Toyota OEM TRD Front Recovery Hooks
Discussion in '3rd Gen Tundras (2022+)' started by RatPanda, Nov 12, 2024.
  1. Mar 21, 2025 at 8:16 AM
    #301
    Outbound
    Aaron
    Northern Alberta
    I may have missed it in the thread, but has anyone in Canada gotten their hands on these yet? If so, how bad was the pricing?
  2. Mar 21, 2025 at 8:56 AM
    #302
    lavey
    lavey New Member
    2025 Magnetic Grey Tundra TRD PRO
    I got mine for $520.70 pretax here in SA.
    I haven't finished the build as I cross threaded this, like 1/4 of an inch(part number 90119-A0443). Nvm, was able to fix it.
    air23cpt likes this.
  3. Mar 28, 2025 at 1:33 PM
    #303
    air23cpt
    air23cpt New Member
    2025 Tundra Limited Crew Max TRD Off Road
    Nice... I'm going to install later today. Did you have to make any cuts or did everything good without cutting?
  4. Mar 28, 2025 at 2:49 PM
    #304
    lavey
    lavey New Member
    No cutting at all but make sure you place alot of painter's tape around the inner edges of that new front bumper valance replacement as seen in the picture i previously posted.
    Steps I did with installation.
    1. Remove old valance cover.
    2. Remove old front mount brackets and old stabilizer bar brackets.
    3. Install new front mount brackets.(#3 and #4 in the installation picture using #9 flange bolt) Make sure it is torqued to specs.
    4. Partially place the new stabilizer brackets with one loose #11 bolt at the posterior end of it with no washer)
    5. Replace new valance cover and make sure to place painter's tape at the edges and where you deemed it's needed.
    6. Align and pass through the recovery hooks through new valance cover holes. It is a very tight fit, that the plastic may stretch while pushing through it. Be careful!
    7. Place the new #11 bolts with #12 washers now on your #5 and #6 recovery hooks and torque to specs.
  5. Mar 28, 2025 at 3:06 PM
    #305
    air23cpt
    air23cpt New Member
    Thanks lavey for the fast reply. Appreciate the info.
  6. Mar 28, 2025 at 3:19 PM
    #306
    lavey
    lavey New Member
    You're welcome. Additional info, I didn't remove the skid plate cover, supported the front sway bar with jack stands on each side with towels to protect from scratches.
    air23cpt[QUOTED] likes this.
  7. Mar 29, 2025 at 5:28 AM
    #307
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    Too bad there’s not a class action lawsuit on tow hooks not included on a $74K truck. Just like they did a lawsuit on the trucks not having a trans cooler. Peace. D
  8. Mar 29, 2025 at 8:42 PM
    #308
    RaulTX
    RaulTX New Member
    Raul
    2025 Mudbath Tundra TRD Pro
    Thank you for the comparison to the front license plate. Question: Does the new valance cover stick out more than the original one? I ask because I already have only about an inch of clearance between the struts on my garage door and the front license plate, so if the new valance cover makes the license plate stick out farther out it's a no-go for me.
    Thank you again!
  9. Mar 30, 2025 at 9:28 AM
    #309
    Breathing Borla
    Northern Illinois
    this was well documented , I’m saying I agree or like it but here it is…
    the lawyers overrode the engineers and they were citing crash and pedestrian testing
    the engineers have now won at least to the point you can get them after the fact , my guess when they do refresh at least some models will have them
    this changed when the taco was redesigned
  10. Mar 30, 2025 at 9:30 AM
    #310
    Breathing Borla
    Northern Illinois
    no damages , no class action
    besides lawyers get rich and you get .03 cents ten years from now
    much better off if you want super robust tow hooks for off roading, just shell the 500 and get them and move on with life
    they did put out a beast of a set at least !! Best tow hooks on any tundra ever by far as far as oem and I’ve owned them all
    Calif-Tundra, Beak01 and Huckwheat like this.
  11. Apr 4, 2025 at 7:44 PM
    #311
    air23cpt
    air23cpt New Member
    Got it done. Followed lavey's instructions and it worked out perfect. Just had to lose the fear of damaging a new truck and did it.
    motogon, MAC25Tundra, lavey and 4 others like this.
  12. Apr 5, 2025 at 3:45 AM
    #312
    TheDo114
    TheDo114 New Member
    2022 Black Tundra SR5 TRD Offroad
    Curious as well.
