Removing factory rails in center console
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Frestyl06, May 29, 2019.
  1. May 29, 2019 at 6:10 PM
    Frestyl06
    Frestyl06 [OP] New Member
    2019 trd pro
    I recently purchased an after market center console organizer for my 2019 pro and was wondering if anyone had any tips on how to remove the factory rails in the console. There are 4 rivets in front and 4 rivets in back. Or is the only option to drill them out?
  2. May 31, 2019 at 11:11 AM
    1811 Tactical
    1811 Tactical 1811 Tactical ®
    Mississippi
    2019 Tundra TRD Pro
    I used a chisel and hammer, came right out. Installed a console safe.
  3. Jun 4, 2019 at 5:15 AM
    EglSctAndy
    EglSctAndy MGM Crüe
    Andrew
    Arizona
    2019 MGM Crewmax TRD Sport
    Icon Stage 5 17” Icon Rebound Wheels TOYO Open Country A/T 35 12.5 RCI Heavy Duty Side Step Weathertech Mats 4” Stubby Antenna Fyre Flys Interior LED Lights Plastic Dipped Badges Decked tool box Baja Designs Squadron Sport fog lights
    1811 - this is probably a dumb question but I’ve already had one “simple” mod backfire on me so I figured I’d ask before screwing something else up. Did you place the chisel right behind the rivet or behind the rail itself? Also, would drilling them out work too as the OP suggested?
    Btw....how do you like the console vault? I picked one up yesterday from a private seller for only $150 and it has the upgraded 4 combo lock. Pretty excited to get this thing installed.
  4. Jun 8, 2019 at 10:43 PM
    Frestyl06
    2019 trd pro
    Worked perfectly. Thank you for the advice!
  5. Jun 21, 2019 at 8:17 AM
    1811 Tactical
    Mississippi
    2019 Tundra TRD Pro
    Yes behind the rivet, couple of taps and the head comes right off.
  6. Aug 3, 2020 at 2:26 PM
    NUMB LOCK
    NUMB LOCK Perpetual Member
    Northern VA
    2016 MGM TRD Pro
    Fox 3" lift, Methods, 35" A/T Baja Boss, Retrax Pro XR, Baja Designs light bar, Warn winch, Chaos Fab Shop tire carrier
    I used a chisel to remove the rivet heads but now what’s left of the rivets fell into/behind the console wall. Shall I be concerned of these sharp things falling onto something underneath or not to worry? I guess I could start pulling things apart to find them.
    BigWheel likes this.
  7. Jan 9, 2021 at 10:55 AM
    Frosty
    Frosty New Member
    2020 Super White CM
    I had to drill these out. I couldn't get a chisel seated on the rivet. Worked like a charm.
  8. Apr 8, 2023 at 7:53 PM
    BigWheel
    BigWheel New Member
    Anyone ? I am concerned about the same. Don’t need these things rattling around or damaging something.
  9. Apr 8, 2023 at 8:00 PM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler, FRAC, RCI Skid
    Finally... someone else has ran into this problem, my console safe has been sitting on my workbench without a home because of this aftermarket add. I would like to remove and looks to be some good advise in here.
    Thanks all.
  10. Apr 8, 2023 at 8:01 PM
    BigWheel
    BigWheel New Member
    Let us know what happens when you pop the rivet heads off.
  11. Apr 8, 2023 at 8:06 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    It'll probably be a few days, but I'll try and report back.
  12. Apr 8, 2025 at 6:10 AM
    TundyManFL
    TundyManFL New Member
    2021 MGM TRD Pro CrewMax
    Same question: about to drill out these rivets but don't want the ball end of the mandrel popping off and rattling around. Not worried about damage but rattling sounds drive me nuts.
