General Supercharger Thread
  1. Apr 2, 2025 at 2:34 PM
    Tundra Texan
    Tundra Texan New Member
    Todd
    2016 Tundra
    None at this point.
    LOL...ya sneaky bastard.....
    snivilous[QUOTED][OP] likes this.
  2. Apr 2, 2025 at 2:47 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Recommend getting an AFR gauge too if you are still getting this installed. Don't know if that was suggested.
    If it is an older vehicle you'll want to do a preflight check before install AKA compression test and test fuel system.
    ARES35, HulkSmurf14 and mustang67408 like this.
  3. Apr 2, 2025 at 2:51 PM
    Saltyhero13
    PCV side only. Get yourself an AFR gauge too. If something starts to go wrong it will aid in troubleshooting.
    HulkSmurf14 likes this.
  4. Apr 2, 2025 at 2:58 PM
    Saltyhero13
    Headers and exhaust will drop boost some but how much depends varies about ~1PSI. A larger blower also helps keep the boost down.
  5. Apr 2, 2025 at 3:01 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Saw 2 psi drop in my setup recently. What would be typical next steps would be to double down on the pulley size to regain the boost loss but we’ll leave that to the built motor for moaarr powwwaa. Not that it really needs it
  6. Apr 2, 2025 at 3:17 PM
    Saltyhero13
    eh hem....If the Amazon cans weren't so cheap in price I could see a Sniv branded catch can.
  7. Apr 2, 2025 at 3:28 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    With the 3 inch exhaust, headers, no cats keeps the psi down.
    With a 6.75 or .71 crank pulley and 2.0 SC pulley I'm trying to keep it low. But the little 1900 does sing. Just gotta keep it all together. :D
  8. Apr 2, 2025 at 3:31 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Yes! Less boost more power super efficient is the key.
  9. Apr 2, 2025 at 3:37 PM
    Saltyhero13
    Shame I didn't have my boost gauge before headers. Probably wouldn't have mattered since I still had the stock muffler on lol.
    reywcms[QUOTED] and Mdl like this.
  10. Apr 2, 2025 at 3:48 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    No worries and wasn't implying any type of tunobery. And yes there are certain criteria that would definitely have my ride be rejected...:p
    Saltyhero13[QUOTED] likes this.
  11. Apr 2, 2025 at 3:53 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Finally got my relay box installed. Tried to copy @armyoffoo original setup as best I could. It did clean up the rats nest of wires and relays stacked on the fender/firewall. I still have some more to do... Thanks for the info!
  12. Apr 2, 2025 at 3:59 PM
    mustang67408
    Victor
    Hot dry place in Nevada
    Took me 6 weeks to catch up on this thread...I'll save you some time..
    Yes, it was the kill switch. Internal open in the switch intermittently..
    I replaced the switch with a better one and all issues have been fixed. Had nothing to do with the SC system or Tune...It was all on me...It just didn't do it when I was N/A....coinkidink.
  13. Apr 2, 2025 at 4:02 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Oooooh man! As the paper says, "Look Out!"
    The VB showed up!
    e30cabrio, AZTundra, ARES35 and 6 others like this.
  14. Apr 2, 2025 at 4:17 PM
    snivilous
    SW UT
    300k+ Supercharged 2008
    What decade do you plan to install that by? 2040?
    ssmokedz, AZTundra, ARES35 and 4 others like this.
  15. Apr 2, 2025 at 4:19 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    Haha I have the same RTV sitting on a shelf in my kitchen awaiting the gear install.
  16. Apr 2, 2025 at 4:29 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Anyone replacing a Level10 or IPT valve body with a WAT for a comparison? It would be interesting as they all use the same Transgo/Sonnax kits.
    See if one stands out as a clear winner. I liked hearing the WAT VB held up for a year on a 1000hp build with stock AB60 using DEX3.
    reywcms, ARES35, HulkSmurf14 and 4 others like this.
  17. Apr 2, 2025 at 4:38 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Second time I seeing reference to the 1000hp data point. Did I miss a link or a video? That's way better than the 600/650whp I'm tracking.
    Subscribed to this specific topic, though. Also curious since we're kind of blind to the secret sauce of the WATs (as I'm tracking, anyways). I'm most curious if there's a clear winner in road manners.
  18. Apr 2, 2025 at 4:46 PM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
  19. Apr 2, 2025 at 4:58 PM
    HulkSmurf14
    2014 Tundra Limited
    Hahaha damn Sniv! I know, I know...I want to get this installed quickly, like in a couple weeks so I don't forget to send the core back! Than I'll have the pulley and injectors installed shortly after that...this summer I want to drive it with It and I both smiling! And yes, tuning optimizations will be needed...
  20. Apr 2, 2025 at 5:50 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    @bflooks. In Dubai on a turbo setup, a stock AB60, Extreme VB running Dex3 was able to withstand 1000hp. The guys at WAT were happy that it took a year to finally fail. Apparently they didn't think it would last that long. So the story goes...when I was chatting with Johnny at Cruisers and Co.
  21. Apr 2, 2025 at 5:58 PM
    Silver17
    Eastern PA
    But did it sit in a garage for 11 months and then they decided to take it out for one pull? :rofl:
    That’s pretty cool though. I wonder if the rest of the trans was fresh or already beaten on when they installed the VB?
  22. Apr 2, 2025 at 6:30 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I believe WAT sent the fresh trans and VB to Dubai and it was ran hard all year.
  23. Apr 2, 2025 at 7:15 PM
    centex
    centex New Member
    To completely derail the convo, yall seen the dune racers and crazy off road stuff they do over in Dubai? It’s awesome. Lots of them have money but even the ones that don’t have some awesome rides.
  24. Apr 2, 2025 at 8:00 PM
    Saltyhero13
    I just bought the Alcon brake kit and now you say this too?!? :spending:
    I'll need to rewatch the PS Turbo Tundra vid again and ask them what they were running for the VB since they thrashed the 1000HP rated transmission twice and ended up doing a transmission swap. I think they said the reinforced transmission wouldn't hold 650. Meanwhile Viktor G was drag racing his truck on a stock transmission with a VB and pushed beyond that threshold.
    Sounds like VB is the key
    LILTRD, M3Tundra-JK, Wynnded and 4 others like this.
  25. Apr 2, 2025 at 8:19 PM
    Saltyhero13
    "Send 1000HPs or the Transmission gets it! Here is proof of life..."
  26. Apr 2, 2025 at 8:27 PM
    sbxx312
    sbxx312 New Member
    2018 Tundra, 2012 s/c Tacoma
    I grew up there. We called it wadi bashing. It wasn't just for the rich Arabs. Crazy dune driving with post game music and fun.
  27. Apr 3, 2025 at 9:15 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    I'm at 2600rpm at 80mph indicated with 5.29s and 35s. Which is 84mph on gps. You're not crazy @snivilous
    Mdl, HulkSmurf14 and snivilous[OP] like this.
  28. Apr 3, 2025 at 10:43 AM
    Silver17
    Eastern PA
    This thing better be able to do a 12.5 1/4 mile after these gears and valve body.
    :turtleride:
  29. Apr 3, 2025 at 11:04 AM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    Fresh from down undahh
  30. Apr 3, 2025 at 11:17 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I wonder if they use a plate between the upper and lower valve body that resists wear better than OEM. As we know the VB passages wear out and don't hold pressure causing failures.