  13. Apr 5, 2025 at 4:34 AM
    #313
    Redward 25
    Redward 25 New Member
    2025 SS red Tundra SR
    none....yet!
    Those things look beefy! Great info, thanks for sharing it!
  14. Apr 5, 2025 at 8:12 AM
    #314
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    Wondering is it up to you where to put the license plate or are there markings on the bumper?
  15. Apr 5, 2025 at 8:16 AM
    #315
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    New panel has dimples for license plate hardware.
    matth66 likes this.
  16. Apr 6, 2025 at 6:33 AM
    #316
    Mrconnsmythe
    Mrconnsmythe New Member
    Saskatchewan, Canada
    2025 Tundra Ltd TRD OR WCP
    SA....as in Southern Alberta?
    From a dealership or?
  17. Apr 6, 2025 at 6:57 AM
    #317
    Tiger85
    Tiger85 New Member
    2025 Mag Gray Platinum i-Force MAX
    I can tell from the houses its San Antonio.
    Blufin likes this.
  18. Apr 6, 2025 at 11:45 AM
    #318
    lavey
    lavey New Member
    San Antonio, TX and from a dealership parts dept. but online.
  19. Apr 15, 2025 at 2:35 PM
    #319
    24TundraTRD
    24TundraTRD New Member
    '24 CrewMax Limited TRD
    How do you remove the old valance without taking off the whole front end?
  20. Apr 15, 2025 at 2:38 PM
    #320
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    pull from one end and finagle it out...its easy
  21. Apr 15, 2025 at 2:41 PM
    #321
    24TundraTRD
    Thanks. I'm assuming from the back side (under the truck) ?
  22. Apr 15, 2025 at 3:51 PM
    #322
    Siblue
    Siblue Old member
    25 Tundra TRD pro
    Access to remove panel from under the truck is the easiest. No spoiler on the pro was a bonus
    Derfla, sudobash and Tundrastruck91 like this.
  23. Apr 15, 2025 at 3:55 PM
    #323
    24TundraTRD
    Ok. Thank you. The spoiler might be coming off anyway. Just leave the motor hooked up to keep it from throwing a code.
  24. Apr 19, 2025 at 2:42 PM
    #324
    WindChillYeti75
    WindChillYeti75 New Member
    2025 WCP Limited TRD Off Road iForce Max
  25. Apr 21, 2025 at 8:24 AM
    #325
    RDW
    RDW New Member
    Rob
    NJ
    2025 Tundra Platinum TRD Off-road
    Heritage Grille w/ TRD Marker Lights, Diode Dynamics Light Bar and OEM TRD Dash Switch, Rigid Yellow Fogs, Diode Dynamics C1 Hitch Pod Light, AMP Powersteps Smart Series, Aftermarket Power Bed Step, Bedbug XLT, Rough Country Neoprene Rear Seat Cover
    Looks awesome! Guess I need this now.
  26. Apr 21, 2025 at 8:30 AM
    #326
    24TundraTRD
    I installed mine over the weekend. The passenger side seems to be a little lower than the drivers side. I used the same number of washers on both side. Has anyone else run into having to use more washers on one side to even them out? I know the instructions say they give you several to account for variances in individual vehicles, but I figured it would still be same on either side. It's not off by a lot, just enough to bother me.
  27. Apr 22, 2025 at 12:31 PM
    #327
    Skiomax
    Skiomax New Member
    Just got mine from my Dealership here in Ottawa Canada they are available now
  28. Apr 23, 2025 at 5:48 AM
    #328
    gmcguire7220
    gmcguire7220 New Member
    Ontario Canada
    2022 Limited TRD OR Crewmax - WCP- 2019 Toyota RAV4 Hybrid XSE
    TRD running boards & Bridgestone Dueller Ascent tires
    Awesome! Dealer installed? and how much if you dont mind?
  29. Apr 23, 2025 at 6:24 AM
    #329
    Breathing Borla
    Northern Illinois
    those things are beastly
    toyota went from underkill (none), to overkill, lol:thumbsup:
    sudobash and Skiomax like this.
  30. Apr 23, 2025 at 6:37 AM
    #330
    Skiomax
    Skiomax New Member
    Hook I got for 675 and 300 install my bill was just under $1000 cause my dealer gives a vet discount.
