed? For the grill lights or fender flare lights.
    Wondering if it's that dang canbus that doesn't give 12v ... or is the canbus just for the headlights?
  3. Apr 8, 2025 at 10:40 AM
    kjinxx2
    kjinxx2 New Member
  4. Apr 8, 2025 at 2:18 PM
    Noobo Baggins
    Glenn
    The code is cracked for "Light Bar to High Beam" ... (without the $120 canbus reader). Total cost was about $20.
    2 standard relays, wire, loom, connectors, wire ties.
    Installed, tested, and it is working as it should.
    The light bar will always come on with parking light, low beam, or high beam ... until the fog lights are turned on.
    So if you leave your fog lights on, the light bar will be off with low beam ... and turn on with high beam (since the fogs auto shut off with high beam)
    I can also use the light bar with low beam by turning off the fog lights.
    I did have to source the parking light signal at the tail light as I have the canbus style LED headlights. There may be a better option that I'm not aware of.
    See diagram below:
  5. Apr 8, 2025 at 2:20 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
  6. Apr 8, 2025 at 2:28 PM
  7. Apr 8, 2025 at 6:02 PM
    lapoolboy
    lapoolboy New Member
    Well I never....
    ToyoMafia[QUOTED] likes this.
  8. Apr 8, 2025 at 6:11 PM
    ToyoMafia
    Magic carpet.
    Leave it to me.
  9. Jul 20, 2025 at 12:44 PM
    cynicalbard
    cynicalbard New Member
    For anyone that cares: SR5 with the heritage grill. Installed OEM marker lights using the ROR harness with no issues. Used the Eng-Ing-01 fuse.
    Was it Expensive? Yes.
    Waste of money? Yes.
    Does it look awesome? Yes!
    5/7 would do it again.
  10. Jul 22, 2025 at 9:23 AM
    Noobo Baggins
    Glenn
    I can almost imagine what it looks like.
