General Supercharger Thread
  1. Apr 1, 2025 at 9:26 AM
    Cthenbest54
    Cthenbest54 New Member
    Do you have a recommendation of who to use for a tune? I want someone who knows what they are doing. I want the longevity of the Tundra. Not a lemon.
    mustang67408 and HulkSmurf14 like this.
  2. Apr 1, 2025 at 9:26 AM
    snivilous
    SW UT
    300k+ Supercharged 2008
    @JustDSM OTT https://overlandtailor.com/
  3. Apr 1, 2025 at 9:27 AM
    Cthenbest54
    I am new to the forum world. What does OTT mean?
    mustang67408 likes this.
  4. Apr 1, 2025 at 9:27 AM
    snivilous
    SW UT
  5. Apr 1, 2025 at 9:40 AM
    mustang67408
    Victor
    Hot dry place in Nevada
    ^^^^ WHAT HE SAID!!!
  6. Apr 1, 2025 at 9:43 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    A good tune goes a long way, @snivilous does tuning also. @JustDSM and @snivilous are top contributors and tons of help!
    It's not too common to have rod/ring/wrist pin/valve failures on these engines but it does happen. Not only to the Forced Induction engines but to the N/A crowd too.
  7. Apr 1, 2025 at 10:51 AM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    I was randomly thinking about this earlier, and a way to compare the two. And I hope this doesn't disrespect Sniv or OTT at all! But it made me chuckle a little when it came to mind.
    OTT is like Dr. Pepper. It's a premium, more expensive product with some proprietary things going on.
    Sniv is like Dr. Thunder. All the stuff that makes DP great, minus a few small things you may not notice, but at a lower cost
    Both great choices! I wouldn't turn away either if a cup was handed to me. And hard pressed to taste the difference
  8. Apr 1, 2025 at 11:10 AM
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    I don’t have use for it due to my geographical location, but that’s pretty cool. I’d be curious to find out more about how that one gets set up. I have to assume it just modulates the vacuum going to the existing bypass valve diaphragm to control boost?
  9. Apr 1, 2025 at 11:15 AM
    snivilous
    SW UT
    Hahahaha :rofl:
    I'll avoid adding my own comparisons, I'm not a tuner, just here to help :D
  10. Apr 1, 2025 at 11:55 AM
    texoma
    texoma Triple C Chop Shop
    ChrisTopher
    Lago Vista, TX
    2018 Limited Tundra
    All the Chrome
    I dig it. Being from Texas, I love Dr Pepper.
  11. Apr 1, 2025 at 12:13 PM
    snivilous
    SW UT
    Average sniv speed shop customer? :rofl:
  12. Apr 1, 2025 at 12:16 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Damn...you got me. Needs more facial hair though. Haha
  13. Apr 1, 2025 at 12:43 PM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    Looks like that's how it works, instead of replacing the bypass with an electric one like the smoothboost. be nice if they had some technical details instead of a bunch of marketing BS about their algorithms and how great it is
  14. Apr 1, 2025 at 2:50 PM
    NatesNightMare
    NatesNightMare Is what it is
    Pinetop Az
    Tripleconpanna and HulkSmurf14 like this.
  15. Apr 1, 2025 at 2:57 PM
    snivilous
    SW UT
  16. Apr 1, 2025 at 3:02 PM
    Silver17
    Eastern PA
    I don’t have 5.29s yet but it looks close according to this calculator. I will say, 80 Indicated on 35s is probably more like 87 in reality by GPS isn’t it?
    NatesNightMare likes this.
  17. Apr 1, 2025 at 3:03 PM
    snivilous
    SW UT
    Yea you have to put in stock tire size which is what the dash thinks. Actual tire size doesn't matter in this case since the speedo isn't referencing actual size.
    HulkSmurf14 and Silver17[QUOTED] like this.
  18. Apr 1, 2025 at 3:07 PM
    Silver17
    Eastern PA
    Interesting.
  19. Apr 1, 2025 at 3:12 PM
    snivilous
    SW UT
    That's what I'm saying. Though maybe it's just tolerance stack up between the tach and speedo. I would expect every truck to read identical, but obviously not (my truck reads right around 2650 at 80mph indicated). But sub 2500rpm just seems exceptionally low.
    HulkSmurf14, reywcms and bflooks like this.
  20. Apr 1, 2025 at 3:36 PM
    Silver17
    Eastern PA
    Maybe @NatesNightMare has a speedo correction device and doesn’t know it if he is not the original owner?
    HulkSmurf14 likes this.
  21. Apr 1, 2025 at 6:13 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
  22. Apr 1, 2025 at 7:05 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Maybe he's running 44s :notsure:
  23. Apr 1, 2025 at 9:35 PM
    NatesNightMare
    Pinetop Az
    Nope my speedo is on
  24. Apr 1, 2025 at 9:38 PM
    NatesNightMare
    Pinetop Az
    Ive checked my speedo and it reads correct
  25. Apr 1, 2025 at 11:23 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    I ran my speed against the local radar. It seems to be reading about 5-6mph above what is on my speedometer running 35's as I don't have any correction for it. Hpt only corrects transmission rpm and not the speedometer. So I could probably drop 150-250 off my rpm for the corresponding speed.
    ARES35 and HulkSmurf14 like this.
  26. Apr 2, 2025 at 5:14 AM
    Silver17
    Eastern PA
    Did you check it against a GPS app like Waze or google maps? It would make sense for your RPMs if it is correct, but if it is correct then you must have a speedo calibration device buried in your dash like the hypertech or rough country one. Are you the original owner? Without a calibrator, on true 35s your speed should be off by 8-10%, and if it’s not then your speedo was off by that much from the factory which is pretty bad.
    :deadhorse:
  27. Apr 2, 2025 at 5:49 AM
    bflooks
    bflooks New Member
    Metrowest MA
    Data point: My 33's are within 1mph of the stock speedometer, no calibration.
    Apparently I confused towing vs cruising revs. These RPMs were in 6th with a locked TC (source: https://www.tundras.com/threads/anyone-ever-re-geared-a-stock-truck.149308/page-2#post-3820053).
    "Confirmed this afternoon, 5.29s on 33.4":
    6th gear
    2100rpm @70mph
    2200rpm @75mph
    I won't confirm nor deny the 100rpm/5mph is accurate throughout 6th gear."
    I know I haven't driven the truck since Jan 16th, but I am sitting here surprised at my own data points. I would have bet a dollar my RPM were higher, but I vividly remember capturing these data points to support the discussion in the referenced thread.
  28. Apr 2, 2025 at 9:04 AM
    Silver17
    Eastern PA
    Was it this thread where it was mentioned the trans valve body was heavy? FedEx tracking says it is 16.3 lbs. which doesn't seem right.
  29. Apr 2, 2025 at 9:10 AM
    snivilous
    SW UT
    It'll feel heavy when you're bench pressing that bitch with one arm and squanch falling in your face trying to line up one bolt to hopefully some year start threading in while the check ball and springs are also falling out.
    ssmokedz, ARES35, Danimal86 and 10 others like this.
  30. Apr 2, 2025 at 9:10 AM
    Abell207
    Abell207 New Member
    Anthony
    Maine
    2020 Army Green TRD PRO
    I remember that also. I think it was in their video.
